Author Topic: CB 550/650 Daily  (Read 47217 times)
Offline Camrector
Re: CB 550/650 Daily
« Reply #100 on: July 28, 2017, 09:07:22 AM »
Progress.
Offline DaveBarbier
« Reply #101 on: July 28, 2017, 01:31:30 PM »
Looks great so far dude
Offline Camrector
« Reply #102 on: July 28, 2017, 02:43:15 PM »
Thanks Dave. I was able to test fit the Kerker 4-2 exhaust and it fits like a glove on the 76 cb550 frame
« Last Edit: August 12, 2017, 09:55:06 AM by Camrector »
« Reply #103 on: July 29, 2017, 07:02:53 AM »
Well, heck YES.  Looking good.
Cam, can you elaborate a little on your front fender.  It appears to be a custom piece in terms of both the fender and mount.
Offline Lostboy Steve
« Reply #104 on: July 29, 2017, 07:16:23 AM »
It looks like the stainless steel eBay one that is direct fit.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline Camrector
« Reply #105 on: July 29, 2017, 07:55:11 AM »
Correct Lostboy. Just a motolanna shorty fender from ebay
« Reply #106 on: July 29, 2017, 08:16:35 AM »
The bike looks very clean, Cam. I'm digging the Lesters.
Offline Camrector
« Reply #107 on: July 29, 2017, 09:07:36 AM »
Thanks Don.
I really like the polished and vapor blasted metals together. Helps maintain that classic 70s look.
Offline Camrector
« Reply #108 on: August 12, 2017, 09:31:34 AM »
Progress report.
Installed the new charging system(rotor, stator, and brushes) neutral and oil switch done, finished rear set
linkage and installed the exhaust. Kerker exhaust fits very nicely on the 76 cb550 frame, just need to reposition the kickstand mount slightly.
[im
Offline Camrector
« Reply #109 on: August 12, 2017, 10:28:31 AM »
Offline work9to5
« Reply #110 on: August 12, 2017, 01:11:01 PM »
Looking good Cam! Havnt read through the thread yet, tank options? What are you going with stock?
Offline Camrector
« Reply #111 on: August 12, 2017, 02:23:03 PM »
Yup Chris, stock 550 tank. Fresh candy garnet brown paint.
« Reply #112 on: August 12, 2017, 02:59:55 PM »
With modern paint it will not have that great color shift fading effect, given it was a two color application originally that yielded the look...
Nice work!
David
« Reply #113 on: August 13, 2017, 09:17:17 AM »
This is going to be a nice sleeper.
Offline Camrector
« Reply #114 on: August 13, 2017, 11:19:53 AM »
That's the goal Don and thanks.
Offline Camrector
« Reply #115 on: September 06, 2017, 03:19:14 PM »
Wiring is almost finished, carbs installed, new oem gauges, all the little things....
Sadly my Cognito airbox for the cb750 carbs doesn't fit the frame...
« Reply #116 on: September 06, 2017, 03:53:50 PM »
Bummer about the airbox! Could it be modified to fit?  Are you using an m-unit?
Offline Camrector
« Reply #117 on: September 06, 2017, 05:09:32 PM »
Not without chopping the frame up, Don. There just isn't any room on the 550 engine cradle. 650 motor plus 750 carbs plus 550 frame, I should have expected something not to work lol.
Yes using a motogadget and mlock.
« Reply #118 on: September 06, 2017, 09:32:55 PM »
Maybe a modified box into a single large filter.  I think Cameron Bateman did that on his Rusty Olive.  +1 on the Motogadget gear.
Offline Camrector
« Reply #119 on: September 06, 2017, 09:50:11 PM »
That or pods it looks like.
Offline sethmcalister
« Reply #120 on: September 07, 2017, 08:02:13 AM »
Let me know if you have plans to dispose of the CM airbox, I may be interested...
Sent from my Pixel XL using Tapatalk
Offline Camrector
« Reply #121 on: September 07, 2017, 10:19:22 AM »
^PM sent!!!
« Reply #122 on: September 07, 2017, 10:22:07 AM »
Are you taking the plunge into Pod-dom?
« Reply #123 on: September 07, 2017, 10:40:11 AM »
Could longer intake tubes be fashioned to put the filter box in the triangle, if you have this area clear or could open up enough space for them?  My tablet doesn't play nice with some photos and currently is not displaying the...often true for anything uploaded through tapatalk and hosted on a few of the image hosting sites.  Time for a new tablet when I can save the money forcaother that won't obsolete...ipad most likely this time.
« Reply #124 on: September 07, 2017, 12:46:11 PM »
I have the same space constraints, although I'll likely be using CR26 carburetors.  I wonder if someone talented like Nick could fab an airbox similar to a Cognitomoto one that could be used by Cam, me, Dave and Nick.
