Author Topic: 1975 cb550 Project SENCHA - bike has found new home  (Read 89662 times)
Offline goldarrow
  • one day, i'll be an
Re: 1975 cb550 Project SENCHA - FORK SEALS - STEERING STEM - SWINGARM
« Reply #150 on: September 12, 2012, 07:19:07 PM »
swingarm bushings decided to take forever to come in from Germany, but it's ok, it's cheap, so no rush.  moving on to the next part.
Steering Stem - getting All Balls Tapered Bearing part number 22-1011 $29.64 shipped
back 3 months ago, on page 1 post #21 when i took the top and lower triple tree stem and bearing apart
top triple tree was painted last month. lower triple tree stem is now cleaned, primed, and painted.  ready to be put back
Forks rebuilt -  All Balls fork seals part number 55-108 $12.43 shipped
top portion of forks are rusty and some pitting, these will get cleaned up, primed, and painted
the bike came from NY, last titled in PA, will get titled to CA when the bike is alive
fork oil drained, 37 years old oil? or more? so greyish black and smell like toilet drain
making sure of the markings on the forks and mounting hardware, knowing which way is facing front
everything comes out pretty much straight forward...
-drain the fork oil
-take off bottom fork cap
-unbolt and take off the hex bolt at the bottom
-take off the top cap bolt, be carefuly it may fly because of inside spring tention
-remove the long spring
-remove the fork tube
-remove snap ring, using snap ring pliers or other tools
-pry off old seals using strong flat head screw driver, use towl to cushion the screw driver to minimize scratches or damages to bottom fork.  the seal is tuff to come off, so just pry it!
-remove damper piece, it's all the way at the bottom of the fork
- clean everything
my damper unit doesn't have the long stem piece as pictured in the manual, is this normal? now that i'm really looking at it, i don't have the lock nut part #2 and the long rod (same length as the spring)
CB550 K0
Offline fastbroshi
  • Puppet
« Reply #151 on: September 12, 2012, 08:40:24 PM »
I took apart some forks awhile back, I think they're 500 forks as only one of the legs has the boss to mount the caliper arm.  They had exactly the same parts as the diagram.   Maybe you have the later forks.
Just call me Timmaaaaay!!!
« Reply #152 on: September 13, 2012, 12:37:03 AM »
the picture is 500 forks you have 550 ones.
Offline goldarrow
« Reply #153 on: September 17, 2012, 06:57:09 PM »
i didn't have a whole lot of time to myself over the weeken, and i was pretty much everywhere about the bike.
first of all, i can't do photoshop for !@#$! (the life of me).  but here's the photoshop mock up.
steering stem bearings set.  Top bearing set All Balls part numbers 33-1006 and 99-3511.  Bottom bearing set All Balls part numbers 99-3512, 33-1007 and 99-1054 (thin spacer)
here's how the bottom bearing went in to the stem
steering lock position
bottom spacer sit flushed with the bottom neck
everything went in smoother than what i had anticipated
here's mock up with my painted top forks
CB550 K0
« Reply #154 on: September 17, 2012, 08:18:38 PM »
Love your photo chop! Forks look good.
Offline SohRon
Re: 1975 cb550 Project SENCHA - SWINGARM
« Reply #155 on: September 23, 2012, 08:08:52 AM »
My Element had a nail in back tire. Got a free flat fix at Costco. On my way there about 5 blocks from my house I caught this in the corner of my eyes at a garage sale
Turned my car around to look and it turned out to be a 1974 CB360. Not the best looking bike but for $350 I had to save it.  I had 10 bucks on me so I gave him a deposit, hoping that when I came back it was still there.    2 hours later, flat fix and rest of money, went back to see the bike, it was still there. Sweet.  I rode, well kind of limped it home.  :)
God, I hate you!  >:( ;D ;D  Why don't I ever come across these deals? At a yard sale?!?!? Can't find anything like that for under $1500 where I'm situated. Dang! I'm going to have to take a serious look at my life to see what I've done that keeps me from deals like this. Musta been something terrible  :o ;D
Kudos on the find, and your work on the '550. Will be looking forward to the build thread on the '360.
« Last Edit: September 23, 2012, 08:28:01 AM by SohRon »
Offline fastbroshi
  • Puppet
« Reply #156 on: September 23, 2012, 10:40:23 PM »
Judging by your pic, you just used the one thicker spacer.  Is this correct?
Offline onepieceatatime
« Reply #157 on: September 23, 2012, 10:46:42 PM »
A little farther up in that post, he said the thin spacer.
1965 CA77
1972 CB750K Ol' Sarge
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
Offline fastbroshi
  • Puppet
« Reply #158 on: September 24, 2012, 03:41:09 AM »
Correct, but that's not the thin spacer pictured.  The thick spacer can be identified by the casting mark in the center of its circumference, which is shown in the pic.
Offline goldarrow
« Reply #159 on: September 24, 2012, 12:05:10 PM »
Fastbroshi, I used the thin spacer
Here's pic of thick spacer in my hand measured, and whats left unused from the package. Almost 5mm thick.
