Author Topic: 1974 CB 550 Build Thread - "Resto-mod"  (Read 16218 times)
Offline Jeffro93
Re: 1974 CB 550 Build Thread - "Resto-mod"
« Reply #25 on: January 07, 2016, 06:28:42 PM »
Stev-o
I got the cylinder head today.  Thanks again for sending it over.  It's so nice to see non-stripped plug threads!
This is our wedding anniversary weekend, so I won't get much garage time until Sunday afternoon.  I'll keep you posted.
I should get the pinned cover early next week.
1974 Honda CB550
1983 Honda GL650 Interstate "Cafe'd"
2007 Triumph Bonneville
Online Stev-o
« Reply #26 on: January 08, 2016, 06:02:17 PM »
Stev-o
Ok, glad you got it.   Sounds like you found a pinned head cover, great.   Turns out my motor is a late K model, so I'm good too.
Remember the other Steve (Pecantree)?  Stooped by his house the other day, he was cleaning out his shed and sold me a spare 550 motor for $40.  I have no need for it now but couldn't turn that deal down.
Offline Jeffro93
« Reply #27 on: January 08, 2016, 06:31:25 PM »
I would have bought it too!  Tell him I said hello.
1974 Honda CB550
Offline Jeffro93
« Reply #28 on: February 03, 2016, 07:16:08 PM »
I haven't been posting, but I have been working.  I haven't been getting as much done as I'd like, though.  I've finally got a useable head and cam cover combination.  I sent the top end parts, hubs and several other items to Nils for vapor blasting on Monday and should get the frame, swing arm and associated parts back from the powder coater next Monday.
I tore into the forks this weekend and that's the source of my current question.  When I took them apart, I didn't find the parts that I expected to see.  The picture from my Haynes manual shows a damper rod.  When I got mine apart, they didn't have damper rods.  At first, I thought that the damper rod setup may be for the 500's, with a different setup for the 550's, but I haven't been able to confirm that.
Nils has the fork lowers and I'm hoping to order a new set of fork tubes tomorrow - mine are just way too rusted out.
Manual Image
What I found
Tastey Fork Seal
1974 Honda CB550
Online Stev-o
« Reply #29 on: February 03, 2016, 07:58:32 PM »
Hey Jeff.....you have a late model fork.  Must have been changed out at some time.
Look at the fiche here for a '78 model....
http://www.westernhonda.com/fiche_section_detail.asp?section=2451803&category=Motorcycles&make=Honda&year=1978&fveh=131104
Offline Jeffro93
« Reply #30 on: February 04, 2016, 01:47:38 AM »
Thanks, Steve.  This "dirty but original" bike has turned out to be more dirty than anything.  Oh, well. That's all part of the fun, right?
1974 Honda CB550
Online Stev-o
« Reply #31 on: February 04, 2016, 05:27:58 AM »
absolutely! The bike is 40 years old and had at least a few owners, no telling what it's been through.
BTW - what is the plan for the front end? New springs??
Offline Jeffro93
« Reply #32 on: February 04, 2016, 06:14:29 AM »
Probably just a stock soaring replacement.  I may just use the ones I've got and see what I think.  I haven't really researched it yet, though, so I'm open to suggestions and opinions.
1974 Honda CB550
Online Stev-o
« Reply #33 on: February 04, 2016, 06:19:18 AM »
I installed Progressive springs in my K4 two years ago, and honestly, I didn't notice a big difference. And as you know, I ride fairly aggressive.
Def put good shocks on the back, Hagons and Ikon (was Koni) are a good shock and reasonable priced.
Offline Jeffro93
« Reply #34 on: February 06, 2016, 07:26:01 AM »
No updates today - think I'll just be hanging out in the garage and cleaning/polishing parts.  Hope to order new rims and spokes, though.
I do have a question, though.  Steve-O was kind enough to send me a head to use since mine had some stripped plug threads.  The valves were bent, however.  Though I've got all of this worked out for the project, I'm trying to figure out how the valves got bent.  Since I only have the head, I couldn't check the pistons for damage, but the valves don't show evidence of contact with the pistons.  It's kind of a head scratcher for me...
Jeff
1974 Honda CB550
Online Stev-o
« Reply #35 on: February 06, 2016, 08:29:59 AM »
The PO did not follow proper procedure for installing the head cover.  The valves must be loose and use use the "rubber band trick" to prevent bent valves.
Page 59 of the Clymer shows this, the tappet adjuster must be loose so it comes into proper contact with the valve stem.  Once you see the pic, you will understand.
Are you ready to install the head cover.
One other thing: did you install new "pucks" to prevent oil leaks?
