Author Topic: 71 CB 750 build  (Read 19243 times)
Offline ogsmakdade
  • bike newb
Re: 71 CB 750 cafe build
« Reply #25 on: August 11, 2014, 07:51:22 PM »
I installed the front tire myself but the tube wouldn't hold air, I must have pinched it during the installation.  Rather than fighting it, I took the wheels to the local honda dealer and let them mount and balance the tires.  painted the wheels because they were pretty rough.  installed the new brake pads and shoes.  Surprisingly everything works well, not bad for a bike newb.
painted wheel pics w/ new tires!
whole again
« Last Edit: August 14, 2014, 05:56:01 PM by ogsmakdade »
Everyone thinks Chuck Norris is bad, but Chuck Norris has not meet Lucky either.  Lucky will round house kick Chuck back to 1969 and pop a wheel with the 1st sandcast while shotgunning a PBR!
My "build" http://forums.sohc4.net/index.php?topic=126537.0
Offline Ravie
  • Definitely not a
  • Soul to Soul
« Reply #26 on: August 12, 2014, 08:37:04 AM »
Lookin Good. I bet those drag pipes deafen you slightly. lol
1975 CB750K5 Rebuild in progress.
http://forums.sohc4.net/index.php?topic=139072.0
Offline ogsmakdade
  • bike newb
« Reply #27 on: August 14, 2014, 01:12:58 PM »
thanks.  ;D
I have a really nice helmet that cuts down the sound from the pipes.  I'll admit it is quite loud, but tolerable.   I didn't want to destroy my HM341's so I took them off and wrapped them for storage.
Yesterday I met up with Larry, he walked me through a valve adjustment and carb sync on my bike.  Great to learn from someone who has years of experience and some great knowledge.  Thanks again Larry, you're the man!
« Last Edit: August 14, 2014, 05:59:56 PM by ogsmakdade »
Offline ogsmakdade
  • bike newb
« Reply #28 on: December 27, 2015, 06:24:15 AM »
Still riding and enjoying this bike, oil leaks, rust and all!  I haven't done much to it since the last mods I posted.
I have to finish the second side cover mod.  Pull dents on the replacement tank, and braze a small hole I discovered.  I have a painter lined up to spray the parts, custom color going on.  Going to have the headlight bucket and fork ears sprayed as well, proper for a ,71.
Picked up an 09 CB750 recently that I'm working on, and still wrenching on preludes.  Hope to have the cbr on the road by spring and a supercharger installed on my Lude.  If time permits, maybe I'll have freshly painted parts on the CB in 2016
Offline ogsmakdade
  • bike newb
Re: 71 CB 750 build
« Reply #29 on: August 04, 2016, 08:08:22 PM »
Got rear ended on the bike today.  Pics to come.
Re: 71 CB 750 build
« Reply #30 on: August 04, 2016, 09:01:13 PM »
Crap!  Waiting at a light?
Offline ogsmakdade
  • bike newb
Re: 71 CB 750 build
« Reply #31 on: August 05, 2016, 04:43:32 AM »
Yup.
Luckily I had my leatherman multi tool, I removed the fender/tail light/plate/ turns (or what was left of them)
I was able to ride the bike, the cop followed me to my shop to be safe.
How she sits.
My buddy Larry has offered up some spare parts, I'll use those for inspection purposes.  I'm finally going to install the tail light assembly previously posted in this thread
« Last Edit: August 05, 2016, 04:54:03 AM by ogsmakdade »
Offline BARKER
  • Nova Scotia, Canada
    • Check out my YouTube Channel!
Re: 71 CB 750 build
« Reply #32 on: August 05, 2016, 05:50:07 AM »
I'm a big fan of the seat style you opted for. Looks comfy.
*On a side note... I'm kind of like you: Newish to bikes, not new to forums. My previous addiction were AE86 Corollas. Technically it's still my addiction as it is sitting next to my CB750 and my 450 Nighthawk.*
Anywho... Nice looking project!
My YouTube Channel (contains CB750 stuff!)
-1974 CB750K Project
-1987 Toyota AE86
Offline ogsmakdade
  • bike newb
Re: 71 CB 750 build
« Reply #33 on: August 05, 2016, 06:48:27 AM »
Thanks man.  Seat is pretty comfy.
I like those corollas, cool little cars.
Re: 71 CB 750 build
« Reply #34 on: August 05, 2016, 08:24:55 AM »
It appears that the damage was focused on your fender and taillight.  I assume that the car also struck your rear wheel.  Did the frame, swingarm or wheel suffer any damage from being pushed/plowed into?
Offline ogsmakdade
  • bike newb
Re: 71 CB 750 build
« Reply #35 on: August 05, 2016, 10:09:24 PM »
Hit the rear wheel pretty hard.  Not sure sure what is damaged, I'll likely take the bike to a shop to be evaluated for insurance purposes.  If this bike is totaled I'm gonna be pretty damn mad.
Re: 71 CB 750 build
« Reply #36 on: August 06, 2016, 08:21:32 AM »
It is incredibly easy to total a motorcycle, especially if it is a vintage bike not on stated value but just blue book.
If totaled, you should buy it back from the insurance company, purchase a clean titled frame and transplant all of your parts to the new frame.
Offline ogsmakdade
  • bike newb
Re: 71 CB 750 build
« Reply #37 on: August 06, 2016, 05:41:01 PM »
Understood.  I will likely buy it back, I'm pretty attached to this heap.
Offline ogsmakdade
  • bike newb
Re: 71 CB 750 build
« Reply #38 on: August 07, 2016, 10:36:25 AM »
If the rear wheel is struck, likely the rim is bent, and the swing arm pivot rod too. Replacing the rim is in order, but the spokes (unless they're broken) can be re-used. The pivot bolt is a bit of bugger. It would need replacement, and the bushings too should be replaced (maybe you did/didn't during your rebuild?). Obviously the bodywork and light fixture, but the "unseen" parts are critical for proper evaluation.
Thanks for the info.  Those are parts I didn't replace during my refresh of the bike.  I will push for a new rear wheel, tire swing arm, pivot bolt, bushings, fender, amid tail light.  They will want to total it, but I'll take what they give me and save the bike.
Offline pipeguy
Re: 71 CB 750 build
« Reply #39 on: August 07, 2016, 02:13:31 PM »
Good luck with your, hopefully it's not damaged to bad to affect the frame. I will be watching this project as I have same vision for my 73 that I will be working on, I was also thinking of black wheels...
1970 CB750 K0
1980 CBX
2001 Electra Glide
2013 CRF450R
2013 KX450F
1977 KH 400 triple (gone)
1973 CB750 K3 (waiting it's turn)
2000 KLR 650(gone)
2001 BMW 1200RS(gone)
2004 Busa limited(sadly gone)
2003 ZZR250 ninja(gone)
1996 VFR750(gone)
1974 RD350(really sadly gone)
Offline ogsmakdade
  • bike newb
Re: 71 CB 750 build
« Reply #40 on: August 07, 2016, 08:14:38 PM »
Thank you.  Can't wait to see your build get started.  These old bikes are addictive
