Author Topic: CB 550/650 Daily  (Read 46730 times)
Offline Camrector
CB 550/650 Daily
« on: February 09, 2017, 11:42:22 PM »
Hey guys.
While work continues slowly on my Cb592 racer build, I thought id share some updates and upgrades to my 550 daily. While wrapping up my ladies "Gentlemens Express" build with sinister, I picked up a beautiful 76 cb550 for myself. This bike was really meant to be left alone, but come on who are we kidding.
Inspecting and cleaning with son #1
PO had everything there except the paint color. So some of this:
Gets us this:
After enjoying the bike for most of the summer and eating the ladies dust, it was time for some upgrades.
The goal of this project is to keep reliability, 70s style, and as much period correctness as possible. While some modern upgrades will happen, those will be as un seen as possible. So i quick call and a short last ride brought me to my buddies Dave at Broken Sprocket Garage. We quickly got to work and i needed a ride home.
Nils doing his thing
19f/18r Lesters
Godffreys dual disc
Forks were rebuilt with Race tech emulators and springs, and polished the lowers.
cleaned up and rebuilt the swing arm
Everybody is doing 650 motor swaps so add me to the club
This 79 cb650 motor has 8000 original miles. Covers are currently getting a "touch of Nils"
Which all brings us here.
Ikon rear shocks courtesy of Nils
All parts are ordered and on the way.  Upgrades will include C5 ignition, full Motogadget system, new charging system, Hindle header, cone engineering muffler, 78 cb750 carbs, cognito airbox, led lighting, cb650 tach and speedo, period controls with larger bore for the dual disc, and a few things im sure i missed.
Ready for spring.
« Last Edit: July 19, 2017, 10:34:05 PM by Camrector »
Re: CB 550/650 Daily
« Reply #1 on: February 10, 2017, 12:00:29 AM »
Since those stock 4-4 pipes are no longer needed, I will gladly give them a home!
PM me if you want to part with them.
Offline Camrector
« Reply #2 on: February 10, 2017, 12:04:17 AM »
^Yours brother
« Reply #3 on: February 10, 2017, 06:49:12 AM »
It's a tasteful looking bike. Only thing I'd question is why stay with stock gauges? The reason I ask is not to say that stock clocks are good/beautiful, but doesn't the Lester swap make for a speedo gear issue? Or have you resolved that? Besides, for as clean as the bike is, why have the cable hanging down and looking "floppy"?
I use the stock clocks on my blue 550 with Lesters.  You just need to modify the speedo plate for the dual disc set up.
Offline Camrector
« Reply #4 on: February 10, 2017, 07:01:04 AM »
The brake kit came with the speedo drive already modified for the dual disc. But I'll double check to see if all is well.
Offline DaveBarbier
« Reply #5 on: February 10, 2017, 07:06:36 AM »
Any motor upgrades? The 674cc seems to be a popular direction these days :)
Offline Camrector
« Reply #6 on: February 10, 2017, 07:22:29 AM »
Not yet Dave. I'll probably just ride this around all spring summer and fall. Then next winter upgrade the top end. Main goal here is a rideable, reliable, bike to ride.
Currently getting my engine build fix with a cb592 11.5-1 cr , mike Reick stage 4 head, megacycle 126-20 etc etc.
Offline joeyvans
  • Definitely not a
  • God's Country, Earth
« Reply #7 on: February 10, 2017, 07:30:30 AM »
Subscribed!
What front fender is that, Cam? Modified original or some aftermarket source?
1976 CB550 K2
Non-SOHC4 - 1974 CB450 K7
Non-SOHC4 - 1996 VFR750F
"No matter how much you shake and dance... the last three drops go in your pants."
Offline Camrector
« Reply #8 on: February 10, 2017, 07:44:30 AM »
Subscribed!
Thanks brother! And good eye. That's the motolanna front fender, from flea bay. Modifying the rear fender though.
Offline joeyvans
  • Definitely not a
« Reply #9 on: February 10, 2017, 07:51:35 AM »
Are they making a direct replacement bracket now for CB's? Or will it need to be modified? I assume it will need to be modified regardless for the dual discs.
Looks great!
1976 CB550 K2
Offline joeyvans
  • Definitely not a
« Reply #10 on: February 10, 2017, 08:19:52 AM »
Nevermind.... found my answer. It appears they have 3 different options for SOHC's now.
I may have to purchase one of their "shorty's." Looks good!
