Poll
Stella CB750K7 vs. Helen Restomod CB750F 915 vs. CB750F Hot Rod Flamed Street Tracker
Ron aka Restoration Fan's 1978 CB750K Stella
22 (33.8%)
BigSam302's 1976 CB750F 915cc Restomod Helen
29 (44.6%)
mwasson's 1976 CB750F Hot Rod Street Tracker
14 (21.5%)
Total Members Voted: 59
Voting closed: October 31, 2015, 11:19:17 PM
Author Topic: Vote for Bike of the Month - November 2015  (Read 6174 times)
« on: October 15, 2015, 11:19:17 PM »
Restoration Fan's (Ron & Logan) 1978 CB750K8 Restoration Project Stella
http://forums.sohc4.net/index.php/topic,141761.0.html
Father-Son High School Senior Project
Very thorough, ground-up restoration with custom paint
Reason for new-found family obsession with Honda CB's and additional builds!
Bigsam302's 1976 CB750F Restomod Canyon Carver Helen
http://forums.sohc4.net/index.php/topic,142578.0.html
Braced frame (front and rear cross-members), hoop and custom electronics pan
New generation Big Piston Forks with Brembo monoblock calipers (from Suzuki GSXR and rebuilt by RG3)
915cc big bore kit, ported head, cam, pork chop crank, Carrillo rods and Mikuni RS34 powered
Blue-Gray painted Benjie's Tank with hidden oil tank
Motogadget electronics including Mini-motoscope gauge mounted into stock analog tachometer
Custom rear brake carrier with Brembo caliper (from Ducati Monster)
Custom rearsets and linkage
Custom paint
Newly-laced Sun Rims with Avon Roadrider tires
Video of start up
http://forums.sohc4.net/index.php/topic,131735.0.html
836cc Wiseco kit, Carrillo rods, Webcam 63a cam, Weber powered, Hot Rod-Flamed Asphalt Burner
2004 CBR1000RR front end (custom milled fork lower for single-left-side brake only)
Motogadget (M Unit, M Switches, M Blaze blinkers, Chronoclassic Dark tachometer/speedometer)
Custom fabricated tank (from donor Harley Davidson)
Moon-Eyes oil tank
Old School custom flame paint
« Last Edit: October 16, 2015, 03:01:30 PM by CB750 Cafe Racer Fan »
Offline Bigsam302
    • 1976 CB750F (915cc) Super Sport
Re: Vote for Bike of the Month - November 2015
« Reply #1 on: October 25, 2015, 06:38:58 PM »
Hello,
I wanted to provide some information on my build.  It is something that I am very proud of.  It has been a long road, full of setbacks and frustration.  This was by far the hardest project that I have ever worked on.  I started with this.  It’s a 1976 Honda CB750F Super Sport and I purchased her a little over five years ago.  It took me over four years to build.  A lot of planning and thought went into this build.  My goal was simple.  I wanted something that looked amazing and performed to best of its ability.
This is what she looks like today.
I am very happy with the way it turned out.  This bike is so meticulously designed and put together for the purpose of performance.
My first hurdle was to make the bike clean in the middle and to remove all the clutter.  So I had a gas tank designed with and oil tank in it.  I also fit all the electronics under the seat hump.  Everything is hidden on this bike.
The frame was de-tabbed and braced.  The tank was moved forward.  The suspension is fully squared away.  I had custom YSS shocks build for this bike and my weight. It is equipped with the latest generation GSXR750 Big Piston Fork resprung for the weight of THIS bike, with Brembo monoblock calipers, and Cognito front hub and triple tree.  The rear brake features a custom carrier with Brembo caliper off a Ducati Monster.
The engine is a 915cc beast with Carrillo rods, ported head, and performance cam -- topped off with RS34 carburetors and GIGANTIC Steel Dragon velocity stacks.
I sent all of my engine parts to Cycle X. I got the Pork Chop version and it is gorgeous.  I received a bunch of other goodies like my lighted and balanced alternator, super gasket kit, manual primary chain adjuster, race cut transmission, Cycle X heavy duty primary chain, cam chain, Cycle X heavy duty case studs, etc.....
