Author Topic: Using the kill switch  (Read 9990 times)
« on: December 04, 2012, 07:00:05 AM »
Here is a topic for extensive discussion.  Do you use the kill switch on regular bases to stop the engine?  I was taught - and it was long time ago - that it is for emergencies only.  I always turn the key, but as far as reason the only one I can come up with that kill switch is just an interupter and the key switch is, or should be,  build to handle the ampers.
Opinions?
Re: Using the kill switch
« Reply #1 on: December 04, 2012, 07:22:57 AM »
I use mine quite a bit to turn off the engine after a ride,then I reach down under the tank and turn off the key.I can see why Honda moved the ignition up top in later years,little more convenient to get to.
Offline RSchaefer
« Reply #2 on: December 04, 2012, 07:28:32 AM »
I never use the kill switch and I was thinking due to the primitive nature of the kill switch construction that it should be avoided on the vintage bikes, used for emergency only.
'66 CB77, 305 Superhawk (Project Bike)
'72 CL 175, (Project Bike)
'75 CB750F (Project Bike, Complete)
'05 GL1800 ABS Black Cherry (Current Ride)
'87 GL1200 Wineberry Aspencade
'83 GL1100 Wineberry Aspencade
'76 GL1000 LTD
'75 GL1000 Turquoise
'69 Honda 750cc Gold
'67 Honda 305 Dream Black
'63 Honda S90 Black
'61 Honda 50 Red
GWRRA #000008
VJMC Member
Offline pchchico
« Reply #3 on: December 04, 2012, 07:32:20 AM »
I  never ever use the kill switch on any of my bikes, and make sure  i tell everyone who rides them to never use the kill switch.   What  inevitably happens is people use the kill switch then forget to turn off the ignition switch (key) and  then the battery dies.
I did it once and learned my lesson ever since.
« Reply #4 on: December 04, 2012, 07:38:19 AM »
The MSF (Motorcycle Safety Foundation) Safety Course says use the kill switch every time. I've taken the course 3 times and don't really know why this is. I suspect it goes with the idea that you shouldn't take your hand off the handlebar while the engine is running, but that is my WAG.
I never use the KS.
Offline CycleRanger
  • No comment about being an
« Reply #5 on: December 04, 2012, 07:54:23 AM »
Just to be different - I almost always use mine.  As was mentioned, I can kill the bike before I let go of the bars.
It's a routine - kill switch off, headlight off, key switch off, gas off. :)
« Last Edit: December 04, 2012, 08:44:02 AM by CycleRanger »
Offline Geeto67
  • A grumpy
« Reply #6 on: December 04, 2012, 07:59:55 AM »
the older the bike the less I use it. Why? have you seen the price of right hand bar controls vs the price of an ignition lock? more importantly have you seen inside both pieces - which is the more robust piece - the lock or the bar control? I replace broken kill switches with a deadman's switch. More effective in an emergency and required for the drag strip, plus it forces me to use the key because I don't want to be bothered with resetting it.
Maintenance Matters Most
« Reply #7 on: December 04, 2012, 08:24:28 AM »
Kill switch is well up to the current it carries as it only switches the coils, problem is remembering to turn it back on when you want to go anywhere!!!
Offline Old Scrambler
« Reply #8 on: December 04, 2012, 08:43:13 AM »
I'm with Ekpent and CycleRanger.......been using my K3 switch for nearly 40 years and over 70,000 miles. It has never failed.
The advanced safety course is a great learning experience. My instructor was laughing but did not say anything when I stood on the pegs to negotiate the tight figure-8 turns. Then he had to run and help the BMW LT rider pick his bike up.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
« Reply #9 on: December 04, 2012, 08:45:09 AM »
Use my kill switch ALL the time. Good habit to get into IMO..
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
« Reply #10 on: December 04, 2012, 08:50:43 AM »
OS: AS you probably know standing on the pegs lowers ones center of gravity and makes tight slow negotiations easier, like a trials bike.
Offline trueblue
« Reply #11 on: December 04, 2012, 09:06:18 AM »
When I did my safety course a couple of years ago (Q-Ride here) I was told not to use the kill switch unless in an emergency.  I use mine every now and then, but as a general rule I use the key.
