Author Topic: 1975 CB550 Winter 2013 Build  (Read 23731 times)
Offline Chaser60
  • 75 CB550
Re: 1975 CB550 Winter 2013 Build
« Reply #25 on: January 29, 2014, 06:18:04 PM »
Well a big milestone.   Tear down complete.  Dropped this group of parts off to powder coat.
Give or take 2 weeks.   Will have these back.  Plan is black, with not overly high gloss.   Trying to get close to original paint gloss.  Will post pics when the parts are back.
Offline Chaser60
  • 75 CB550
« Reply #26 on: January 29, 2014, 06:27:29 PM »
During last week have also been dealing with a mess in the fuel tank.   There is another thread in the SOHC /4 bikes section that details the process and before and afters.   Its posted there because some members had helped me out with suggestions.
Here is the before
And here is after....Summary  redkote liner by some PO.   MEK to dissolve, the Works to de rust, warm water and baking soda to neutralize acids.   Rinse then Acetone to absorb remaining water.   Looks way mo' better.  Thanks to all that have posted about the works and to others that helped me identify the original mess as red kote aged to badness.
Offline Chaser60
  • 75 CB550
« Reply #27 on: January 29, 2014, 06:38:45 PM »
Next up shock tear down...Well once again, Forum search function saved my ...   Of course, i had already taken shocks off the bike, unbolted the top nut, drained the oil  and THEN tried to take out the hex bolt at the bottom of fork.    Lots of PB blaster.   some heat and an hand held impact wrench and sure enough its loose, but of course as you all know, it is now spinning in the damper....So read about the broom handle trick...As a reformed wood worked, had lots of dowels around.   Held in the end and bolt now free.    New progressive springs and seals are to be ordered, but have lots of time polishing before re-assembly.
As you can guess, I was surprised when my insides didnt look like any of the diagrams in the manuals... PANIC setting in, but again, quick search here and seems the 550 fork damper changed to eliminate the long rod, but that little tid bit did not make it into the manuals.   All good again.
Offline Chaser60
  • 75 CB550
« Reply #28 on: January 29, 2014, 06:50:23 PM »
And while waiting for the tank to soak in nasty chems, took the rear wheel, tube, brakes and such off.  Have new wheel bearings so this friggin thing is the next issue.   I cant figure out exactly what is meant by drilling out the 4 stops.   Will research this some more, but am having fear of drilling too big, too deep and destroying something vital.   sorry this picture is blurred.  I just cant picture what I am drilling and what I am not drilling.
Next steps here once I get this thing off and the bearings out is to decide how to clean up the hub, and spokes.   I dont really want to unlace it, but I think that is going to be inevitable.    Also need to figure out if brakes need done.  They look ok, no scoring on drum inside, but does anyone know the thickness at which the shoes should be replaced and what are they when new so I can decide how much is worn?
Offline Pasoren
« Reply #29 on: February 01, 2014, 01:10:32 PM »
...and you are drilling why? Just pulled my rear and front bearings using something like this: http://t.harborfreight.com/automotive-motorcycle/pullers/blind-hole-bearing-puller-95987.html
Heat it up first with a heat gun or similar. You have to remove the retainers first.
But, first of all (if you don't already have it) get the parts list and workshop manual!
Online WhyNot2
  • I'm finally an
« Reply #30 on: February 01, 2014, 01:30:41 PM »
Watching......looks good so far.......loves them 550s, still looking for one myself.
Offline Chaser60
  • 75 CB550
« Reply #31 on: February 03, 2014, 06:12:01 AM »
Pasoren,
Thanks for tip.   The drilling was for the 4 small indents that prevent the retainer from turning out.   Once I finally got that free, I got the bearings out thanks again to tips here about moving the spacer over to get a lip for the end of a tool, plus a nice big hammer...  Will post pics later of a DIY tool that did not work for the retainer torque.
The front retainer (with the seal) is pretty beat up from the process so will have to go on line later today to see about availability.   Hopefully it is not some rare item made from that precious metal called unobtainium....I hate that stuff
Offline Chaser60
  • 75 CB550
« Reply #32 on: February 09, 2014, 06:13:21 PM »
Thanks Cal,  Will follow up when I pick up the PC parts as discussed via PM.
