Author Topic: CB750K2 Bionic Mongrel Build  (Read 124197 times)
Re: CB750K2 Bionic Mongrel Build
« Reply #75 on: February 05, 2014, 05:51:58 PM »
Okay, I'm set to receive my oil tank/fender and seat tomorrow, but Ian sent me some preview photos mocked up on a roller he has with a SS tank. Anyway, this will give an idea of how the seat and oil tank/fender will go together.
« Reply #76 on: February 06, 2014, 03:23:00 PM »
Scrump-dilly-icious! Putting down the Viagra and taking the tablet to bed with me...
Thanks Cal.
Now, if the damn postal service employee would actually deliver my box with the aluminum parts, I'd be much happier!!  I don't know why, but the carrier on my work route sometimes skips deliverying our building altogether, and when I check on the tracking it says "notice left" when we were never closed!   :o
« Last Edit: February 06, 2014, 03:25:19 PM by CB750 Cafe Racer Fan »
Offline snowman
« Reply #77 on: February 06, 2014, 04:23:51 PM »
Looking great, just think when you get the packages it'll feel like Christmas all over again.
Sent from my iPad using Tapatalk
« Reply #78 on: February 07, 2014, 09:33:43 AM »
Christmas came yesterday late in the day!  I got the seat and oil tank/fender in our mail delivery.  Not only do the parts look amazing, they are so LIGHT.
I'm taking them over to the shop on Saturday so the frame can be mocked up for mounting points (for the tank, seat, steering damper), detabbed, gusseted, etc., along with the cutting and installation of the Gordon frame kit.  Now, I feel like this project can start moving along!
« Reply #79 on: February 07, 2014, 10:48:31 AM »
No pics!?!?
Sadly, not yet.  The box was delivered to my office, so I checked out the goods and took them home.  Since it was raining and dark, I didn't take any pictures.
« Last Edit: March 03, 2014, 10:52:09 AM by CB750 Cafe Racer Fan »
Offline sethdhawkins
« Reply #80 on: March 03, 2014, 04:52:01 PM »
Wow, just wow. I thought I went overboard on my build.  Do yourself a favor and don't add it up at the end ;)
I slid my oil tank in the fwd part of the triangle, but it's being made a little bigger, and out of aluminum (I can't TIG weld).
fastfromthepast.com has a wonderful assortment of fork clamps for steering dampers, if you're going that route. A top triple mounted damper, with all the anodizing stripped off, then polished, would look the tits up there IMHO.
I look forward to the updates.
All a man needs in this world is someone to love, if you can't give him that, give him hope, if you can't give him hope...just give him something to do!
1972-ish CB750K
1974 CB450
1974 CB360
1976 136' Ocean Going Tug
Offline timbo750
« Reply #81 on: March 03, 2014, 05:51:32 PM »
I had a look at fastfromthepast but there is no listing for early 750k. Have you orderdd one or is there another model that fits?
Project 1 CB750 - http//forums.sohc4.net/index.php?topic=126864
« Reply #82 on: March 03, 2014, 06:49:11 PM »
I haven't finalized where I want to mount a steering damper, but I'm leaning toward mounting it to the upper fork OR the lower triple tree (to the frame).  I have an Ohlins steering damper that I picked up nearly brand new from eBay.
« Reply #83 on: March 03, 2014, 08:11:48 PM »
http://www.fastfromthepast.com/servlet/the-2104/Fork-Tube-Clamp-35mm/Detail
1972-ish CB750K
1974 CB450
1974 CB360
« Reply #84 on: March 03, 2014, 08:15:23 PM »
I like your oil tank.  Both you and Tsunami have similar tanks.
« Reply #85 on: March 03, 2014, 08:23:03 PM »
I mounted it farther aft, so I could tack the battery on between the frame rails. This gives me the option to run two different seats; one a bump stop, and one a comfy touring seat. I'm adding an oil cooler and adding to the oil tanks overall dimensions. I figured my 836 should have more oil capacity, not less, than stock. Have you decided on a carb yet?
1972-ish CB750K
1974 CB450
1974 CB360
« Reply #86 on: March 03, 2014, 08:32:26 PM »
I'm going to run a Setrab oil cooler up front.  Between the tank, oil lines and the cooler, the oil should run significantly cooler.
I'm still undecided between the Keihin CR29s and the Mikuni RS34s.
« Reply #87 on: March 03, 2014, 09:22:31 PM »
Seth,
When I had Mike port my head, he mentioned that two forum members were running similar engine specifications with RS34s.  I have a feeling you were one of those, and Doctor D (David Hiller) was definitely one of them.
