Author Topic: CB750 F2 cylinder head  (Read 8792 times)
Offline Bill/BentON Racing
    • BentON Racing
« on: May 08, 2015, 08:32:42 AM »
That's right, a good one still assembled, $225.00 plus shipping, Bill
BentON Racing Website
BentON Racing Facebook
Offline dragracer
  • CB750F Dragbike
Re: CB750 F2 cylinder head
« Reply #1 on: May 08, 2015, 10:22:27 AM »
Someone buy this head. Its a good base for a stock valve, 1000cc, 10 second drag motor. Ask me how I know
Offline TurboD
« Reply #2 on: May 08, 2015, 01:50:42 PM »
How do you know.... Hehe
Offline dragracer
  • CB750F Dragbike
« Reply #3 on: May 08, 2015, 02:02:35 PM »
I've got the time slips to prove those heads will work with the factory valves, good springs,  light port work, a decent size cam and a 72mm bore.
Offline bear
  • Leeton in Australia
« Reply #4 on: May 08, 2015, 02:07:12 PM »
Not one of mine I hope Billy ;)
Brian
    • BentON Racing
« Reply #5 on: May 08, 2015, 02:53:40 PM »
Haha  of course not. Yours in the box marked Bear's heads! ;D Bill
Offline sohc boy
« Reply #6 on: May 08, 2015, 02:56:46 PM »
 i too have run 10's with these heads  ported,stock valves an springs ,shimmed up
i live by the voice inside my head
Offline dragracer
  • CB750F Dragbike
« Reply #7 on: May 08, 2015, 04:23:42 PM »
And there you have confirmation. I can't speak about the performance of the earlier model heads after port and valve spring work but with the right cam and pistons, they make decent power. And that's my last sales pitch for Bills cylinder head. Lol.
    • BentON Racing
« Reply #8 on: May 13, 2015, 03:53:57 AM »
OK, a deal for someone, cylinder head for $225.00 shipped 48 states, best I can do, Bill
« Reply #9 on: May 13, 2015, 04:03:51 AM »
Bear's Heads would be great name for beer :)
« Reply #10 on: May 13, 2015, 07:01:12 PM »
What do you do to get the compression sorted with these heads on K engines Bill..?  I may be interested   ;)
Offline cbr954
« Reply #11 on: May 17, 2015, 08:01:48 PM »
I had to mill my F2 head .060" to get the chamber volume the same as earlier K head.  Running 10.5 :1 cycle x 970 K pistons.  You also have to have brass bushings installed in some of the cylinder stud holes in the head so you dont have oil leaks.
03 CBR954RR, 72 750 chopper(970cc
F2 head), 2017 CRF450R, 2001 CR250R, 72 CB500, 79 XR250, 04 CRF50,70's soon to be rebuilt cb750 drag bike.
Offline TurboD
« Reply #12 on: May 17, 2015, 08:07:54 PM »
Looks nice that should make good power.
Online HondaMan
« Reply #13 on: May 17, 2015, 08:12:37 PM »
I've been using the 750 DOHC pistons with their shoulder turned off 1.5mm, about 1/4" in, with the K7/8 and F2/3 heads. It makes the CR about 9.2:1 on the F, and about 9.5:1 on the K7/8 head. I also mill the heads a bit, about 0.5mm.
« Reply #14 on: May 18, 2015, 12:50:40 AM »
Thanks 954, If I buy it, it will be off to Mr Rieck's place for a stage 4....
« Reply #15 on: May 18, 2015, 12:55:29 AM »
PM sent Bill   ;)
Offline Old Scrambler
« Reply #16 on: May 18, 2015, 06:31:10 PM »
RR..........take a look at the 915 kit from Dynoman for the F2-3 motors. I used CB900C rods with J&E 62mm pistons and installed a squish-band on the perimeter of the head except at the valves where it is not needed. No decking other than a few thou to get level. Note the egg-shape of the chamber perimeter. Compression is 12:1+ when cold.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
« Reply #17 on: May 18, 2015, 07:47:41 PM »
OS, this would be going on a billet block 1000cc engine, on a K8 bottom end, if it will work, i'm interested in the F2 head because of the bigger inlet spigots, I'm going to run fuel injection and the Throttle Bodies I have are going to be easier to fit using the bigger diameter F2 rubbers and spigots, I considered having F2 spigots machined into a 392 K8 head, but if the F2 {410} head will work I will go with that...
Offline bear
« Reply #18 on: May 18, 2015, 07:59:00 PM »
My opinion.
The 410 head is the best option for a motor that size Retro.
Brian
« Reply #19 on: May 18, 2015, 08:17:52 PM »
My opinion.
Brian
Thanks Brian... ;)
Offline motorclocks
Re: CB750 1970 cylinder head, cam and holders
« Reply #20 on: December 14, 2018, 11:52:08 AM »
not sure if im doing this right, can't figure out how to post question. I have a 1970 cb750 head no cam or towers can i get them from another head same year and have them work.
« Reply #21 on: December 14, 2018, 06:24:54 PM »
Yes
« Reply #22 on: December 14, 2018, 06:43:35 PM »
That deck # is correct.....055 to .065. Though those #'s start to miss with the cam chain. Boy...older thread  ;D
« Reply #23 on: December 15, 2018, 07:45:36 AM »
F2 head (std height) on K1-K6 cylinder with F2 pistons or with K 12.5:1 pistons should work too?
Offline Cougars750F0
« Reply #24 on: December 15, 2018, 12:53:25 PM »
Sold?
1970 Honda / Yoshimura 810 with ported head, 1968  Honda CB450 5 speed European model, 1973  Triumph Bonneville 750 twin carburetor model, 1975 Honda 750F0 Super Sport, 1977 Honda 750A
