Author Topic: 1st gear, 2nd gear, 3rd gear POP, POOSHH, WHINNNGRRRR!!!! (Motor kaput!) pics  (Read 4545 times)
Offline timdhawk
  • 1978 CB750K
Pulled the motor, opened her up and found this: a broken ARP stud without the nut:
And this spoke to me in a bad way:
A beautiful collection of WTF leftovers:
Do you think this is bad...?
So, seriously... WTF happened? I found the nut from the broken ARP stud in the bottom with all the chain mess, and its chewed to hell. 488 miles after total rebuild! Damn...
In deeper than I should be...
Offline reddyvv
Damn, that's terrible. Sorry for your loss. Looks like the nut and stud remnant got stuck between the cam chain and sprocket or jammed the camshaft somehow causing it to lock and blow up in spectacular fashion.
Did you put those studs in when you did the rebuild? Didn't overtorque them did you? If not some metallurgical issue (wasn't hardened properly?) since that needle point looks like a typical bolt separation from overtightening or weak metal.
« Last Edit: August 12, 2013, 05:03:11 PM by reddyvv »
Offline timdhawk
  • 1978 CB750K
I guess its possible but I did take my time on the torqueing since it was my first 750 rebuild. But how would the nut be separate from the broken stud? See 1st pic - the broken stud end is to the left of the stud and the nut was down in the case..
Offline Nikkisixx
I would expect the aluminum threads in the case to pull out before the stud could be over torqued.  How did you thread them into the case (double nut, pliers, hands of steel)?
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
Sorry dude! That must have sounded horrible!  :'(
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
Offline reddyvv
I would agree and I am wondering if a stud made it through QC without get hardened. Or a flaw in the metal? It would be interesting if someone could suggest how to check the hardness on that stud.
Overtightening a double nut enough to stretch the bolt before screwing it into the case could be possible but, man you'd have to be strong.
Once the stud stretches enough that there is no longer any tension on the nut, or the stud breaks off, the nut will just vibrate itself off the stud.
« Last Edit: August 12, 2013, 07:15:34 PM by reddyvv »
Offline trueblue
Ouch, talk about a spanner in the works :o
It could just be an optical delusion, but that stud looks like it has been waisted just below the break point, this would point to it being too tight or the stud is too weak.
1979 CB650Z
Online PeWe
Heavy Duty cylinder stud that snapped?
I snapped one when torquing the head just under the nut as yours. I hope the other ones will not snap when driving.
Just open the engine completely again, clean it, maybe new bearings and other parts on the list as well :-\
Offline Nikkisixx
The shape of that break is typical of tension failure. What is not typical (but not unheard of) is that the break is that far above the flange surface, and would have occurred halfway inside the nut.  PeWe described a more common failure: under the nut.  Breaking inside the nut leads me to believe there was a stress riser (a nick or cut) on the stud at that point prior to installation.  Is the stud loose, has it backed out?
Offline trueblue
There is no washer there, so it would probably would have been just under the nut ;)
1979 CB650Z
Man that sucks, looks like it took out a lot of other parts.. Is that a stock cam ?
Offline Magilla
  • My bike: 1976 CB750F
I was feeling bad because I broke the left front fork on my Norton last week.  Now I see that I don't have it so bad.
That is a catastrophic failure in epic proportions.  Did it happen on the break in ride?  What RPM range were you in when it detonated?
1972   Honda CB350
1972   Yamaha 500
1982   Yamaha 650
1988   Harley Sportster 883
1983   HD FXR Shovelhead
2003   HD Heritage Softail
2006   Victory Vegas Jackpot
1980   Honda CB650
1976   Honda CB750K
1982   Honda CB750
1964   Honda CA95
1982   Kawasaki 550
1974   Honda CL360
1975   Suzuki GT550
1981   Honda CB750
1981   Honda CB750
1970   Norton Commando
1972   Yamaha U7E
1970   BMW R50/5
1976   Honda CB750F
If that cam stopped whilst the crank was turning you also have bent valves mate
Offline Vinhead1957
Total top end rebuild and hopefully it didn't hurt the gear on the crank
Painful to watch!
What was the timeline?  The first ride or how many miles since rebuild did it happen?
Not just topend, tore up a primary chain..
Offline CrankyOldGuy
  • Wish I was a
I am just curious but in the second picture in the original post is that the end of a sparkplug that is visible through the remaining hole in the cam shaft sprocket?  If so, there must be more damage to the underside of the head.  It's been 35+ years since I had my 750 apart so I could be wrong.
HarrY O.
750 K1 Original Owner
There were some reports of broken "Heavy Duty" studs 2-3 years ago...
http://forums.sohc4.net/index.php?topic=77878.0
Online PeWe
timdhawk
Do you know how much torque that was used on these studs?
The damage on photo might include crank (sprockets for prim, cam chains). Cracks in cases too?
Any other known expensive HD stud case as this one?
Offline timdhawk
  • 1978 CB750K
Ya know... I had a vague recollection that an HD stud had snapped on me once before when putting this motor back together... I was right:
http://forums.sohc4.net/index.php?topic=82414.msg926653#msg926653
Not the exact same stud, but from the same parts seller...
Online PeWe
My stud snapped at the same torque as you have described in your thread... after torquing the first 10 head nuts to 21 ft/lbs per recommendation, #11 snapped before hitting the torque "click".
So, I have to take out the engine again and replace all other studs too?
I bought a complete new set when one snapped, replaced the broken one only. All studs tightened to 21ftlbs first time. Now18ftlbs only after the failure when one stud was replaced together with new head gasket. 24 hours later all nuts retightened one by one by unscrewing each nut 1/4 turn followed by retorque to 18 again, from center going outwards as head should be done. I marked some nuts to verify, nuts moved appr 2mm on the outer radius.
It must be a fabrication failure. In my world studs like these are manufactured in batches where a number of samples are tested to verify when stretch and snapping. It cannot been done here.
- The stud that snapped for me felt soft much earlier than the snapping moment, maybe around 15-18. Same for you?
You torqued them all to 21 2:nd time too?
EDIT: IN your old thread the studs look a littbe bit strange.
Are they mounted upside down with the longer thread upwards? Should be into the case if I recall correctly. I have pics of my stud failure home, long way from where I'm now.
« Last Edit: August 15, 2013, 12:41:13 AM by PeWe »
