Author Topic: 1974 CB550. Racetech Monoshock. JMR Head. Built Engine. "BLAC"  (Read 209762 times)
Offline BLAC
  • An espresso is a
Re: 1974 Honda CB550 Build. It's cash fire time.
« Reply #100 on: February 28, 2016, 09:30:35 PM »
I have looked through their site a few times, they just dont really list what is compatible for specific bikes.  I think I'm just going to have to wait until mine is town apart so I can see and measure everything I will need.
If you can't fix it with a hammer, it's an electrical problem... If it's an electrical problem, it's Cal's problem.
*2005 Yamaha R6 (sold)
*2014 Ducati Streetfighter 848 (sold)
*2014 BMW S1000RR (sold)
*2010 Ducati Streetfighter S
*1978 CB550 Restomod Build
*1974 CB550 Monoshock build
http://forums.sohc4.net/index.php/topic,154614.0.html
« Reply #101 on: February 28, 2016, 11:25:25 PM »
I got mine from Jay at Lossa. It's about a $15 part.
Offline apehanger550
« Reply #102 on: March 05, 2016, 10:31:27 AM »
Tragedy has struck... well that's a bit of an exaggeration.
On the LAST carb I was rebuilding (finally feeling really confident about knowing how they work and go together) I noticed that the previous owner must have dropped one of the carbs without the bowl on it because one of the posts that holds the float has been broken off and glued/JBwelded back together  >:(
Does anyone have a carb casting (cylinder 1) for a 74 550k for sale?  I would like to replace this with a casting that isn't held together with putty  :'(
  I have a set of carbs bought for parts for a CB550 1977 and I do not know which one of mine has a broken post. [either#1 or #4] If you would like a body for 30.00 and you think mine might fit, that is something to consider.
Offline BLAC
  • An espresso is a
« Reply #103 on: March 07, 2016, 11:32:25 PM »
Thanks, but those are a different style carb.  I went ahead and am sending it out to be re-welded back on.  that way they are all a matching set, look the same and I can rest easy ;)
Does anyone has a source for where I can buy an OEM rebuild kit for my 74 cb550 petcock?  The model for the whole assembly is
16950-300-020, and I can buy a new OEM one for $45 shipped... I'm thinking it might be worth just doing that vs trying to find a kit and rebuilding it...?
Offline BLAC
  • An espresso is a
« Reply #104 on: March 10, 2016, 08:19:54 PM »
more parts being dropped off almost daily.  It's going to be a fun month =)
Offline GV1390
  • Express Gratitude.
« Reply #105 on: March 11, 2016, 06:42:07 AM »
Thumbs up, homie!  8)
08' Ducati S4RS, 71’ CB500, 71' CL350, 72' R90/6, 16' Ural Gear Up & 02' ZRX1200R.
« Reply #106 on: March 11, 2016, 09:14:16 AM »
Always a positive bump to get new parts in the mail.
Offline BLAC
  • An espresso is a
« Reply #107 on: March 26, 2016, 03:33:59 PM »
New petcock came in the mail, and my broken carb body is almost back from Jim French.  Thanks again for that suggestion, he did a great job on it from the pics he has sent and the price was great!
I should have the bike running in the next couple days and then the big teardown begins.
I think I will end up replacing the stock wheels with alloys, either Sun or Excel.  I want 18's front and rear, what are good widths to go with front and rear?  I dont want overkill on either, just a little wider.  Anyone liking their setups a lot?
« Reply #108 on: March 27, 2016, 05:33:02 AM »
18x2.15 front, 18x2.50 rear. Pretty common widths to allow 110 front tire and 120 rear. Appears pretty close to stock. You can go 2.5 front and 3.50 rear and use 120/140 front and rear if you want a more modern tire.
