Author Topic: KO basket, i think? YUP! Gonna bring back to life......  (Read 23802 times)
Re: KO basket, i think.
« Reply #25 on: November 23, 2015, 09:48:06 AM »
The air assist is a period mod that doesn't work all that great and does not even maintain pressure over time (you will need to periodically add air).  You are better off using original caps and upgrading your springs (and maybe upgrading to Race Tech valve emulators if you want some improvement in the front).
Offline pipeguy
« Reply #26 on: November 23, 2015, 05:30:38 PM »
Ok guys got my jugs measured today, and apparently they measured 61.107, will new rings be enough or will I have to rebore and buy piston kit? Trying to get skinny on these measurements  but most stuff on here is in inches and im a mm guy, thanks in advance.
1970 CB750 K0
1980 CBX
2001 Electra Glide
2013 CRF450R
2013 KX450F
1977 KH 400 triple (gone)
1973 CB750 K3 (waiting it's turn)
2000 KLR 650(gone)
2001 BMW 1200RS(gone)
2004 Busa limited(sadly gone)
2003 ZZR250 ninja(gone)
1996 VFR750(gone)
1974 RD350(really sadly gone)
Offline rickmoore24
  • Be led by your dreams, not pushed by your problems.
  • I <3 SOHC4's
    • Rosenbard Films
« Reply #27 on: November 23, 2015, 10:41:42 PM »
I believe stock is 61mm, first over is 61.25mm. For 61mm clearances with stock rings and a hone, I'd dig around to see what Hondaman says. You may need to go up to 61.25mm? Are the cylinders in good shape? Any gouges or things of that nature?
1972 CB750 K2 (Daily Runner)
1972 CB750 K2 (Sold)
1973 CB750 K3 (Hardtail 836cc)
1998 CBR F3 - R.I.P., went down on the 101 in Calabasas, Ca.
1995 EG6
Online Don R
« Reply #28 on: November 23, 2015, 11:48:51 PM »
   So, how many clutch bolts?
Offline pipeguy
« Reply #29 on: November 24, 2015, 02:34:02 AM »
I have not checked original broken cases, but the clutch cover has 10 bolts. Cylinder measurements were done after cleaning them up. Thanks.
1970 CB750 K0
1980 CBX
2001 Electra Glide
2013 CRF450R
2013 KX450F
2000 KLR 650(gone)
1996 VFR750(gone)
« Reply #30 on: November 24, 2015, 08:07:01 AM »
Check the original cases, i think they may have one less hole..
Offline pipeguy
« Reply #31 on: November 27, 2015, 12:13:39 PM »
Here is pictures of cases, dunno seems the same to me.
1970 CB750 K0
1980 CBX
2001 Electra Glide
2013 CRF450R
2013 KX450F
2000 KLR 650(gone)
1996 VFR750(gone)
Online Don R
« Reply #32 on: November 27, 2015, 12:21:21 PM »
Yep, 10 bolts. The number pad looks like a rare sandcast case but if it was, it would have only 9 clutch bolts.  Someone may have welded up the number pad, ground it back down and re-stamped the numbers. That's all I got.
« Last Edit: November 27, 2015, 12:23:51 PM by Don R »
Offline pipeguy
« Reply #33 on: November 27, 2015, 12:27:02 PM »
This is the tank, is this the wrinkle tank everybody talks about? Previous owner did a crazy paint job lol, oh well, paint will cover all that up.
1970 CB750 K0
1980 CBX
2001 Electra Glide
2013 CRF450R
2013 KX450F
2000 KLR 650(gone)
1996 VFR750(gone)
Offline BPellerine
« Reply #34 on: November 27, 2015, 02:09:34 PM »
yep that's the wrinkle tank,neat find.bill
1978 CB 750K ard and webers
another anfob
« Reply #35 on: November 27, 2015, 02:46:16 PM »
That is what I noticed the number pad..lets take a closer look ..maybe sandcast. With an extra clutch hole.. Show a pic of the back of motor looking from the top..
Offline pipeguy
« Reply #36 on: November 27, 2015, 02:55:46 PM »
Here are pics
1970 CB750 K0
1980 CBX
2001 Electra Glide
2013 CRF450R
2013 KX450F
2000 KLR 650(gone)
1996 VFR750(gone)
« Reply #37 on: November 27, 2015, 02:59:15 PM »
Now they look diecast..not sure what is with that numberpad...
Offline pipeguy
« Reply #38 on: November 28, 2015, 02:50:28 PM »
Trying to secure all major parts, this week got tank, stator, field coil, and spark advance and points plate. Now on to seat search, from what I have read, 69-71 are same pan and hinge mounts. Is this correct? Is there any other Honda model that will fit also? found a few locally that were listed as CB750 seats but were all later years 74 and up, thanks in advance.
