Author Topic: Whats Your Favorite Tank Liner???  (Read 6341 times)
Offline GizmoDuck
« on: June 03, 2015, 06:26:05 AM »
Rust is almost removed from my tank now I need to coat the inside what is your favorite one?  I have looked at Red-Kote, POR-15, Eastwood, and Caswell but not sure which one to go with.
Offline chewbacca5000
  • I polish covers!
Re: Whats Your Favorite Tank Liner???
« Reply #1 on: June 03, 2015, 06:31:02 AM »
 I like RedKote as it is the easiest to do and stand up to ethanol well.  You can cut with small amount of MEK and get nice even coverage.  This is important as uneven coverage leads to a failed linner.  If the material pools up it will make a thick spot that will crack and flak off.  Not with red kote.  Nice and even.
Offline mrfish2
  • I might be a
« Reply #2 on: June 03, 2015, 06:52:31 AM »
+1 on the RedKote. I bought is mostly because my local mom & pop hardware store carried it so I wouldn't have to wait for Caswell to come in the mail. The can says it only takes 24 hours to dry and be ready for use, but mine took closer to 4 days to sit up rock hard. Like Chewy says, it stands up well to Ethanol. I've had it on the tank for almost a year now and haven't had any issues.
1976 CB550K            1979 XS1100
1980 CB650C - Sold
It's a little motor and likes having the tits revved off it.
« Reply #3 on: June 03, 2015, 07:23:00 AM »
No liner  ;)
Offline Tews19
  • I am no
« Reply #4 on: June 03, 2015, 07:25:46 AM »
My tank literally has a minimum of 30 pin holes up and down the lower seems. I used Caswell per stev-o and Cal and I am not looking back. Tank is great. No leaks so far. Will use again.
1970 Honda CB750 survivor.
« Reply #5 on: June 03, 2015, 07:45:17 AM »
Caswell.
« Reply #6 on: June 03, 2015, 08:08:55 AM »
Anything but Kreme please------------------ I have used Redkote on a few with no issues, easy to work with but wish it did not look so much like blood. The color I noticed fades out over time to more of a gray.
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #7 on: June 03, 2015, 09:23:18 AM »
I had a radiator guy etch and use Redkote on my tank and it has held up so far.
« Reply #8 on: June 03, 2015, 11:23:24 AM »
I used Kreem as directed and it held up 20+ years just fine.
« Reply #9 on: June 03, 2015, 11:29:07 AM »
  I think for the most part it is all about the prep. The ones I have had to remove always had a layer of rust underneath. On a Suzuki GT550 once that had been stored empty for awhile I was able to pull the whole thing out in mostly one piece right through the filler hole. It was weird.
  • I polish covers!
« Reply #10 on: June 03, 2015, 11:53:13 AM »
Miraculous healing!  Cream be gone!  Hallelujah.  Or your tanks imune system rejected the white cancer poured into it.
Offline b5rider
« Reply #11 on: June 03, 2015, 12:43:05 PM »
Damn! I just bought POR-15
1984 Honda Elite 150
1998 Yamaha 650
2004 Honda 750 ACE
1975 CB550
1978 CB400A
1978 CB550 now 603cc w/sidecar
The key to life is to make sure the line to put flowers on your grave is longer than the one to piss on it.
« Reply #12 on: June 03, 2015, 01:13:11 PM »
no liner is best.
..use it only on a tank as last chance..on a tank vho not can be faund a used one.(most tanks can be faund fine  used.. ..if rust (/korosion have maket it  leaking
.a rotten sealed tank can spring leak in a aksident..more easy then a solid good one
.not to seal rust and dirt inside a tank..insteat of a good kleaning job....
Offline ofreen
« Reply #13 on: June 03, 2015, 02:07:02 PM »
Nothing wrong with POR-15. Or Kreem. I believe the older Kreem formulations only began to suffer with Ethanol (personally). I've encountered many tanks with it still in there and still holding strong. (Or at least until a PO left abandoned gas/water in it for decades).
I had a Kreem liner go almost 20 years in my 750, but it failed a few years ago almost overnight it seemed. There's a thread about it here somewhere. After getting it out (a #$%* of a job) I replaced it with POR-15. Without looking at my notes, I believe it has been in there for about 5 years now and doing fine with potato juice they call gas here in the Boise area. They say 10% erhanol, but I believe there is more than that in many lots of fuel. Makes your eyes water when fueling. I agree with going without a liner if you can get away with it. Unfortunately some of these old tanks are too far gone. As said above, everything has to be done just so, or you'll have a failure.