« Reply #36 on: February 06, 2016, 08:32:26 AM »
yes ..there is 100% bend valvets ,,if you just clask the cover on and teigten Down...its need some att to Mount it korrekt
Offline Jeffro93
« Reply #37 on: February 06, 2016, 11:16:49 AM »
Thx guys.  I'm not ready to put it back together. The top end is at Nils shop.  It was just something to think about while cleaning parts.
1974 Honda CB550
Offline flatlander
« Reply #38 on: February 06, 2016, 12:10:42 PM »
make sure the tappet adjust screws are backed off completely, and when installing the cover pop up each rocker arm with a finger so the screws naturally fall into their position on top of the valve stem. this works for me, i never used the rubber band trick.
Offline Jeffro93
« Reply #39 on: February 11, 2016, 06:19:20 PM »
I've made a lot of progress this week without really doing anything (except keeping my credit card warm...).  I got the frame and associated parts back from the powder coater on Monday (looks great - much better than in my crappy pictures). I got the top end, fork lowers, hubs, etc. back from Nil's vapor blasting shop (Restocycle.com) and the new rear rim was delivered today as well.  I've got a large order from 4into1 on the way, too.  Whew!!!
This weekend, I hope to complete the engine cover polishing and get started on stripping the engine case to prep for paint.  Once the engine is done, it's back into the frame.  Then lacing wheels, rebuilding the front end (after I get new fork tubes) and then I'll be done, right?  :-\
1974 Honda CB550
« Reply #40 on: February 11, 2016, 10:02:13 PM »
I probably missed this but what's going on with your VIN stamp?
Offline Jeffro93
« Reply #41 on: February 12, 2016, 04:25:40 AM »
They wanted to make sure that the VIN wasn't obscured by the powder coat. It's taped over for now, but I'll tape the powdercoat off and spray the VIN with a few coats of clear.
1974 Honda CB550
« Reply #42 on: February 12, 2016, 12:51:09 PM »
That's the first time I've seen that done.  PC usually shows through - I've never seen it caked on so thick that it completely obscures the stamp.  With clear, it will look cool.
Online Stev-o
« Reply #43 on: February 25, 2016, 05:07:22 AM »
Great looking parts there, Jeff.  Should keep you busy for awhile.
Offline Jeffro93
« Reply #44 on: February 29, 2016, 06:39:16 PM »
Quick picture-less update:
The engine cases are painted and the clutch cover, drive cover, etc. are polished.  I will hone the cylinders, lap the valves and put the head back together this weekend.  I don't expect the new rings to arrive until early next week.
In preparation for having the rings on hand, I would appreciate a few pointers regarding installing the cylinder block onto the cases after a top-end rebuild.  This would be a much simpler step with the cases open...  I think I've seen a few threads where this was discussed, but I can't seem to find them.  Since there's I can't use a sleeve for the rings and need to be able to do two pistons at a time, I really want to know what I'm doing instead of making it up as I go.
Thanks,
Jeff
1974 Honda CB550
« Reply #45 on: February 29, 2016, 10:44:27 PM »
the rings have to be compressed to slide into the bores and two at a time...  Just be patient and compress them with a sleeve that can be parted and pulled away. Even a hose clamp can do it if you take the time to unscrew the worm drive all the way...just more fiddly.
supporting cylinders on both ends with a board to keep them from making it harder with weight from them pressing down on your work... before it is ready.
Shouldn't need any hammers unless a deadblow plastic as you don't want to force anything and cause more issues with broken ring or worse...
I'm not sure of a good thread to direct you too either off hand...
Offline Jeffro93
« Reply #46 on: March 20, 2016, 07:04:48 PM »
In case anyone thinks I gave up or died (though I doubt I've crossed anyone's mind).  I got the cylinder block on today and put the engine in the frame.
It seems to me that it's much easier to put the engine in the frame at this point than after it's fully assembled.  It was a breeze to install and NO SCRATCHES on the frame. Plus, I got to spend an afternoon in the garage with my dad - doesn't happen much any more.
I'm in the process of lapping the valves now.  Once I've got the head/cam cover installed, I'll focus on lacing the new rims (stock) to the vapor blasted hubs.
1974 Honda CB550
Offline Bootsey
« Reply #47 on: March 20, 2016, 07:20:04 PM »
That's one tidy looking bike in the making, nice work.
Online Stev-o
« Reply #48 on: March 20, 2016, 10:25:23 PM »
Looks fantastic, Jeff.  Glad your not dead!
Offline Jeffro93
« Reply #49 on: March 21, 2016, 06:41:14 PM »
thanks for the heads up on that, Calj.
1974 Honda CB550