1970 CB750 K0
1980 CBX
2001 Electra Glide
2013 CRF450R
2013 KX450F
2000 KLR 650(gone)
1996 VFR750(gone)
« Reply #39 on: December 02, 2015, 02:32:42 AM »
Congrats mate, looks like you've got the best part of a K0. This is both a windfall, and a curse, because while you've got the most desirable of all CB750's, (well, "Sandcasts" are the most valuable, but a good diecast K0 is a wonderful bike to own) everyone else knows that too, so you have to pay a massive premium for any parts that you'll need.
I've slowly been collecting parts to put my own K0 together for several years now, but I still need a 1969 frame before I can get too excited. Whereas I can buy a good K1-K6 frame for peanuts, the entrepreneurs out there want anything up to 1000 bucks just for a bare frame. There are plenty of seats available on ebay, from a couple of hundred for a reasonable repro, to a couple of thousand for a pretty average original.
What's your frame number? If it's already been listed, my apologies, I missed it. I hope you get it up and running, and back on the road, but if you give up, I call dibs! Cheers, Terry. ;D
Offline pipeguy
« Reply #40 on: December 02, 2015, 05:56:20 AM »
Thanks Terry, im pretty excited, I always loved these bikes, I guess like you said it could be a curse hahaha, at least that's what wifey says. I have seen some parts online and yes I will have to open wallet, but I will be patient, hopefully I will get motor together by the spring. You know living up here in Canada I have another obsession....Ice fishing lol, cheers.
1970 CB750 K0
1980 CBX
2001 Electra Glide
2013 CRF450R
2013 KX450F
2000 KLR 650(gone)
1996 VFR750(gone)
« Reply #41 on: December 02, 2015, 12:18:41 PM »
Ha ha, no worries mate, I hate the cold, so the inly ice I want to see is in my drinks. Have fun with your build, they're nice simple bikes to work on, and if you meep it long enough you'll get your money back. Cheers, Terry. ;D
Offline Sgt.Pinback
« Reply #42 on: December 02, 2015, 12:53:21 PM »
Sorry to ask..
..where is that K0  listing?
Doc, I love a motorcycle!
Offline pipeguy
« Reply #43 on: December 13, 2015, 04:47:15 PM »
So been keeping busy taking some more stuff apart this week. worked on taking all valves out of head. Also picked up an engine stand for 30 bucks.
1970 CB750 K0
1980 CBX
2001 Electra Glide
2013 CRF450R
2013 KX450F
2000 KLR 650(gone)
1996 VFR750(gone)
Offline yunk
Re: KO basket, i think? YUP! Gonna bring back to life......
« Reply #44 on: December 16, 2015, 03:04:44 AM »
I'm green with envy.
CB 750s are much rarer over here in Europe and the ones that exists are crazy expensive and they only get more and more expensive each year.
Basket cases doesn't really exist at all, and if they do they want thousands of $$$$$$$
Offline Sgt.Pinback
« Reply #45 on: December 17, 2015, 01:12:10 PM »
Heavy duty!
Will follow this while bringing my KO  barn find back to live. Good luck in finding all the missing parts!
Offline Restoration Fan
  • My wife will never call me
« Reply #46 on: December 18, 2015, 06:08:57 PM »
Nice find, pipeguy.
Looking at that stator, when you go to try & get that surface rust off of the stator, I HIGHLY recommend Metal Rescue.  I can't say enough great things about it.
It's $25 per gallon here in the States and I can only assume it's available there in Canada for you.  Go to http://www.metalrescue.com/home.aspx and there's a link for where you can buy it.
You literally just soak your part in this stuff and it removes the rust.  Take it out every couple of hours and wipe off the rust, then put it back in the stuff and keep doing that until all the rust is gone.  It's environmentally friendly, isn't caustic if you get it on you, can be re-used, and doesn't affect plastic, rubber or vinyl...only rust.
I think I'm on my 3rd or 4th gallon now because I reuse it over & over until it gets so brown that even when you strain it, the stuff looks like chocolate.  At that point, I dump it out and get a new gallon.
Enjoying your build so far.  Keep up the great work.
Swoop
« Reply #47 on: December 21, 2015, 04:14:22 AM »
Keep up the good work.
If you need any help and/or possibly the odd part, give me a shout. I'm just down the road from you in Nobleton and I am putting a K0 together this winter as well.
Cheers
Steve
Offline pipeguy
« Reply #48 on: December 21, 2015, 05:27:26 AM »
Wow Steve, you are quite a bit more ahead of me lol, but thanks for offer to pick your brain, I will send you Pm with my info, we can connect one day, I got a buddy that lives in Nobelton, cheers, Fred.
1970 CB750 K0
1980 CBX
2001 Electra Glide
2013 CRF450R
2013 KX450F
2000 KLR 650(gone)
1996 VFR750(gone)
Offline pipeguy
« Reply #49 on: December 22, 2015, 12:30:11 PM »
Had some time today and started the metal rescue on flywheel as suggested, thanks. Also cleaned up valves and springs, measured them still within spec, just found a bent exhaust valve. Does anyone know best place to find one, or just best to try dealer?
1970 CB750 K0
1980 CBX
2001 Electra Glide
2013 CRF450R
2013 KX450F
2000 KLR 650(gone)
1996 VFR750(gone)
