Author Topic: "Break in" miles on new rings and honed cylinders?  (Read 4234 times)
Offline Anton
« on: August 26, 2014, 11:03:25 PM »
Hey guys,
Did my piston rings and had the cylinders honed, just wondering how many miles the break in period should last? Iv read to ride it fairly hard (without redlining), no constant rpm, lots of speeding up and down shifting ect...
Thanks!
Re: "Break in" miles on new rings and honed cylinders?
« Reply #1 on: August 26, 2014, 11:20:11 PM »
3 and 3/4 hours.
Offline Anton
« Reply #2 on: August 26, 2014, 11:26:20 PM »
3 and 3/4 hours.
Thats pretty specific Dave,  how did you come up with 3 and 3/4 hours?
« Reply #3 on: August 26, 2014, 11:44:16 PM »
couple of hours will do it,change the oil as they'll shed metal in 3 and 3/4 hours use.
Online PeWe
Offline Schnell
« Reply #5 on: August 27, 2014, 03:55:01 AM »
I watched on of those car shows on TV, Fast and Loud, where they had a freshly rebuilt or maybe brand new engine, and they used "break in oil". It contains extra zinc to harden metal surfaces like the cam lobes and lifter pads.
Is there any truth/validity to that?
« Last Edit: August 27, 2014, 04:29:56 AM by Schnell »
primary: 1974 Honda CB750
project: 1971 Honda CL350
project: 1974 Honda CB450
previous:
1975 Honda CB750
1973 BMW R90/6
1981 Suzuki GS650
1973 Honda CD175
« Reply #6 on: August 27, 2014, 04:19:56 AM »
bump
Offline martin_uk
  • CB750F1 CB750K8
« Reply #7 on: August 27, 2014, 04:44:30 AM »
Just done mine on a 750 and used mineral competition running in oil.
Have done 90 miles and plan on another 100, then change oil and filter to standard mineral oil, plus adjust valve clearances, carbs and recheck cam chain adjustment.
May remove sump, to check pick up filter as well, depending on whether I have the exhaust off.
« Last Edit: August 27, 2014, 04:50:05 AM by martin_uk »
CB750F1, CB750K8,  Triumph Street Triple R, AJS 350, Triumph 3TA
Offline fmctm1sw
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
« Reply #9 on: August 27, 2014, 02:44:14 PM »
(I went with a cheap dino oil and added zddp)
Ran it pretty hard for the first 30 miles after a hone/re-ring.  All rpms.  Nothing constant.
Changed oil (same cheap dino+zddp) and filter w/magnets
Did another 70 miles in all RPM's.
Changed oil (my preferred oil) and filter w/magnets.
Almost at 500 where i'll do it again.
....not one bit of smoke. 8)
Offline Anton
« Reply #10 on: August 27, 2014, 10:07:13 PM »
great, thanks fellas!
« Reply #11 on: August 28, 2014, 03:00:40 AM »
is it best to use the cheapest oil I can find for break-in? and then run it moderately hard at all rpms ? I like that & I think it might help break-in the new rings better. I've always gone real easy(I think too easy)for the first 600mi. and I think it took forever to seat the rings.
« Reply #12 on: August 28, 2014, 09:05:34 AM »
I dont know if its 'best' but cheap (oreillys auto house brand) oil and leftover zddp was what i had on hand, so thats what I used for the first and second break-in intervals.
Once I got my vacuum sync done, I was off to find short straights and wind it up.  No moderation on rpms here  ;D
Offline Lostboy Steve
« Reply #13 on: August 28, 2014, 09:37:21 AM »
yep, get on it and ride the balls off of it.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
« Reply #14 on: August 28, 2014, 12:14:47 PM »
where can I get some zddp flybox ? does it help w/ the process ?
« Reply #15 on: August 28, 2014, 01:44:51 PM »
Read a few of the threads on the forum about it.  Just search ZDDP.  Hondaman speaks volumes :)   Its wear protection....
You have a few options.
-order it online(amazon) as an oil additive
-get other brand additives containing zddp, like Rislone
-buy an oil containing high levels of zinc/phos (VR1)
(After initial break-ins, I am using (non synth) Valvoline VR1 Racing 20w50.  High zinc/phos + low detergents)
« Reply #16 on: August 28, 2014, 03:32:46 PM »
thanks for those options  8)
I think I'll get a bit of Rislone(an oil additive?)since I might be able to get it at Autozone? it will hopefully not inhibit the break-in process...
« Reply #17 on: August 29, 2014, 01:57:04 AM »
oh no,oil thread looming?
« Reply #18 on: August 29, 2014, 02:08:16 AM »
I've seen some races bikes "run in" that you wouldn't even know they were being run in....!
Offline mick7504
« Reply #19 on: August 29, 2014, 02:14:15 AM »
Same here Mick.
Re ring 'em and then wring their fcuken neck.
No worries.  ;D
If I was you
I'd be worried about me.
« Reply #20 on: August 29, 2014, 02:33:56 AM »
3 and 3/4 hours!
« Reply #21 on: August 29, 2014, 03:50:48 AM »
Actually Advance Autoparts carries it, not Autozone at least in VA which is not that far from PA.  Yellow bottle Rislone.
« Reply #22 on: August 29, 2014, 03:52:09 AM »
thanks Prokop
« Reply #23 on: August 29, 2014, 07:53:19 AM »
Wouldn't use additives. Too much zinc IS harmful and this whole zinc thing is out of proportion if you ask me. All oils still contain some zinc.
Maybe you'll find this interesting: http://speedtalk.com/forum/viewtopic.php?f=1&t=32279
Offline Schnell
« Reply #24 on: August 29, 2014, 08:38:36 AM »
Wasn't it the introduction of catalytic converters that forced lower levels of zinc in gas car oils? Before that, oils were optimized for best protection. Now they are compromised, having to accommodate the catalytic converters. Diesel and race engines don't have cat converters so oil types for them is preferred. That's how I see it.
previous:
1975 Honda CB750
1973 BMW R90/6
1981 Suzuki GS650
1973 Honda CD175