David prefers the RS34s to the CR29s; he says they provide more street-able power.  I've heard others remark that the CRs run best flat out and on the high rev range.
I got your PM regarding a Wideband gauge for tuning Air-Fuel.  Can you give me more details on the one you are using?  How did you install it?
Don
« Reply #88 on: March 03, 2014, 09:39:37 PM »
I think my engine is not quite as built as what you're planning, but it's plenty ;)
Concerning the Wideband:
It's the lowest priced model made by innovate.
I mounted the gauge (right) as such:
I have a 4-1 Carpy exhaust (which is crap fitment, btw...don't purchase) and I welded the O2 sensor bung in the collector, in the 21:00 position (looking from the rear), just behind the side stand (k model frame). It was really the only option for placement.
There's a box that houses some of the gauges electricals, that's maybe 4-5" long by 2" wide, which was the hardest part to hide. I hid it under my battery box, and it all but disappeared to the eye.
Some info for the RS34's.
http://forums.sohc4.net/index.php?topic=122398
I think MadScientist, Tweakin', and Dr. D all have motors from 836-915cc with MRieck's heads. They all are running RS34's, as am I.
« Last Edit: March 03, 2014, 09:49:39 PM by sethdhawkins »
1972-ish CB750K
1974 CB450
1974 CB360
Offline brandEn
« Reply #89 on: March 03, 2014, 09:56:30 PM »
subscribed!
Looks like a good build. I have met Ian at Twinline and he seems like a pretty good dude.
« Reply #90 on: March 27, 2014, 12:17:54 AM »
Not too much new to report.  I'm still waiting for my fabricator to make some time to modify the frame (gussets, frame kit installation, steering damper mount, steering lock tabs, tank mount, oil tank mount, seat mount, battery and electronics tray, etc.).
I did pick up a Joker oil pressure gauge (since they were on sale with Cycle X) to add to my engine accents.  Cylinders are bored and honed, and I also picked up a Cycle X gasket kit with a MLS head gasket.
« Reply #91 on: March 27, 2014, 04:27:29 PM »
Put me up for two weeks in Cali, and I'd be happy to do any steel fab for you ;) It was 12 degrees here two mornings ago :-/
1972-ish CB750K
1974 CB450
1974 CB360
Offline P.abrera
« Reply #92 on: March 27, 2014, 07:07:52 PM »
Just caught up on this thread. Ugh, too nice. Beautiful build, love watching it come together. Lotta inspiration for my small bucks 550 build. Hurry up already! :-D
« Reply #93 on: March 27, 2014, 08:56:48 PM »
Haha!  It's a frigid 70 degrees here.  Brrrr.  I have to go to Michigan in a couple of weeks.  I hope it's not too cold.
Thanks!  I would love to speed this one along.  I've been distracted by buttoning up details on my other 750 (Nine Lives) bike and my 550 (Stockish Restomod), so I can then focus on this build.  Then I have one lined up behind waiting.  I'm spread too thin.
« Reply #94 on: March 29, 2014, 10:21:42 AM »
Just received my offset front sprocket and rear offset sprocket adapter plate from Devin at Cognitomoto.  Great quality party, cool packaging in muslin drawstring bags AND A FREE T-SHIRT.  Supercool!!
Thanks, Devin!!
« Reply #95 on: March 29, 2014, 02:52:22 PM »
How wide you runnin' back aft?
1972-ish CB750K
1974 CB450
1974 CB360
« Reply #96 on: March 29, 2014, 05:18:04 PM »
I haven't decided.  I'm going a bit wider than stock.  One of the things I need to source is the wheels.  I'm planning to run modern Morris wheels.  I'm trying to see if RSD will turn out a pair with the hub specs for the 750.
« Reply #97 on: March 29, 2014, 07:51:30 PM »
*drool*
1972-ish CB750K
1974 CB450
1974 CB360
« Reply #98 on: March 29, 2014, 11:30:56 PM »
My fab guy says my bike is in line to start next week!  Stoked.
« Reply #99 on: April 24, 2014, 12:43:43 AM »
I discovered that the Motogadget Chronoclassic gauge - for all of its splendor - does not include any control or mode button in the gauge itself. Rather, you need to wire on to the gauge. Jeez!  So I got to buy yet another piece of Motogadget gear - a push button kit.
http://store.revivalcycles.com/collections/motogadget-instruments-and-electronics/products/push-button-kit
