Author Topic: What are some specialized motorcycle tools I can add to my xmas list for family?  (Read 3925 times)
Offline ChopSticks
Tools that aren't so common but anyone that is wrenching on their bike would need to use eventually such as carb syncs, compression tester, spark plug gapper etc
For example: I've got Cam-lock straps and Timing light so far
Offline WV_750
JIS Screwdrivers. They have been the most satisfying tool purchase for my bike.
« Last Edit: December 21, 2015, 09:24:14 AM by WV_750 »
73 CB750 K3
76 CT90
78 CT90
07 CB900F (919 Hornet)
+1 to JIS screwdrivers
Impact wrench (w JIS tips)
feeler gauges for valve and points gaps
vac sync gauges w long motion pro adjuster tool
multimeter w diode tester function, dwell meter
Mini kit of metric wrenches to take with you on your bike. I have a small roll of titanium wrenches.
Offline Magpie
Carb jet cleaner tool. I'm forever looking for pieces of the right sized wire to use.
https://www.canadasmotorcycle.ca/bikemaster-carburetor-jet-cleaning-tool-26-03a.html
Cliff.
Offline mycoal
Ultrasonic cleaner
Chain breaker
Ratchet straps
Aux gas tank
Snap ring pliers
Brake bleeder
Gauge feelers
Torque wrench set
easy outs/bolt extractors
Tap and Die set
Volt meter
1978 CB750K with 1977 GL1000 front end
  Bike cover, tire spoons, tire gauge, truing/balance stand, honda SOHC4 shirt,  test light. Harbor freight bike lift, if you've been really good.
Offline Gene
  • Chat enuf you too can be a
Spare bike to ride while the other is being worked on.
It won't fit in a stocking, though.
*1973 CB750K3 (Bow)
battery tender....
Offline Gene
Tire spoons - indispensible.
*1973 CB750K3 (Bow)
Offline wowbagger
  • Not much of an
Aux gas tank
Tap and Die set
+1 on both of these. My full metric tap and die set have been invaluable. You never realize how much you need an aux tank until that first time you tank falls off the bike and dents because you propped it up while you were working on the engine. My gas "IV" make tuning so much easier.
Offline przjohn
Motion Pro Clutch, Gear, and Sprocket Holding Tool.
Offline b5rider
a thin-walled spark plug socket.
I use the plug wrench that came with my original tool kit and it's still the best for changing spark plugs because there is little room in the 550 cases
1984 Honda Elite 150
1998 Yamaha 650
2004 Honda 750 ACE
1975 CB550
1978 CB400A
1978 CB550 now 603cc w/sidecar
The key to life is to make sure the line to put flowers on your grave is longer than the one to piss on it.
Offline mycoal
A punching bag and bottle of alcohol.
Offline Magpie
A small supply of Band-Aids too. Cliff.
Offline camelman
  • Man... Myth... Legend
This: https://store.snapon.com/Flex-Combination-mm-Wrench-Metric-Combination-Flex-Head-Open-End-10-mm-12-Point-P642105.aspx
My favorite tool and absolutely worth the money.
A close second is a10" set of forceps.
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
Offline Magpie
Probably at the end of your list but if you have the space and money purchase a lift. I've messed with bikes for awhile and just recently bought a lift. I should have bought one years ago!
http://www.harborfreight.com/automotive-motorcycle/lifts-stands/1000-lb-capacity-motorcycle-lift-68892.html
Cliff.
Made me laugh!
Offline Gene
Made me laugh!
Yeah, me too.  And actually a good suggestion.  Beats throwing the tools on the ground as hard as can . . . having them come back up off the concrete and take a fairly decent bite out of your arm and/or fingers.  Not that I'd know anything about that . . .
*1973 CB750K3 (Bow)
Offline mrbreeze
  • Not your average
Made me laugh!
  ;D ;D ;D HA!.....you too? I've probably done that a time or 5 over the years......not so much nowadays!! Done the old punch the wall too! That drywall can be expensive to fix and if you don't aim right and hit a stud.....well you can imagine!! Don't have to do it too many times before you learn better......
MEMBER # 257
Offline Restoration Fan
  • My wife will never call me
Don,
You happen to have a link to the set you bought?  I've been looking at a few sets to get for Stella but if you already have a set you like, I'll just buy a set of those.
Offline ChopSticks
Thread pitch gauges? Stereo system?
Poster of hot girl?
What's a thread pitch gauge for?
Offline danyo
For measuring pitch on threads;)
Sent from my SM-N900T using Tapatalk
   So, what did you get? I got two bike covers.