Been a busy week, not able to do much real work on this project.    However, did get the wheels unlaced.   Will polish up the hubs and rims.   Then will have to make decision on spokes.   Spokes are in pretty good shape, but after spending all day messing with polishing other parts, not sure I am going to tackle 80 spokes.
Hubs are in good shape and I am sure will polish up well if I can get my technique refined.  More on that later.
Front rim has light rust on inside.  It will clean up fine.   Rear is worse, but will try to clean that up too.   Will prime inside with rustoleum primer before assembly.   Have seen a few threads on that here.
Offline Chaser60
  • 75 CB550
« Reply #33 on: February 09, 2014, 06:29:26 PM »
Spent a good part of day polishing.   My first attempt at this.   Read a lot of good tips here and also on the caswell plating website.    That said, what a freaking mess polishing creates.   I wore goggles and face mask, but rest of my face looked like pictures I have seen of men coming out of coal mines !   I had hung tarps in my shop to keep dirt contained, but wow...
Any of you have any tips on how you keep yourself reasonably clean, I am all ears...
Anyways,   most of my parts are not deeply pitted, so only used wet n dry paper on a few.     Basic method was
Light sand with 400 or 600 only if needed,
Black compound on sisal wheel
Wipe down part or wash any residual black off the part
Brown compound on spiral sewn wheel
wipe down part or wash any residual brown off the part
White compound on loose cotton wheel.
Finish with mothers aluminum polish
Below are a few parts.   They are significantly improved, but not quite the mirror finish that I have seen some of you all acheive.
Front fork lowers came out better
As I said, this is my first attempt at this, so if anyone has ideas how to improve the results, I would love to hear them.
Plan to polish the hubs and a few bits on the engine, so lots of opportunity to get better...(and filthy)
Offline Chaser60
  • 75 CB550
« Reply #34 on: February 09, 2014, 06:39:28 PM »
So how many miles do sprockets and chains typically last?   I have no idea how old these are, but bike has about 8300 miles so I guess, that should be the max on these.    It looks to me like the 17 tooth has some wear and should be replaced.   The rear looks ok to me, but is hard to see in these pics.   Is it ok to replace only 1 of the 3 components (chain being the third obviously), or is this best to replace front, rear and chain as a set?
Offline KrautKoffin
« Reply #35 on: February 10, 2014, 10:43:29 PM »
If you replace one you'll prematurely wear it, replace all three and save yourself the hassle of doing it later.
74 cb550
I now have Beastie Boys "Sabotage" stuck in my head after seeing your avatar.
Offline Chaser60
  • 75 CB550
« Reply #36 on: February 27, 2014, 05:19:01 PM »
been away from this for a long while.  Too much going on.   But great news, picked up all the powder coated parts last week, so now I need to get going on engine paint and polishing, so I can start the re-assembly.   PC looks great and really helped clean it all up, especially the smaller parts.
Offline Chaser60
  • 75 CB550
« Reply #37 on: February 27, 2014, 05:30:33 PM »
Also heard from the guy doing my seat.   He is done and has pics for me.
here is a picture of the reshaped seat pan and green foam mock up that I sent him
here is the finished product.  I am a long ways and a lot of work from being ready to get it on the bike, but glad it is done and on its way back.
« Reply #38 on: February 27, 2014, 08:09:29 PM »
The seat looks good!!
Offline Chaser60
  • 75 CB550
« Reply #39 on: March 06, 2014, 03:03:54 PM »
I am all jacked up today.   Painter called and tins are done.   So of course I dropped everything and ran out to get them.
Here is the tank before...Rusted under seat line and several smaller dents on other side along top edge
And the after...
The front fender is one that I found damaged on ebay and I shortened it front and back before sending out to paint.
So of course I couldn't wait to try it on with the seat.   Color is a deep red pearl and does not really show that way in the pics
I had thought that by time I got frame parts back from powder, the seat back from cushion/cover fabrication and the tins back from paint, I would be ready to start build.  Sadly, I have so much work left, but wow do these make me want to get er DONE...
« Reply #40 on: March 06, 2014, 04:36:18 PM »
The paint and body work look solid.  I like the reshaped seat, too!
Offline Chaser60
  • 75 CB550
« Reply #41 on: March 30, 2014, 05:35:27 PM »
Its almost time to start putting this thing back together.   Polishing about done, parts bagged and tagged and done soaking in Evapo Rust ( this stuff has almost replaced vodka as my favorite liquid ).