CB550 K0
Offline goldarrow
« Reply #160 on: September 24, 2012, 12:16:28 PM »
Well, life sucks. :( But may be for the better. And you may hate me for this. :)  Got laid off from work last week. Stressed out. Very stressed. So I decided to take a 7 hours drive road trip with a friend who was delivering smerchandise to client.  23 hours trip total I came home with this
1978 Suzuki GS550 for $300. The bike runs, carb needs to be gone through as it leaks gas when turn on petcock. Front light broke but came with a spare. One rear blinker broke. Original title from owner back in 1979. Tool kit and manual included.
« Last Edit: September 24, 2012, 12:20:06 PM by goldarrow »
CB550 K0
« Reply #161 on: September 24, 2012, 02:56:04 PM »
Love the 1978 GS1000, especially with the Wes Cooley Yoshimura look.  The 550 and 750 share the looks but could use the bigger mill.  I came very close to buying a Wes Cooley replica and a stocker.  In the end, I decided to pick up my sitting CB750 project.
Offline fastbroshi
  • Puppet
« Reply #162 on: September 24, 2012, 03:03:36 PM »
Well damn they look like the same one.   Thin spacer it is then.
« Reply #163 on: September 24, 2012, 03:50:12 PM »
Let me get this straight: you got laid off and you bought another bike?!  Sorry to hear.
BTW, nice calipers. I need some.
Offline PrsCustom22j
  • "they've done studies you know...60% of the time it works every time"
« Reply #164 on: September 24, 2012, 06:15:40 PM »
that engine rocks man...nice work.   someday i'll do that to mine.  keep posting those pics   ;D
1976 Honda CB550K
Offline goldarrow
« Reply #165 on: September 24, 2012, 07:39:11 PM »
Yes  :'(. Another victim of [not so good] educational system. Company has been laying off since January and I'm the last round. Next may be closing.
Looking for something to do while job hunting, so what might you guess?
On my way to pick up another one.  :o
CB550 K0
Offline goldarrow
« Reply #166 on: September 24, 2012, 11:27:29 PM »
And here is the one......
.....and is a keeper
Bike came with bill of sale and two up seat
« Last Edit: September 25, 2012, 12:30:09 AM by goldarrow »
CB550 K0
« Reply #167 on: September 25, 2012, 06:00:29 AM »
And Lesters?
We all hear how expensive bikes are in Cali but you've come across some good deals.
Offline goldarrow
« Reply #168 on: September 25, 2012, 12:15:59 PM »
And Lesters?
Front wheel is confirmed Lester with marking.  Can't fine the marking on the rear wheel yet.
Bikes are still expensive here I agree, that is if one get stuck working in office. Deals are out there, just have to have time for it.
This orange bike is not as cheap (4x more than the gs550) as the others that I got previously. But all complete and looks like a runner. Some tappets cover were butchered with vise grip. May be why it was parked.
« Last Edit: September 25, 2012, 12:21:27 PM by goldarrow »
CB550 K0
Offline rb550four
« Reply #169 on: September 25, 2012, 05:03:56 PM »
Will this orange one be for #2 son? Looks promising.
« Reply #170 on: September 25, 2012, 06:46:12 PM »
The rear Lester wheel will have the name in the drum brake area of the hub.
Offline goldarrow
« Reply #171 on: September 30, 2012, 10:13:04 PM »
Definitely this orange bike is a keeper and for one of 3 sons. I'll let them fight over who wants which bike.
Not sure if I'm ready to disassemble the wheel yet but thinking about swapping them on to my project though. The gold wheels have not been cleaned up yet.
Over the past week I have been very busy cleaning up back yard to make some space for bikes and storage, but able to get bits and pieces done on the bike.
So, swingarm bushings came in about 3 weeks ago, and has sat in the freezer ever since.
Took them out today for installation. Small amount of grease lubed the arm holes. Dropped in the bushings and started whacking it with big rubber mallet. Took some whacking force but wasn't too bad. No torch heat needed.
First side went in, no problems
One side went in, lost some paint on the edge
Pivot collar went in
Pivot shaft went in next
All assembled on to the bike. Left side has washer for the nut, but right side is not there..Looks like i lost the nut washer when disassembling.
The zerks were removed, need to go to HF for tap and die tool kit
CB550 K0
Offline Main Street
« Reply #172 on: October 01, 2012, 10:33:15 AM »
Following....
Knees in the Breeze
Offline goldarrow
« Reply #173 on: October 02, 2012, 08:54:37 PM »
Ok so I put in the zerks and greased up. Stupid question for the day. How much grease is too much? I put in until grease started coming out of every where.
The swingarm is parallel to the ground by itself, did I tighten engine hanger bolts too tight?
New to me shocks went in. Progressive shocks I believe they are series 12. Got them from forum member mainerider way while back.
CB550 K0
Offline fastbroshi
  • Puppet
« Reply #174 on: October 02, 2012, 09:03:18 PM »
The way I understand it, the arm should swing freely up and down with mimimal slop side to side when tightened.   It shouldn't be holding itself in position.  Maybe something to do with all the extra grease that's in there now?