I'd still go 110 on a 2.5 inch x18, My gixxer1100 had 18 x 2.75 front with a 110, stock sizes,  A 120 front needs at least a 3 inch front,  ideally 3.5. I know we are talking 18's here but,  almost all sport bikes run a 17 x 3.5 front with a 120 tire, smaller diameter rims can accommodate slightly wider tires , but in saying that, my old GPX750R Kawasaki had a 16 x 2.5 inch front and also ran a 110 tire... ;)
Offline Lostboy Steve
« Reply #109 on: March 27, 2016, 05:49:28 AM »
I run close to factory sizes on my 77.  I had previously run a 110 on the front and a 110 on the rear and it handled pretty good. On the 75 I run a pretty fat and tall 16" on a comstar.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline Camrector
« Reply #110 on: March 27, 2016, 09:14:19 AM »
Guess it depends on the look your going for.
I'm running 17x3.5 fronts and 17x4.25 rear on this one build. This allows a 120 front and 150 rear.
Another 550 build I'm doing has the more stock 18x2.15 and 18x2.75 rear.
17s on your bike would looks sweet!
Offline GV1390
« Reply #111 on: March 28, 2016, 04:24:39 AM »
I'm running 18 x 2.5 F&R.
Offline Camrector
« Reply #112 on: March 28, 2016, 10:25:50 AM »
And super messed up geometry!
Offline BLAC
  • An espresso is a
« Reply #113 on: March 28, 2016, 12:56:28 PM »
I really like the look of this bike's wheel/tire combination.  I think I want to go with 2.15 / 2.5 18"  Shouldered Takasago wheels, I just need to figure out the tire setup.  It's tough because not many bike articles go into tire detail...
http://www.japanriders.com/showthread.php/1204-Honda-CB550-by-Raccia
Offline Camrector
« Reply #114 on: March 28, 2016, 02:42:26 PM »
That's a beautiful classic. My only concern is that you have already purchased modern
components for your build, then to add a more classic wheel combo would look wonky.
Those forks you have are pretty beefy, and need a beefier tire to look right. Does that make since. Classic with classic, Modern with Modern
I too love that classic look hence building a second 550 for my girl in that style.
« Reply #115 on: March 28, 2016, 02:52:34 PM »
 ;D ;D ;D :P
120/80/18 for the rear and 100/80 or 90/18 front... I'd go the 100/90/18 front for the street .
« Last Edit: March 28, 2016, 02:58:53 PM by Retro Rocket »
Offline BLAC
  • An espresso is a
« Reply #116 on: March 28, 2016, 03:17:33 PM »
And that is with the 2.15 / 2.5 rims?
Offline BLAC
  • An espresso is a
« Reply #117 on: March 28, 2016, 03:19:22 PM »
I have decided to not use the GSXR forks.  I am going with Race Tech springs + Gold Valve Emulators.  I decided to stick with the classic styling of the bike =)
« Reply #118 on: March 28, 2016, 03:33:53 PM »
Yes, the 2.5x18 is the rear 120/80/18 , the front 2.15x18 is 100/90/18, that is of course if you use 18's front and back...  It can be a little difficulty finding sizes to suit but most manufacturers will have a size chart somewhere on their site.. I have rim sets in 3.5x18 R  with 2.15x19 FR...3.00x 18 R with 2.50 F and 4.5 x 18 R with 2.75 x 18 F {being modified soon} , all going on 750/4's.... ;)
Offline Camrector
« Reply #119 on: March 28, 2016, 04:19:51 PM »
Noted and RAD!
Offline GV1390
« Reply #120 on: March 28, 2016, 04:37:20 PM »
I'll run mine against yours (with you riding it) around the track whenever you'd like. Please bring money.
Text if you'd like further details instead of derailing a thread.
« Last Edit: March 28, 2016, 04:39:32 PM by GV1390 »
Offline BLAC
  • An espresso is a
« Reply #121 on: March 28, 2016, 04:40:07 PM »
Offline BLAC
  • An espresso is a
« Reply #122 on: March 28, 2016, 05:03:34 PM »
Sounds like you have your hands full =P
Im thinking the Avon ROADRIDER AM26.  They come in 100/90 - 18 and 120/80 - 18
« Reply #123 on: March 28, 2016, 05:13:52 PM »
Hahahaha  ::)
Hands full, not enough money, slow and steady wins the race... ;)
Offline BLAC
  • An espresso is a
« Reply #124 on: March 28, 2016, 05:29:27 PM »
Well I am the slowest and the steadiest with a non-running bike sitting on its center stand... So I have that going for me, which is nice.
