Author Topic: Cafe Brat alloy seat fabrication with no frame mods  (Read 4042 times)
Offline Rigid
  • She likes a
    • KingCustomCycles
« on: September 01, 2013, 06:21:57 AM »
Wanted a cool brat seat, but no frame mods on my 77 CB750.  This is what I fabed up.  Now off to the upholsterer.
(using tab in front under tank rubber and two tabs in back where fender attached to secure.)
« Last Edit: September 01, 2013, 02:02:53 PM by Rigid »
Re: Cafe Brat alloy seat fabrication with no frame mods
« Reply #1 on: September 01, 2013, 06:25:48 AM »
You should post a pic of the butt side also  ;)   NOT yours but the seat  :D
Offline 750K
« Reply #2 on: September 01, 2013, 09:09:49 AM »
Yes, let's see more pics. Of it on the bike especially, mounting it with stock hinges and lock as well?
77 Cb750, 78 Kz1000
Offline lucky
« Reply #3 on: September 02, 2013, 12:26:05 PM »
I hate that name "Brat style" Did some rich brat think that up or what??? ;D
Its a Cafe, Bobber, Street Fighter, or Street Tracker. Isn't that enough? Cheeeeesssshhhh!!!
« Last Edit: September 02, 2013, 12:28:48 PM by lucky »
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
« Reply #4 on: September 02, 2013, 12:59:18 PM »
Interesting. What do you intend to do with the tail/fender/lights?
Build threads:
1977 CB750 F2
1958 Norton Model 99
Offline Rigid
  • She likes a
    • KingCustomCycles
« Reply #5 on: September 02, 2013, 04:25:10 PM »
Probably a cateye with a small black fairing to blend the light and the original fender side mounts.  Anybody can cut a frame and stick a hoop on.  The challenge was to have a clean look with no frame mods.  These sohc bikes are getting harder to find so preserving the frame was important.
Offline nccb
  • 1974 CB750 Four
« Reply #6 on: September 02, 2013, 04:30:02 PM »
That looks real good.  I am interested in some of the finishing pictures when you get the rear end together more.
Offline Tews19
  • I am no
« Reply #7 on: September 02, 2013, 05:20:06 PM »
Nice job Rigid... Looks really clean and well made
1970 Honda CB750 survivor.
Offline KrautKoffin
« Reply #8 on: September 02, 2013, 07:35:42 PM »
 ::) this cracks me up
74 cb550
I now have Beastie Boys "Sabotage" stuck in my head after seeing your avatar.
« Reply #9 on: September 03, 2013, 03:41:37 AM »
Using regular Joann's Fabric foam?  Looking good!
I know somebody who used carpet padding in layers on a rebuilt seat - it was for Jawa from sixties.
Offline Geeto67
  • A grumpy
« Reply #10 on: September 03, 2013, 08:26:36 AM »
it is replacing where the inner fender goes. Did you check for clearance? if not, you might want to unless a tire hitting you in the ass at full compression is your idea of fun.
Maintenance Matters Most
« Reply #11 on: September 03, 2013, 08:29:19 AM »
Its above that.
Offline Geeto67
  • A grumpy
« Reply #12 on: September 03, 2013, 01:08:14 PM »
it's sort of above that. where the seat mounts in the rear is the topside of the mount, the inner fender uses the bottom side. Chances are it will probably clear, but too many people build these seats without ever checking for impact through all suspension travel so I thought I would bring it up.
Offline KrautKoffin
« Reply #13 on: September 03, 2013, 01:57:57 PM »
What's your upholsterer charging you to line it?
74 cb550
Offline lucky
« Reply #14 on: September 03, 2013, 02:02:26 PM »
Good thing to mention too.
Offline dusterdude
« Reply #15 on: September 03, 2013, 02:51:58 PM »
Very cool,what gauge aluminum did you use?
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline Rigid
  • She likes a
    • KingCustomCycles
« Reply #16 on: September 03, 2013, 03:55:10 PM »
.060 2024-T3, going to have rigid struts so suspension travel will be nil, and finally, about $125. to get it skinned,  Thanks guys. :-)
Offline SKTP
« Reply #17 on: September 03, 2013, 03:56:27 PM »
It's going to look really good
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline dusterdude
« Reply #18 on: September 03, 2013, 04:17:49 PM »
Good deal,thanks dude
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline wowbagger
  • Not much of an
« Reply #19 on: September 03, 2013, 04:58:29 PM »
Yeah, I'm interested to see how this finishes as well. I've been looking for a way to get a smaller seat on my bike while keeping the stock rear fender. This might just do it.
Offline KrautKoffin
« Reply #20 on: September 03, 2013, 06:05:47 PM »
I like the idea of keeping the stock pan
74 cb550
Offline wowbagger
  • Not much of an
« Reply #21 on: September 03, 2013, 06:41:46 PM »
This is the best "brat-ish" seat made on a stock pan that I've seen so far: http://forums.sohc4.net/index.php?topic=91241.0
Offline pjwalsh
« Reply #22 on: February 23, 2014, 12:36:44 PM »
Hey Rigid,
I've been racking my brain to figure out something like this seat mod, I like it!
I'm in the same mind set about not chopping the frame, can you please post some more pics of the seat, what you do with the pan, hinges and latch etc!
Thanks,
Pat