Offline Chaser60
  • 75 CB550
« Reply #42 on: March 30, 2014, 05:39:17 PM »
Drilled the rotor today and installed the all balls wheel bearings in the rear hub.
Offline Chaser60
  • 75 CB550
« Reply #43 on: March 30, 2014, 05:44:35 PM »
Also pressed in the rear shock bushings.   Thanks to Hondaman advice to point out to press them from Inside to Out since the hole in swing arm is slightly tapered.   I just reversed the process I used to get them out.   1 bolt, 2 different size sockets and be sure to tape the socket that will touch the beautiful new powder coat.
Offline Chaser60
  • 75 CB550
« Reply #44 on: March 30, 2014, 05:57:10 PM »
And to officially kick off the rebuild, I also re-attached the VIN tag to the frame.   I used these drive rivets.  An old thread here identified them.  They worked perfectly.   I also used double sided carpet tape on the back of the vin tag so it is stuck down to the frame in addition to the rivets.
http://www.mcmaster.com/#91654a077/=bg3npl
Part Number: 91654A077
Nail Type: Easy-Drive
Easy-Drive Nail Type: For Sheet Metal, Plastic, and Plywood
Material: 18-8 Stainless Steel
Finish/Coating: Plain
Decimal Size: .100"
Number Size: No. 2
Head Type: Oval
Shank Type: Spiral
Head Diameter: .162"
Head Height: .069"
Recommended Hole Size (Drill No.): .086" (44)
Length: 1/4"
Box Quantity: 100
Specifications Met: Not Rated
Note: Length is measured from under the head.
Offline streak09
  • I don't know what im doing, but I'll do it anyway
« Reply #45 on: March 31, 2014, 01:35:06 PM »
You are moving along! The powdercoat, paint, and polishing looks great!
Offline Chaser60
  • 75 CB550
« Reply #46 on: April 12, 2014, 01:00:06 PM »
Completed the all balls steering stem bearing replacement.
Here is the lower stack.  I used the thin spacer.
Here is how it went on the stem
Used this cast pipe to smack it home.  Freezer for the stem.  Didnt bother to heat the bearing.  Went on easy
Ground the underside of the top nut flush and did not use the top seal.
Dont have a pic of that, but it all looks good.
Is the tightness of this last adjustment nut, done by feel only?  Does not seem to be torque spec. and everything I read seemed more focused on the install and spacers than proper tightness of this nut.
Offline Chaser60
  • 75 CB550
« Reply #47 on: April 12, 2014, 01:03:01 PM »
Re-installed engine into the frame today also.  Followed a truly detailed build thread by SohRon.   Made it easy.   Did the centerstand while at it and this job is way easier to do before the swing arm goes on.
Offline Chaser60
  • 75 CB550
« Reply #48 on: April 26, 2014, 05:39:04 AM »
Backing up a step or two...Found a great thread by grepper titled "yet another engine painting thread"  I was not planning a teardown of engine since it runs well (or at least it did before I started this).  So I followed his thread taking care about getting the polished parts and gaskets off first and completing all the clean up of the gasket surfaces so as not to scratch the painted motor.   I had also very carefully stripped old paint and oils with cleaner and ultimately with aircraft aluminum stripper.   Masked it all up, wiped it down with acetone, let that fully dry.  Shot it with duplicolor engine primer and then two light coats with duplicolor cast coat aluminum 500 degree engine paint.   into the foil lined box with a heat gun.   I didnt cut a hole in box for this because my heat gun can stand up on its end, so I just put it on the ground pointing at top of box.   i also cut a flap in the box so I could open or close it to regulate heat.   On high setting, heat gun produces 200 in the box with no issue.   Cured it for 60 to 90 minutes and its hard as can be.   Time will tell how it holds up, but it looks way better than it did before the paint job.  Local hardware store that sells grills was happy to give me a box.   Used staple gun to tack in the aluminum foil.   This all was pretty slick.  THANKS GREPPER !!
Will remove cylinder cover and oil filter cover to paint those separately later.  While at this also dressed the rims inside with rustoleum after cleaning up the rust on inner surface
Offline Chaser60
  • 75 CB550
« Reply #49 on: April 26, 2014, 05:44:27 AM »
My bible for this re-assembly is the crazy detailed and helpful thread that was done by SohRon.   I also used the bubble wrap trick to protect the powder coat on the frame.  Worked and engine is now installed.