Here are my Carrillo Rods and they are pretty!
Transmission and Cycle X primary chain adjuster installed
The cylinder head:
-Cycle X #4 Race Port
-Kibblewhite 5mm Bee-Hive Spring Conversion Kit
-Oversized intake valves
-Light weight intake valves
-Light weight exhaust valves
-Intake guides and seals
-Exhaust guides and seals
- Keepers and lash caps
-Titanium retainers
-Chrome silicon springs
= BEAUTIFUL!
915cc Big Bore Kit
The 915cc Pistons are gorgeous. I also had the pistons coated.  That’s why the skirts are black.
Here is my new CX-7 camshaft from Cycle X.
Here is my new APE adjustable cam sprocket
My rockers were welded and lightened with titanium rocker nuts.
The gauge is one of my favorite custom parts.  I put a lot a thought into.  I came up with a trick mount for my custom combination analog tachometer and inserted Motogadget miniscope.  The gauge is fully rebuilt with Joker Machine trimmings.
My gauge is gorgeous and it works like a charm.  All the idiot lights work like they are supposed to.  I have the neutral and oil pressure lights working.  I am very happy with the way it turned out.
I have all Motogadget electronics:  M-Unit, M-Lock, switches.  It is clean and tucked under the seat with a Li-Ion Anti-Gravity battery.  The M-Lock RFID has a hidden gusset that points the wireless key under the seat to activate and lock the electronic system.
All this makes for an awesome bike and a blast to ride.  Again, I am very happy with the way this turned out.
Check out my build for more details!  And thanks again for the nomination and the vote.
Sam
1976 CB750F (915cc) Super Sport: http://forums.sohc4.net/index.php?topic=142578.0
Offline run-tmc
« Reply #2 on: October 25, 2015, 09:02:12 PM »
Great work on that bike Sam, just a beauty.
Sent from my iPad using Tapatalk
'76 CB750K6
Offline Bigsam302
« Reply #3 on: October 26, 2015, 08:46:05 AM »
Thank you very much run-tmc!  I appreciate it.
Sam
« Reply #4 on: October 26, 2015, 08:58:21 AM »
Thanks for the build summary, Sam.
This bike is so well thought out.  I love the frame tube bracing up front and rear.  It is simple and looks factory.  The engine is pure performance bike porn.  This bike might not be able to keep up with Sam's Ducati 1198, but it sure will one of the faster 750s out there.  The suspension and brakes are a huge upgrade, too.  I cannot wait to see you riding this bike, Sam.
« Reply #5 on: October 27, 2015, 05:28:00 PM »
Only four more days of voting!
« Reply #6 on: October 27, 2015, 05:42:17 PM »
Been there, done that... ;D ;)
« Reply #7 on: October 27, 2015, 06:01:39 PM »
« Reply #8 on: November 01, 2015, 12:30:19 AM »
Congratulations, Sam!
« Reply #9 on: November 01, 2015, 03:15:41 AM »
For once I voted for the winner, usually I am with the second or third place.
Offline Bigsam302
« Reply #10 on: November 01, 2015, 04:18:52 AM »
Thank you very much 70CB750!  And thanks to all of you who voted for me.  I am truly honored!  :D
Sam
Offline Davez134
« Reply #11 on: November 01, 2015, 12:35:44 PM »
Congrats on the BOTM! Usually I am torn on the vote, but I could not stop looking at yours! All the lines are perfect, and mods done with a purpose. Makes me want to start another project to keep mine company!
Offline Restoration Fan
  • My wife will never call me
« Reply #12 on: November 01, 2015, 01:49:36 PM »
Congrats.  Very nice bike.  If you have to lose, you wanna lose to a bike like that.
« Last Edit: November 01, 2015, 05:39:26 PM by Restoration Fan »
Offline CBertels
« Reply #13 on: November 19, 2015, 05:37:48 PM »
Sam, that color is amazing.  Your build has inspired by project quite a bit.
http://forums.sohc4.net/index.php/topic,150258.msg1727587.html#msg1727587
