Author Topic: Better late than never?  (Read 1661 times)
« on: June 08, 2016, 05:37:00 AM »
I never knew this, I must be pretty thick in head.
Offline dusterdude
Re: Better late than never?
« Reply #1 on: June 08, 2016, 05:44:33 AM »
Depending on brand of plug
Sent from my LG-D850 using Tapatalk
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
« Reply #2 on: June 08, 2016, 06:04:06 AM »
Also depends on plug cap. The OEM Honda caps use plugs with the terminal nut removed. If you are using after market coils and plug wires, they usually require the terminal nut in place.
Offline Rookster
« Reply #3 on: June 08, 2016, 06:55:28 AM »
Those things are a pain.  On my Triumph I need them in place but they constantly loosen due to the vibration.  They need a hex cut into them to tighten properly.
Scott
« Reply #4 on: June 08, 2016, 07:07:36 AM »
None of the NGK's or ND's I purchased over the years came with these terminal nuts.
« Reply #5 on: June 08, 2016, 07:15:48 AM »
Yeah, once I'd sourced a serving of them, I have to remove them from the old plugs and install on the new plugs. I have Accel plug caps and wires.
Offline strynboen
« Reply #6 on: June 08, 2016, 08:23:16 AM »
vas they not used in easatern Europa.?.
.in West ve had them..all over..both bosch and champinon had them as ekstra in the box.
.ngk often have  the big end veldet on..so no screv off tap
i hate all this v-w.... vords
Offline DaveBarbier
« Reply #7 on: June 08, 2016, 09:44:14 AM »
Me either! Not until about a year ago when I was helping a friend with his KZ750. Couldn't figure out why the plug cap wasn't fitting right on the plug. His girlfriend told us there's a screw cap on the end. I didn't ask how she knew that.
« Reply #8 on: June 08, 2016, 11:03:07 AM »
That nut was standard on most of the plugs many years ago .
Offline strynboen
« Reply #9 on: June 08, 2016, 11:14:56 AM »
i had a Ferguson tea 20 from 1949...learned it vhen i thanged plugs on that old beast
Offline simon#42
  • liverpool
« Reply #10 on: June 08, 2016, 02:29:44 PM »
you boys are slow ! they are a throwback to the days before plug caps , the ignition lead had a spade connector on it which fitted on top of the plug then you screwed the metal top on
Rookster , just solder them on
Offline 333
  • Time for change
« Reply #11 on: June 08, 2016, 09:20:12 PM »
These durn kids today.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline strynboen
« Reply #12 on: June 09, 2016, 02:08:55 AM »
no the schrev on vire spade type had a" roletted "finger  teighnted bolt head ..its a 3.. different vay to do the same..job
Offline simon#42
  • liverpool
« Reply #13 on: June 09, 2016, 01:42:41 PM »
this old bmw shows what i mean
« Reply #14 on: June 09, 2016, 01:52:58 PM »
I know what you're saying. But there are semi-modern plug caps that require the nut to be in place.
Offline simon#42
  • liverpool
« Reply #15 on: June 09, 2016, 03:42:34 PM »
yes but the plug came first , the latter caps were designed to fit it
« Reply #16 on: June 09, 2016, 04:28:26 PM »
You sure? I have D8EA's on the shelf and the nut screws off.
My RD uses NGK B8HS and I need to take the nut off to fit the stock cap on.