1979 CB650Z
« Reply #12 on: December 04, 2012, 09:33:41 AM »
Its been a while since my last MSF course. They may have changed the protocol.
Offline trueblue
« Reply #13 on: December 04, 2012, 09:36:36 AM »
Different country ;)
1979 CB650Z
« Reply #14 on: December 04, 2012, 09:41:24 AM »
Ah so. Could be different.  :D
Offline Elliot Cannon
« Reply #15 on: December 04, 2012, 10:57:31 AM »
Well.  That settles that then! :D ;)
« Reply #16 on: December 04, 2012, 11:43:30 AM »
i use mine from time to time when parking on a grade,i leave in it first,pull the clutch and flick the switch,then the key gets switched off and i flick the kill back to on straight away.
Offline Magilla
  • My bike: 1976 CB750F
« Reply #17 on: December 04, 2012, 11:53:28 AM »
I use mine 100% of the time.  I don't like to take my hands off the bars when it is running so I flip the KS.  The Key being under the tank on the clutch side of the bike is not a safe place for it.  I prefer to keep my bike in gear when not running and I don't want to reach for the key with my right hand because its awkward and would cause me to scratch my paint.
I have been riding for 31 years and have used my KS 100% of the time on every bike I have owned. Think of it like a light switch.  When you want your light off you flip the switch, you don't go to your circuit breaker box and flip the breaker.  The switch is designed to do the job, that is why it is there.  It says "Off-Run-Off" on it.  Not Emergency off.
1972   Honda CB350
1972   Yamaha 500
1982   Yamaha 650
1988   Harley Sportster 883
1983   HD FXR Shovelhead
2003   HD Heritage Softail
2006   Victory Vegas Jackpot
1980   Honda CB650
1976   Honda CB750K
1982   Honda CB750
1964   Honda CA95
1982   Kawasaki 550
1974   Honda CL360
1975   Suzuki GT550
1981   Honda CB750
1981   Honda CB750
1970   Norton Commando
1972   Yamaha U7E
1970   BMW R50/5
1976   Honda CB750F
Offline LoVel
  • Yes, I remember your mother well. She was quite the
  • 1972 CB500 four
« Reply #18 on: December 04, 2012, 12:28:03 PM »
My MSF course told us to use the kill switch.  I tried it, don't care for it, don't use it.
I'm an individual,  just like everyone else.
Offline Fritz
« Reply #19 on: December 04, 2012, 01:45:13 PM »
I think that using the kill switch frequently is a good 'training' to find it quickly in case you _really_ need it.
1976 CB550F
Offline Geeto67
  • A grumpy
« Reply #20 on: December 04, 2012, 02:11:48 PM »
you could fix that by drilling a little hole in the knob and using a keychain ring and a lanyard with an alligator clip to make a makeshift deadmans switch. Then you can brag your bike is "full race" to boot.
Offline Gordon
  • 750K1, 550K2
« Reply #21 on: December 04, 2012, 02:27:08 PM »
I only use mine on the occasion that I can't quite get the transmission into neutral after I've parked.  I don't have any particular reason for not using it regularly, though.  I guess I just never felt the need to, since I have to turn the ignition off anyway.
Offline Bailgang
  • Scott
  • Indiana
« Reply #22 on: December 04, 2012, 02:38:40 PM »
I use the kill switch mainly because my 550 can be stubborn going into neutral when the engine is running and at operating temp but easy when the engine is off so I just turn the switch, wait for the green light on the trees to light up when I find neutral then turn the key off. And yes I am guilty of leaving the key on once.
This topic popped up before and it turned into a rather heated debate and I never could understand why. Both points of view have valid reasons so as far as I'm concerned it's nothing more than a personal preference. Basically it's your bike, you pay the bills for it not me so turn it off however you d..ned well please, you wont catch any flack from me on which way you choose.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
Offline lucky
« Reply #23 on: December 04, 2012, 02:53:57 PM »
Opinions?
You were taught correctly.
The emergency switch was designed so that emergency personal could shut of a motorcycle engine. They needed to be able to get to it when the bike was down.
You should TURN the key to turn on your ignition system.
Offline LoVel
  • 1972 CB500 four
« Reply #24 on: December 05, 2012, 05:43:12 AM »
Note lucky's post and the, I am right and this is the only answer attitude.  You don't really wonder why the heated debate do you.
