Author Topic: old german mini lathe  (Read 9798 times)
« on: April 20, 2013, 03:40:50 AM »
hey dig this little lathe a mate gave me today,it was his father inlaws whos now passed,its a "lorch" brand,it has an aussie drive motor though,,it all seems to move and work ok,any tips on using it?,i still have to get a box of other stuff that goes with it from him,,im guessing the cutting tool mount and tools,hopefully a tail stock mini chuck?
Re: old german mini lathe
« Reply #1 on: April 20, 2013, 04:28:57 AM »
Great score,Dave!
Offline trueblue
« Reply #2 on: April 20, 2013, 04:34:59 AM »
The best way to use that Dave is give it to me ;D
1979 CB650Z
Offline mick7504
« Reply #3 on: April 20, 2013, 04:37:05 AM »
Nice Dave.
All Australian boys need a lathe and a shed.  ;D
They're an asset mate and easy to be self taught.
I've bought a few bits and pieces from this fella over the years.
http://stores.ebay.com.au/THE-ENGINEERS-SHOP/Engineering-Tools-/_i.html?_fsub=2&_sid=174423672&_trksid=p4634.c0.m322
If I was you
I'd be worried about me.
« Reply #4 on: April 20, 2013, 04:44:35 AM »
im going to start making custom one off jets for any pod users?the chuck is just that too small for swing arm bushes,it has a leather drive belt thats disintergrating,the "gmf" motor spins up ok,its so tiny,,i might have a little wank?
good link mick750 thanks,,err i mean wanks,ihavent touched a lathe since trade school,we made the obligutory center punch and screw driver etc,,i still have use that punch!
« Last Edit: April 20, 2013, 04:54:58 AM by dave500 »
Offline trueblue
« Reply #5 on: April 20, 2013, 04:49:52 AM »
Those jaws should flip around so you can grab onto something bigger ;D
1979 CB650Z
« Reply #6 on: April 20, 2013, 04:56:35 AM »
yeah thanks true i looked at that,,they have grub screws holding them in,,its like some kind of watch makers/jewellers lathe?
Offline trueblue
« Reply #7 on: April 20, 2013, 04:57:29 AM »
I still wouldn't say no to it ;D
1979 CB650Z
« Reply #8 on: April 20, 2013, 05:02:40 AM »
That is a beautiful  little lathe, Dave. (which rhymes, incidentally) As Blue mentioned, the jaws will probably reverse, in which case it'll probably be big enough for other stuff, but I'm guessing that is a special "Modeller's Lathe", which were very popular 50 or 60 years ago, so don't try to machine anything too big, like a new stainless swingarm pivot. Very nice piece of kit mate, you're a lucky boy. Cheers, Terry. ;D
« Reply #9 on: April 20, 2013, 05:02:56 AM »
yeah i like its precision,i need to get a new belt,it snapped after a few seconds of running,i tried to re do its join,its a leather loop with like a half a staple as the joiner,its all crumbly so ill get a new rubber or whatever one.
« Reply #10 on: April 20, 2013, 05:05:29 AM »
Yeah, get a whatever belt mate, they fit all lathes! ;D
Offline trueblue
« Reply #11 on: April 20, 2013, 05:10:13 AM »
You should still be able to pick up a new leather belt for it.  It is a very nice looking piece of equipment, but I wouldn't go trying to peel a 0.080" cut off something with it.  Anything you do with it will have to be done very gently, I would be very suprised if it could do any more than a 0.010" cut.
1979 CB650Z
« Reply #12 on: April 20, 2013, 05:52:04 AM »
yeah i hear you true blue,i realise itll,only skim off whatever its cutting,i sort of picture bronze bushings only on this rig?
Offline trueblue
« Reply #13 on: April 20, 2013, 06:07:43 AM »
Bronze, brass, copper and aluminium is all I would realistically expect it to cut.  You may be able to get away with mild steel but it would only be really small cuts, I would expect 0.005" at the most.  You will have to use HSS tools, I wouldn't even contemplate using carbide tips, they are too blunt.
1979 CB650Z
« Reply #14 on: April 20, 2013, 06:11:05 AM »
youve just dashed all my visions of repro front forks,and also astra starter motors.
Offline trueblue
« Reply #15 on: April 20, 2013, 06:25:19 AM »
You could do it, it would just take you a while ;D.  Also last week I would have happily given that #$%*ing car away.  The lathe I used for the starter motor spacer is a bloody nice unit, 105mm through the headstock, 3 metres between the centres, and 18" swing over bed.  It also has a digital readout which reads to 0.00001" but in reality only accurate to 0.0005", mind you being realistic about it you can't expect to be any more accurate than that ;D.  Oh and it can peel 0.1" cuts off with ease ;D.
1979 CB650Z
Offline Killer Canary
  • Typical Bran Muffin
« Reply #16 on: April 20, 2013, 08:24:43 AM »
Yikes!
Kawi GPz900, H1
« Reply #17 on: April 20, 2013, 08:28:05 AM »
Get into the hobby business, Dave.You could machine all scales of brass machine gun/ cannon barrels easily with that.
Kawi GPz900, H1
« Reply #18 on: April 20, 2013, 09:01:32 AM »
McmasterCarr carries belts and lacing. I was able to shorten my logan's belt and reuse the lacing.
« Reply #19 on: April 23, 2013, 07:46:39 PM »
Bronze is way harder to cut than mild or leaded steel..
Offline kghost
« Reply #20 on: April 23, 2013, 08:48:10 PM »
I'm going to have to stop by and see it lol
Stranger in a strange land
« Reply #21 on: April 23, 2013, 08:49:59 PM »
They are a dedicated watchmakers lathe Terry, did a bit of research for Dave when he got it, awesome little thing. There are a few You Tube vids on how to set up and use it. One of the video's shows a guy machining brass... ;)  You need to get that other box that goes with it Dave.... ;)
« Reply #22 on: April 23, 2013, 08:50:25 PM »
This weekend Tim..?
« Reply #23 on: April 23, 2013, 09:34:01 PM »
That is a nifty little lathe! I've never seen anything quite like it, but my first thoughts were watch making. Odd tail-stock...
« Reply #24 on: April 23, 2013, 11:12:18 PM »
i picked up all the other stuff for it,a tiny dual action dial scale for like tiny springs,quite a few cutting tools,small whitworth and ba taps,some tiny reamers,collets and the tool post and a tool rest with two rests similar to a wood lathe.
so i quickly knocked up this vintage seiko sports 100 with it.
heres how they came boxed when new if you scroll down,mine might be 40s or 50s with the improved drive head?
http://www.lathes.co.uk/lorchtriumph/
« Last Edit: April 23, 2013, 11:17:01 PM by dave500 »
