Author Topic: "Mile High" CB350 Four project  (Read 36881 times)
Offline CBJoe
Re: "Mile High" CB350 Four project
« Reply #75 on: October 29, 2016, 03:18:06 PM »
Ok, so maybe I've gone a little too far prettying up the starter motor...
I think that's the cleanest starter I've ever seen ;D
'07 Bonneville Black
'65 CB77
'66 CM91 (C90'ish)
« Reply #76 on: October 29, 2016, 04:02:31 PM »
Nice work !  8) 8)
Offline Denver_Larry
« Reply #77 on: March 07, 2017, 03:04:36 PM »
Finally something to talk about!  After a long break from the action Cliff Meyer worked up some more of his magic and delivered this beauty today:
I won't be able to play with it until this weekend but at least I got to check it out and hold it up against the bike.  My new welder gets here Thursday!
2005 RC51
1973 CB350F...project
« Reply #78 on: March 07, 2017, 03:27:40 PM »
Miller Syncrowave 210.  Little step up from my little Century wire feed!
2005 RC51
Offline BLAC
  • An espresso is a
« Reply #79 on: March 07, 2017, 03:47:33 PM »
Looking great! make sure you get the shock mounting points in the correct spot (if you want to run stock springs.
I built the subframe how I wanted it to 'look' but it ended up not working with stock springs and I scrapped the mounting plates and dual springs and went with a monoshock   :P
If you can't fix it with a hammer, it's an electrical problem... If it's an electrical problem, it's Cal's problem.
*2005 Yamaha R6 (sold)
*2014 Ducati Streetfighter 848 (sold)
*2014 BMW S1000RR (sold)
*2010 Ducati Streetfighter S
*1978 CB550 Restomod Build
*1974 CB550 Monoshock build
http://forums.sohc4.net/index.php/topic,154614.0.html
« Reply #80 on: March 07, 2017, 03:56:08 PM »
Nice box! Its a great "shop" unit. Not too portable, but really welds well. I am partial to the Dynasty series, but they're pricey and then some. If my current unit ever dies, I'll be replacing it with a 280DX but the darn thing keeps kicking  >:(
Hoping to get quite a few good years out of it.  Couldn't justify or afford anything more at the moment!  I was pretty much set on a Diversion 180, but this will let me grow a lot more as I get better I think.  Have you ever dealt with Matheson for gas and wire?  Closest place to me and I need a bottle and some filler to start with.
2005 RC51
« Reply #81 on: March 07, 2017, 04:01:09 PM »
Thanks, although I can't really take any credit for the hoop and cowl! Lol!
Not planning on running the stock shocks, but I'll certainly be as careful as possible measuring and replicating the stock mounting locations.
2005 RC51
« Reply #82 on: March 07, 2017, 04:16:56 PM »
Cliff does some great sheet metal fab.
« Reply #83 on: March 07, 2017, 05:29:09 PM »
They're national, that's why I asked.  IOC is where I just bought my new rig from.
2005 RC51
Offline palepainter
    • Mike Learn custom paint and airbrush.
« Reply #84 on: March 07, 2017, 07:47:18 PM »
That tail section really looks sweet.  Almost too nice to paint.   :)
Offline JDP12
« Reply #85 on: March 07, 2017, 08:10:12 PM »
Never thought I would say a starter is gorgeous, until now.  Wow man great job.
« Reply #86 on: March 07, 2017, 10:06:40 PM »
And that's coming from a painter.
I agree.  Maybe brush the finish and clear it, or at least show some of it off.
« Reply #87 on: March 10, 2017, 06:29:36 PM »
No turning back now!
After a couple test runs on the old subframe I got brace and started with welding on the hoop:
So far so good!  It's nice and level and centered up as best I can tell.  Need to pick up a 1" hole saw tomorrow so I can miter the stays and start welding them on, along with the shock mounts.
2005 RC51
« Reply #88 on: March 10, 2017, 07:05:43 PM »
So far no blow through, but I'm staying conservative I'm in the 90s for amperage and not giving it a full pedal.  What do you recommend for amps?  First time with anything more than my old Century 100 wire feed, so total apples and oranges!  My welds so far are nowhere close to what I would consider pretty but I'm getting good penetration I think.  Dipped the tungsten a few times...
2005 RC51
« Reply #89 on: March 10, 2017, 08:15:36 PM »
Thanks for the tips Cal.  I suppose it does make sense and is more consistent to go lower with the amperage but keep the pedal floored.  It does have pulse, I'll give it a go with some practice runs tomorrow.
2005 RC51
Offline innovativems
    • Innovative MotoSports
« Reply #90 on: March 10, 2017, 09:03:13 PM »
I spy an rc51!  I have an 03 track bike.  Btw loving the 350!
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
« Reply #91 on: March 11, 2017, 07:45:54 AM »
Exactly, the new material is 0.083 so I dialed into the 90s and was throttling back a bit.  But being brand new at TIG it wasn't the best for consistency.  I only have the stock 3/32 tungsten for the moment.
2005 RC51
« Reply #92 on: March 11, 2017, 01:54:07 PM »
Ad hoc tubing cutter....
2005 RC51
« Reply #93 on: March 11, 2017, 03:26:25 PM »
Well that TOTALLY didn't work! Lol. Grinder it is....
2005 RC51
« Reply #94 on: March 11, 2017, 05:26:26 PM »
I actually did strap it down close to the cut before I started but there was just too much movement everywhere to get a decent cut.  I bailed on that idea and resorted to the cutoff wheel/grinder and got it pretty decent after some fine tuning.  Done for the night, things started getting sloppy so it's time for food!  Got the shock mounts tacked into the plates before I called it for the night though.
2005 RC51
Offline NobleHops
  • Don ya be callin' me no
  • Misfit - Tucson, Arizona
« Reply #95 on: March 12, 2017, 12:46:58 PM »
Crazy mad skills there Larry. That hoop looks like it grew there.
I have a motorcycle problem.
« Reply #96 on: March 12, 2017, 01:10:44 PM »
Thanks Nils but I can't take credit for the vast majority of it, I just measured and welded.  Cliff Meyer is the man who made it.
2005 RC51
Offline palepainter
« Reply #97 on: March 12, 2017, 02:15:13 PM »
Nice work modding the frame.  What part of Denver are you in?
« Reply #98 on: March 12, 2017, 02:32:14 PM »
Saudi Aurora.  You?
2005 RC51
« Reply #99 on: April 16, 2017, 08:53:51 PM »
Looking into a new battery for the project and my RC, and want to get into one of the newer lithium ones.  Question is, what brand?  Speedcell, Shorai, and Antigravity all make what I'm looking for for both bikes.  Pros and cons from everyone's experience?
2005 RC51
