Author Topic: Drag Bike / The Big 4 Express.  (Read 81052 times)
Online Don R
Re: Drag Bike / The Big 4 Express.
« Reply #600 on: November 22, 2025, 11:33:09 PM »
 Nope. This stroker engine used to go bar hopping, street riding and ran within .02 of whatever NHRA had for its class record. Sounds good enough to me.
  I bought a set of used Italian Weber faceplates tonight on ebay. They will look a lot better than mine and are in the US already. Mine have peeling chrome and were sanded smooth so no numbers were there, not that the numbers matter.
 They appear to be painted or vapor honed, I'm going to guess paint.
« Last Edit: November 22, 2025, 11:38:44 PM by Don R »
« Reply #601 on: November 23, 2025, 06:43:05 AM »
Cool stuff!
Online Don R
« Reply #602 on: November 25, 2025, 05:32:52 PM »
 Google says my new to me when they arrive carb tops may have come on an Alpha Romeo Guilietta Veloce. Pretty fancy for an old SOHC Japan bike L0L!
Online Don R
« Reply #603 on: November 26, 2025, 04:35:04 PM »
 I blended the turbo drag bike into this thread, tonight I rolled out the engine that has the future 997cc crankcase and the mocked up turbo on it. I made a strut to hold up the back of the turbo, that way it doesn't hang off of the header and the carb rubbers.
 I'm subscribing to David Freiberger's motto, don't get it right, just get it running. In light of that I'm putting a stock K5 motor with an F2 cam into the raked "other Egli" frame and hanging the turbo onto it. The rocker cover can come off in the frame so I can work on it later.
 The hard part will be getting the rolling frame off of the shelf in the shop.
« Reply #604 on: November 27, 2025, 01:11:01 AM »
You need a pair of long ramps
Online Don R
« Reply #605 on: November 28, 2025, 01:10:35 PM »
 I put it up there a few weeks after my hernia surgery, not a wise decision.
« Reply #606 on: November 29, 2025, 12:41:15 AM »
Possibly mount a small electric winch w/ a roller plate on a rail which heads out toward the big door.
Online Don R
« Reply #607 on: November 29, 2025, 09:34:38 AM »
 It will for sure come down easier than it went up, the issue was that the chain hoist's hook hangs down a foot or so and the bike almost touches the ceiling. Creative rigging is required but I put a pair of 20,000 lb chillers into the basement of a hospital once so this is easy as pie.
« Reply #608 on: November 29, 2025, 09:57:19 AM »
A small electric winch is powerful,and it should pull-up tight to the ceiling w/o the hook hanging down too far;it will be slower than a chain hoist.
Online Don R
« Reply #609 on: November 30, 2025, 08:53:43 PM »
 These Webers were for the Big 4 express stroker motor, the faceplates were chromed and nasty, I spotted a pair of nicer ones on ebay. new/old. I painted the mount plates, and plan to get new rubber biscuits to go to the frame tabs.
« Last Edit: November 30, 2025, 08:56:50 PM by Don R »
« Reply #610 on: November 30, 2025, 10:57:40 PM »
Look Good.
Online Don R
« Reply #611 on: November 30, 2025, 11:04:57 PM »
 Thanks, I think the screens on the air filters need to be black. I straightened them as good as I could when I made the new foam filters.
« Reply #612 on: December 01, 2025, 07:06:05 AM »
Do the Webers make a big performance difference?
Online Don R
« Reply #613 on: December 01, 2025, 09:36:54 AM »
I honestly doubt that they work much better than a good set of Mikunis but the cool factor is off the chart. They are heavy, but are extremely tunable. I've followed the proven jet and air bleed thinking posted on here.
 Carbs from an Alpha Romeo have to be cool, right?
« Reply #614 on: December 01, 2025, 09:44:58 AM »
Those a Very Cool.
Offline Tintop
« Reply #615 on: December 02, 2025, 05:44:57 AM »
Besides their overall tunability, the biggest advantage is the acelerator pump.  Zero flat spots when working right.  They made my sidecar a bear out of courners.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Online Don R
« Reply #616 on: December 02, 2025, 10:19:35 AM »
 I'm going to have to slap them on a good running test bike. I may need to hang them from a couple of zip ties to avoid bending the airbox tabs though.
 I had a few minutes in the shop and made up a new set of fuel hoses with a brass tee and slip over spring clamps. Not sure why but it's for a single outlet petcock.
« Last Edit: December 02, 2025, 04:34:40 PM by Don R »
Online BenelliSEI
« Reply #617 on: December 03, 2025, 04:54:57 PM »
No question, side draft, DCOE Webers are the most beautiful carbs ever made! Solex produced a virtual knock off, but not the real deal! The Orient Express drag bike I picked up many years ago came with a set and I wish I’d never parted with them!
Online Don R
« Reply #618 on: December 03, 2025, 05:12:57 PM »
 The Orient express bikes were well known, as far as I know they are still selling parts. I was going to order my 36 mm flatslide Mikuni's there but they were out of stock.
Online BenelliSEI
« Reply #619 on: December 03, 2025, 05:26:27 PM »
That bike came from their shop around ‘76.
« Reply #620 on: December 04, 2025, 09:13:08 AM »
Weber carbs are known to be really good.
They look good too.
Weber DCOE 40 kits for CB750 still available at an Australian shop.
Fuel injection might be maintenance free except for all sensors that will suddenly stop the fun.
There are fuel injection in weber copy bodies
https://silodrome.com/jenvey-heritage-dcoe-throttle-bodies/
Weber porn. Why not a carbed  car with electronic ignition, no cat nor oxygen sensors. Manual choke. ;D
« Last Edit: December 04, 2025, 09:16:28 AM by PeWe »
Online Don R
« Reply #621 on: December 04, 2025, 10:31:53 AM »
 I've always loved the look of that V8 set, that efi that mimics the Weber carbs look is pretty cool too.
 I saw a set of 3-barrel Webers for sale, it was hard to resist buying them just to put them on a 6-cylinder Goldwing that I don't even own yet.
