Thanks!
The bike was running when I bought it in Hollywood, I rode it back to Marina Del Rey to my house (30 min ride).  I was missing a little bit under partial throttle, but nothing extreme.  I assumed the carbs needed to be cleaned or synced.
BUT
Yesterday things got interesting... I started it, it idled and revved fine, but when I started off, it felt like I was trying to take off in 4th gear and would die under any load.  Then later on I started it again to see what was going on, but now it wont even idle without dying.  It will start up (with some throttle), rev up a little bit but will die as soon as I let off the gas (even once it is fairly warm).
I have noticed that there was a small puddle of gas under it right when I stopped riding (the day it was running) and I traced it to the petcock area or one of the two lines coming from it.  I'm guessing that is related.
Would you guys suggest pulling the carb and rebuilding?
I am going to take it down to the frame, paint and reassemble into a really minimalist 'cafe' style, so I was planning on doing a lot of this work, but am curious if I should build the bike and get it all working and healthy, then pull it apart for paint and the beautification or if I should just tear it down to a frame now and build everything from the ground up?