Greg
'75 CB750F
« Reply #14 on: June 03, 2015, 02:51:23 PM »
+1 Caswell.  Have 2 tanks with it.
Offline AlekStooge
  • can't afford cheap stuff
« Reply #15 on: June 03, 2015, 04:52:34 PM »
I just derusted my tank with metal resuce. Now its getting powdercoated. I don't want to use liner because it will prevent me from welding on it, if I chose to do so in the future. There are no noticeable pinholes and it holds fluid well, besides the gas cap when its is upside down. Is lining an absolute necesity? I've been meaning to ask this question but didn't get around to it.
Offline AlekStooge
« Reply #16 on: June 03, 2015, 05:40:36 PM »
Lining is absolutely not required. Some folks do it as a prevention once they've de-rusted a tank, others to deal with small pinholes. But you're dead right; don't line a tank then weld on the tank. The liners are flammable, they will fail progressively away from the welded area, and wherever you weld (assuming you're installing a patch) will not be treated.
If you do choose to line, wait until you're metal work is done, but before paint (or after powder coat as the heat also is problematic for the liners) to avoid damaging the final paint with prep chemicals.
The fact anyone would line a tank seems like a cheap fix like bondo. Do it right, weld the pinholes or get a professional to do it. I have heard gas tanks already come with a liner in it   and it will get destroyed with powdercoating, others say it is only BMW'S that have this. Anyone care to straighten me put with the facts?
Offline AlekStooge
« Reply #17 on: June 03, 2015, 06:07:41 PM »
So old Japanese motorbikes don't have liners stock? Other than being a quick way to fix pinholes, I see it like putting super glue and rubber on a tire.
« Last Edit: June 03, 2015, 06:11:58 PM by AlekStooge »
« Reply #18 on: June 03, 2015, 06:16:41 PM »
Not quite.
I see it as a way to seal a tank so I dont have to worry about rust debris entering my fuel system.
Offline AlekStooge
« Reply #19 on: June 03, 2015, 06:24:58 PM »
Not quite.
I see it prevents rust from developing but not to fill in pinholes.
Offline jdenz
« Reply #20 on: June 03, 2015, 06:28:01 PM »
I would also say NO liner. If you have no more rust and no pin holes there is no use for a liner, just make sure you have fuel in the tank and you will be ok. Its what ive done and i must say it works. i also put a nice inline filter to trap any rust residue.
Offline b5rider
« Reply #21 on: June 03, 2015, 07:32:52 PM »
Not quite.
+1
That's the only reason I'm doing it.  I have a custom painted tank that would be difficult to match,  but it has some rust that is getting into my carbs despite a filter
1998 Yamaha 650
2004 Honda 750 ACE
1975 CB550
1978 CB400A
« Reply #22 on: June 03, 2015, 08:30:40 PM »
Don't like liners at all, if  have a tank bad enough to need one I'll just buy a new one.... ;)
Offline AlekStooge
« Reply #23 on: June 03, 2015, 10:30:30 PM »
Not that I have come across but I haven't seen every tank from every manufacturer on the inside.
I can tell you from personal experience, that in order to fix badly damaged tanks, it is sometimes absolutely necessary to re-line them. Or, you must cut the tank shell free from the tunnel, work a patch to the curves, weld it in, grind it, hammer and dolly the metal, then, weld the tank back together. Would cost you right around $1,000 to do it that way.
Or, with some decent patch work, some tig welding and grinding, a liner insures that the patch is leakproof. So, sometimes, it's a matter of economics for folks on a budget who desire to retain the original tank.
And I don't know how much bodywork you've done, but Bondo is absolutely used on every show car to attain perfect lines. Bondo isn't the foe, gobbling it into dents to raise the surface by amateurs is. But every pro "surfaces" body panels to produce perfectly straight and flawless paint jobs. And they're not cheap either...
I've never used a liner before and never done body work (interested though). I guess there is more work than just filling in the pinholes. I always hear bad things about Bondo.
Offline ofreen
« Reply #24 on: June 04, 2015, 06:27:26 AM »
Fillers can be misused and abused like anything else. Used correctly they make a lot of things easier (and possible).
Greg
'75 CB750F
