Author Topic: Sandcast 4286 Project  (Read 192230 times)
Offline Bill/BentON Racing
    • BentON Racing
Re: Sandcast 4286 Project
« Reply #525 on: March 16, 2014, 09:44:20 AM »
Greggo, it's the 80/20 20/80 time!. Last 20% takes 80% of the time!! ;D
Really looking good, off to look for kicker in a few! 8)
BentON Racing Website
BentON Racing Facebook
Offline rtbmrgl
  • Got Points! Roseville, Ca
« Reply #526 on: March 22, 2014, 11:39:04 AM »
I dropped off the chrome bits at that plater and got a quote.  I'm glad I found these guys.  I did end up not having him do the gauge backs because they were too badly pitted.
19 pieces for $460 out the door is a smokin' deal in California.
I live in the Sacramento area, whats the name of the chrome shop. I have mufflers for my CB500 I may have chromed.
thanks, Mark
Roseville, Ca
Got Points!
1973 CB500 back yard find 1243 orig mi,  http://forums.sohc4.net/index.php?topic=124285.0
1976 CB750 Restoring,        http://forums.sohc4.net/index.php?topic=132997
« Reply #527 on: March 22, 2014, 12:01:35 PM »
Get your chromed items back yet, Greggo?
I didnt, been 4 weeks, still waiting on my two K4 mufflers
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #528 on: March 22, 2014, 03:37:26 PM »
It's called Electro Forming, in Richmond California.  They're open I think from 8am to 330pm, and aren't great at answering the phone sometimes.
Stev-o, I haven't gotten them back yet, I expect it'll be another couple weeks.  I'm guessing left side mufflers? ;D ;D
« Reply #529 on: March 22, 2014, 07:31:42 PM »
No, L&R Action Four 4 into 2 mufflers.  I love the sound....
Offline rtbmrgl
« Reply #530 on: March 23, 2014, 12:12:24 PM »
Thanks Greggo, Ill give them a call,  8)
thanks, Mark
Roseville, Ca
Got Points!
Offline Greggo
  • Somebody's
« Reply #531 on: March 23, 2014, 02:42:09 PM »
Nice! I bet you'll be happy when they look brand new. Which bike are they going on?
« Reply #532 on: March 23, 2014, 03:59:36 PM »
On the K4 Boss Maroon, avatar bike.  I have it apart rebuilding the front end.  Bearings, springs, seals etc.
Offline Greggo
  • Somebody's
« Reply #533 on: March 25, 2014, 08:19:29 AM »
Started working on my spare K0 hubs...it started out like most do: yellowed and dingy looking.  That factory clear coat is TOUGH!  I let the spray on Air Craft Paint Remover work its magic for about half an hour, and it still didn't break through all the clear.  But, under that clear is a real nice looking hub.  I should be able to just lightly clean up the rough spots, and re-clear at least this front hub.
Here is the other hub I already had clear coated...too flat looking.
« Last Edit: March 25, 2014, 08:23:20 AM by Greggo »
« Reply #534 on: March 25, 2014, 04:48:03 PM »
That did clean up nice.  Flat sheen clear....who knew?
Offline Greggo
  • Somebody's
« Reply #535 on: March 25, 2014, 05:51:21 PM »
It's because of the way I prepped it, but he put a lot of clear on them.  I think I'm going to coat them myself when I get them looking right.
Offline Greggo
  • Somebody's
« Reply #536 on: March 28, 2014, 03:54:11 PM »
Another day of "Nothing is easy on this project..."
We borrowed a hone from a shop my dad is friendly with, and honed the .50mm overbored cylinders to find that one of them is pitted beyond usability.  Instead of boring all four cylinders and buying all new pistons, I'm going to bore a standard sized sleeve from another cylinder and swap it with the one bad sleeve in my sandcast set.  It's a lot more work than I was expecting, but it's the most cost effective solution.
The bad sleeve...pits can be felt with a fingertip.
A good sleeve for comparison
I reinstalled the shifter mechanism pieces, but it doesn't feel right to me...I'm going to disassemble it and do it again more carefully.
Does this look right?
Offline Greggo
  • Somebody's
« Reply #537 on: April 05, 2014, 05:16:59 PM »
I disassembled the shifter mechanism and started over..something was off with the roller pins that clamp onto/into the shift drum..everything feels nice now.  I pulled the engine covers off the K1 that came in this sandcast frame, and started working on finishing them.  The shifter (mission) cover is cleaning up very nice with green scotchbrite, but the valve cover is going to require some sanding.  It started oxidizing the moment I cleaned off the clear coat with paint remover.
Offline Greggo
  • Somebody's
« Reply #538 on: April 12, 2014, 02:18:25 PM »
Cylinder/sleeve swap is done.  It took a little over an hour between heating up two different sets of cylinders and swapping a good sleeve into the sandcast cylinder set.  I'm definitely going to have to repaint the good set when they come back from boring.  Just the one cylinder has to be bored .50mm to match the others.  That took up most of my time today, but I also got the handlebars wired with the new switches, and bead blasted all my engine covers...it was taking too long to get an even finish with sandpaper and elbow grease - now I'm starting from the same place on all of them.
The head is out at a machine shop still, but should be ready soon.
The 'new' sleeve is pretty obvious when set against the others...
« Reply #539 on: April 12, 2014, 06:35:28 PM »
What bars are those, Greggo?
Offline Greggo
  • Somebody's
« Reply #540 on: April 12, 2014, 07:34:43 PM »
K0/K1..they're not perfect, but they came with the bike.
Offline Greggo
  • Somebody's
« Reply #541 on: April 13, 2014, 09:00:48 AM »
I'm gettin' there...
The valve cover is a real pain in the ass to get an even finish on.
And, the alternator cover has some deep scratches I can't get out...crap :-/
Offline Greggo
  • Somebody's
« Reply #542 on: April 19, 2014, 01:55:16 PM »
Sandy head is back from the machine shop, and looks the business :D :D
Looking for ideas on how best to fix the busted spigot without heating up the head and replacing it...
« Reply #543 on: April 19, 2014, 02:23:55 PM »
Head looks great except for that spigot. Why dont you want to replace?
« Reply #544 on: April 19, 2014, 03:08:54 PM »
I'd replace it.... ;D ;)
Offline Greggo
  • Somebody's
« Reply #545 on: April 19, 2014, 05:25:56 PM »
We probably will have to replace it...just didn't want to have to heat it up like that now..
Offline Old Scrambler
« Reply #546 on: April 20, 2014, 01:43:28 PM »
Try applying heat from the inside..............If no, put ice on inside after minor heat on the head............they have a sealing-agent in the threads to overcome.............then be sure to seal the new unit.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline Greggo
  • Somebody's
« Reply #547 on: April 20, 2014, 01:53:24 PM »
Thanks OS!  I knew there was some sealant to overcome.  Any ideas on what to use on the new one?
Offline Greggo
  • Somebody's
« Reply #548 on: April 25, 2014, 01:04:34 PM »
Gotta love Yamiya for some stuff.  Even with shipping, I got four OEM grips for less than the price of two from the Honda dealer.  I stocked up on extra fork copper crush washers in case I need 'em later.  I don't know where else to find them.  Also got the correct K0 single cable throttle tube, ten exhaust spigot screws, and an extra starter button.
The cylinders are off to be bored, and we're going to replace the busted intake spigot.
« Reply #549 on: April 25, 2014, 03:54:05 PM »
Yes, Yamiya is quite a site, some stuff is worth more than the entire US space program and other stuff is dirt cheap, I think their pricing officer likes acid..... 8)
