Author Topic: Tews' 605 build, On the road! 5/4!  (Read 95449 times)
Offline MoMo
  • Ride like you're invisible
Re: Tews' 605 build, DAMN IT!!!! Head gasket cylinder failure
« Reply #525 on: March 26, 2015, 11:05:38 AM »
If the shifting problem is all gears, most likely the problem is clutch related.  Specific gears would be trans. And............oil type and viscosity does affect shifting.  I did not touch one of my bikes this past winter either...Larry
Offline Old Scrambler
« Reply #526 on: March 26, 2015, 11:21:42 AM »
Note the battery-powered tool...............Two garage buildings have burned/exploded a few miles from me over this past winter (will it ever end?) caused by spilled fuel and/or fumes that were ignited by the electrical discharge of a battery-powered shop tool.  If your tool shows a flash when you release the trigger...........be warned.
Tews............your getting some great advice............
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Online Stev-o
« Reply #527 on: March 26, 2015, 04:41:06 PM »
Offline Trad
« Reply #528 on: March 26, 2015, 06:27:01 PM »
Tews,
Did you remove the baffle on your MotoGP pipe?
74 CB550 Build: NOS-GUTTED-OEMplus-HOLDTRUE
http://forums.sohc4.net/index.php/topic,130575.0.html
Offline Tews19
  • I am no
« Reply #529 on: March 26, 2015, 07:03:11 PM »
Tews,
I did not.
1970 Honda CB750 survivor.
Offline Trad
« Reply #530 on: March 26, 2015, 08:18:02 PM »
Tews,
I did not.
So it's in there or you got the older pipe without the baffle? I should have been more clear. haha.
Offline Tews19
  • I am no
« Reply #531 on: March 26, 2015, 08:20:45 PM »
No I have a baffle. I didn't take it out. I left it in.
Offline Mcwilliams570
« Reply #532 on: March 27, 2015, 01:01:49 AM »
That headlight shell looks really special..:)
My CB550 project http://forums.sohc4.net/index.php?topic=101182.0
Project UFB Cb550 http://forums.sohc4.net/index.php?topic=112143.0
Like a 10 dollar hooker on Friday night its going to be ridden.
1974 cb550
1975 cb550
2005 vmax
2009 vmax-sold
1981 gl500i
Offline Tews19
  • I am no
Re: Tews' 605 build, Progress!
« Reply #533 on: April 12, 2015, 10:20:49 AM »
The lower engine is back together. I find it funny yet I have a "glad I tore it apart moment". There are 2 dowels that go into the case where the main gear thing is and another in the other area. Not to accurate on the description but anyways when I put the engine together I didn't install. This time I did. Lower end is all buttoned up and this week I should get to the rest.
I also installed the new cam chain. The original was so stretched. Really shocking how much it was.
Goal is to have the engine done by Friday. Hopefully riding on Sunday...
« Last Edit: April 12, 2015, 10:33:17 AM by Tews19 »
« Reply #534 on: April 12, 2015, 10:59:14 AM »
That'll give you some peace of mind!
Offline Tews19
  • I am no
Re: Tews' 605 build, More progress! 4/17!
« Reply #535 on: April 17, 2015, 06:57:37 PM »
Got to assemble the engine a little more today. My cam has some pitting as I posted on another thread. I'm really contemplating running it for the summer. Then spend some big bucks on new rockers and a brand new cam. Here is how the engine site today.
« Last Edit: April 17, 2015, 07:00:04 PM by Tews19 »
Offline Tews19
  • I am no
« Reply #536 on: April 24, 2015, 06:17:06 PM »
Engine was delivered to my house yesterday.  My buddy Mike who has been helping rebuild the engine helped me get it in the frame. 2 people  installation is much easier and less time consuming then taking the bike down to the frame. Adjusted valves and the cam chain. Buttoned up everything minus the carbs. I need to drop the needles on the carbs, order a battery and clean out the tank.  Then it's on to riding!
#$%*ty garage pic but it's late.
« Last Edit: April 24, 2015, 06:23:13 PM by Tews19 »
Online Stev-o
Re: Tews' 605 build, The home stretch. 4/24
« Reply #537 on: April 24, 2015, 06:59:47 PM »
Congrats, that's a milestone.  Motor looks good with the polished bits.
Offline Trad
« Reply #538 on: April 24, 2015, 08:21:27 PM »
The engine looks fantastic. Love the colour the pipe turns after some heat cycles. Just beautiful.
Offline hellraiserDLX
« Reply #539 on: April 24, 2015, 09:03:19 PM »
i believe those are all actually chromed covers. They look great iN person
« Reply #540 on: April 24, 2015, 10:18:02 PM »
Looks great.
Offline Tews19
  • I am no
« Reply #541 on: April 25, 2015, 04:20:20 AM »
That was the color they turned from being ceramic coated internally, Trad. They may not turn much further now, but it will be interesting to see the effect of it after some time.
Cal, it's 4am when you posted! Do you ever sleep? You are a machine.
Online Stev-o
« Reply #542 on: April 25, 2015, 06:08:41 AM »
And you at 4:20.   You have it running yet?!
Offline Tews19
  • I am no
« Reply #543 on: April 25, 2015, 05:24:25 PM »
Not running. Youngest boy had wrestling.
Offline Tews19
  • I am no
« Reply #544 on: April 26, 2015, 05:07:24 PM »
This will be my last post prior to completion. Dropped the needles in the carbs to 4th notch. Installed carbs, airbox.  Installed the 77 550 speedo and a 650 tach. My engine is installed but I am wondering if I remove my tach plug am I able to install the 650 tach gear into the engine or does the engine need the valve cover off?
Lastly I will have to run the spare tank until I coat the original tank with Caswell tank liner.
Here are my 2 tanks.
Offline brandEn
Re: Tews' 605 build, pics of the tanks. 4/26
« Reply #545 on: April 26, 2015, 05:24:00 PM »
Orange for the win! :)
« Reply #546 on: April 26, 2015, 05:29:16 PM »
bummer dude...both those tanks look so #$%*ty...jk
Offline Tews19
  • I am no
« Reply #547 on: April 26, 2015, 06:52:05 PM »
Lol, Sean the tank with decals has a bunch of pin holes. The other one has scratches but those should buff out.
Thanks Cal! Once again your wisdom is much appreciated here.
« Reply #548 on: April 30, 2015, 09:11:31 PM »
Ok. Enough with the grab-a$$.   ;D  Wire that bad boy and let's see it run!!
Offline Tews19
  • I am no
« Reply #549 on: April 30, 2015, 09:19:56 PM »
I have a video of its first start up. Downloaded on Google drive. I can't post it on here through that.