1976 CB550 K2
« Reply #11 on: February 10, 2017, 08:21:37 AM »
Looks like the Goddfery dual disc kit.  Countersunk rotor mount holes so you can re-use the stock bolts; lightened, thinned and drilled rotors.  Great stuff.
The paint came out nice, too.
Offline Camrector
« Reply #12 on: February 22, 2017, 01:41:27 PM »
Well after reading through all of Daves amazing cb650 build thread, I couldn't resist.
Pulled the trigger on some go fast parts and boom Christmas in February!
Head is getting the Mike Rieck "touch of excellence", so motor can be buttoned up in a few short weeks.
674 kit, c5 ignition, Yoshi 122-00 cam, Hindle header, cognito airbox (with matching engine case paint), and I think we know what the skittles mean!
« Reply #13 on: February 22, 2017, 02:05:25 PM »
Well, so much for a stock bore motor! I guess in for a penny, in for a pound!
Looking forward to seeing this come together.
« Reply #14 on: February 24, 2017, 05:34:25 PM »
At least one of you fellas (maybe all y'all) will have to get some dyno numbers with these 674's for bragging rights!
Offline Camrector
« Reply #15 on: February 24, 2017, 06:13:14 PM »
I want to dyno all three motors together
Gentlemens express build, 592 high compression motor, and this one. Graph them together and break down the HP in dollars spent. So 1 hp costs X kind of thing.  ;D
Offline BLAC
  • An espresso is a
« Reply #16 on: February 24, 2017, 09:12:13 PM »
Don't put yourself through that math  :-X :'(
Haha
If you can't fix it with a hammer, it's an electrical problem... If it's an electrical problem, it's Cal's problem.
*2005 Yamaha R6 (sold)
*2014 Ducati Streetfighter 848 (sold)
*2014 BMW S1000RR (sold)
*2010 Ducati Streetfighter S
*1978 CB550 Restomod Build
*1974 CB550 Monoshock build
http://forums.sohc4.net/index.php/topic,154614.0.html
Offline Camrector
« Reply #17 on: February 24, 2017, 09:29:06 PM »
It's for posterity ;D ;D ;D
Offline flatlander
« Reply #18 on: February 25, 2017, 12:37:49 AM »
do it. skip the $/hp bit if it worries you, but do the dyno part. posterity will be indebted to you for eternity.
« Reply #19 on: February 25, 2017, 12:40:48 AM »
You guys and your Skittles...someone keeps going on about Skittles and "Tasting the Rainbow".  Ran across this from moons ago in the Babe Thread. Thought I would share it.
« Reply #20 on: February 25, 2017, 12:52:20 AM »
Wouldn't your comparison be more valid if the head work and cam was the same across all of the comparative test units?  Having different cams and exhausts will impact the performance potential. The carbs kind of tie into the solutions to a certain extent don't you think?  The Gentlemen's Express using those recommended within that document...
Ignition systems shouldn't make a huge difference, unless you believe the hype. Only way to prove it makes a difference is dyno with one system and then swap in the other in the matter of hours of first testing so environmental changes are not impacting the results as much, right?
So, fresh plugs and all using the same fuel.  If it is going to compare things then it really needs to do the job to reduce a few things that could skew results, right?
But, what do I know.
David
« Reply #21 on: February 25, 2017, 04:16:13 AM »
Even a simple ignition change can make a difference, 4hp in my case. No other change except ignition. Probably not that the new one made any more power, but that the model being replaced wasn't up to snuff.
« Reply #22 on: February 25, 2017, 04:21:29 AM »
Wow Brent, didn't realize that would be a huge factor.  In race apps like your bike you are probably at higher rpms than most riders would do and it is capable of higher revs due to nice blueprinting and balancing, and porting to crank out the numbers and perf of your bike.
I can see how a system could run out of steam unable to keep up or build sufficient spark or consistent spark to achieve the higher performance.  Just never thought about it...
Offline flatlander
« Reply #23 on: February 25, 2017, 04:48:44 AM »
uh cal i wish i had a sip of whatever that is in your glass! 50+ at the rear wheel is closer to the truth ;)
and yes, +1mm in valves, 12600cam, 59mm 10:1 wiseco pistons, mike's stage 2.5 head.
« Reply #24 on: February 25, 2017, 05:02:01 AM »
50+ is realistic though. I have a 592 with a small Web, stock valves & carbs, and it's 51 @ the wheel. Very much fun to ride.
