Author Topic: Blue K2 750 "Louisville Bike"  (Read 18103 times)
Re: Blue K2 750 mystery bike "Louisville Bike"
« Reply #25 on: September 07, 2019, 04:15:26 PM »
 I think the taillight covers a weld too. The PO made a fender like it on the drag bike but didn't take the time to weld, it was flopping by the time I got it. Rivets could work too.
« Last Edit: January 25, 2021, 11:42:07 AM by Don R »
« Reply #26 on: January 18, 2021, 06:45:31 PM »
 The best laid plans of mice and retired Plumbers.
  Old blue has been in storage, as there always seems to be a 750K0, Dragster or Street Rod ahead of it in line. It's in my race trailer right now in a building across town. It's going to collect the hot rod parts as I return other 750's to original.
  Blouisville ?
« Last Edit: January 18, 2021, 07:27:56 PM by Don R »
Re: Blue K2 750 "Louisville Bike" update on no progress.
« Reply #27 on: February 12, 2021, 10:08:27 PM »
 This one still has a plan, it's a k1/2 hybrid. I built a K1 and promptly sold it to David Silver, I regret that so I'll copy it.
  2013 Honda Accord tiger eye pearl brown with K2 gold/pearl white/black stripes. I have k2 chrome headlight ears with K0 reflector threads, I may paint a set of K0's for it though, it has a DSS repro seat already and hooker 4-2 headers.
« Reply #28 on: February 22, 2021, 11:06:51 PM »
 I'm saving the brown tank off of my K0 for this bike. As mentioned it will get painted Accord tiger eye pearl brown with gold/white/black K2 stripes, I may use some new K0 sidecovers on it, since it's a resto mod it may as well be a total confuser. I have chrome headlight ears welded and tapped for small reflectors, another deception.
  I've already laced up a set of 750 A rims, ready for tires, with the engine performance mods I'm leaning towards using the A front forks with double discs, I'll just need another center outlet caliper. I have a yoshi looking header but it has a way too long muffler, works and sounds awesome looks wrong, I believe it came off of a dohc bike.
  This engine has a big bore kit of unknown size. The engine guy remembered building it but said around that time they were short on 836 kits he couldn't say for sure what it had in it. The PO claimed 836 but I know how that goes. Honda Euro bars for sure.
« Last Edit: February 22, 2021, 11:14:18 PM by Don R »
Re: Blue K2 750 "Louisville Bike" update on accidental progress.
« Reply #29 on: March 14, 2021, 10:33:56 AM »
 More accidental progress, I was straightening out the shop and found the new set of 400f handlebars I bought a while back, Will work instead of the euro bars. Now to order up a set of short cables for it. Today I'll look for the long rotor bolts for the double disc. Since it's a 72 and not going to be a restored bike at all I think I'll use the 76A forks I got last year, I like the center inlet calipers and have the one already.
« Reply #30 on: September 30, 2021, 02:14:40 PM »
   I found a k2/k3 front end in my brothers storage unit today with a center bleeder caliper on it. It has separate turn signal holes and a beeper, 73? After making it into parts I now have a 76A fork and two sets of late center bleeder brakes for it.  I also have a K0 speedo drive and 5/16" bolts for the rotors. There is what I want for my late fork dual disc setup for the performance build. It has tall lowers so an F1 fork brace will work.
  I keep hearing about K2's with K1 engines so maybe this one isn't as part swapped as I originally thought. My wife thinks it's bad luck since the PO and engine builder are both deceased. I happen to think Karma will appreciate what I'm doing.
« Last Edit: September 30, 2021, 11:26:46 PM by Don R »
« Reply #31 on: October 01, 2021, 05:00:08 AM »
Yeah, don't worry about the "Deceased" thing Don, it's only when someone's killed on your bike (like the PO of my 2006 VTR1000F) that you need to worry, the old guy who built that bike is probably happy that you're getting it running again. ;D
« Reply #32 on: October 01, 2021, 11:15:20 AM »
 It was odd when I was putting my old dragbike back together every part it needed seemed to be within reach or in the top of the tote. It seemed like Karma was on my side until I borrowed the 400F handlebars for another project. It hasn't co-operated since then. lol.
 I'll see if the spirits approve when I take the drag bars off and put 400F's back on.
« Last Edit: October 02, 2021, 08:44:41 AM by Don R »
  Since this frame is not numbered and is a mish mash of K1/K2 stuff it might be a perfect victim of my parts collection. It has a nice hooker 4-2 already and an unknown big bore kit. We presume (PO said) it's an 836, the engine guy remembered doing it but didn't remember the kit for sure. So maybe I'll hang the Webers and an ARD on it, or at least the carbs and an old stock Dyna electronic ignition.
  I ordered a VIN tag from the ebay guy Switzerland. Around $40 he stamps the reverse numbers in it for you. He also had the proper build month/year printed already. He sent links to videos showing how to bend the plate to fit the neck tube and rivet the tag on. I'll need the proper drill bit also.
  I borrowed a set of number/letter stamps and will apply the title numbers to the neck as should have been done when the replacement frame was assembled. Too bad there isn't a Honda font number stamp set like there are for Harleys.
Re: Blue K2 750 "Louisville Bike" update, actual parts bought for it.
« Reply #35 on: August 12, 2022, 01:08:26 PM »
 The data plate, follow along for installation also frame neck number stamping.  I didn't see the drill and rivets until later, the plaque came with 3 rivets.
  https://www.ebay.com/usr/65ronron
  https://www.ebay.com/itm/254938865109?hash=item3b5b8a5dd5:g:mw8AAOSw2e1gdBNm
« Last Edit: August 12, 2022, 02:32:10 PM by Don R »
Re: Blue K2 750 "Louisville Bike" replacement frame tagging.
« Reply #36 on: August 14, 2022, 07:02:32 AM »
FYI - He has a website with more models and years available:  https://www.khneisser.ch/honda
« Reply #37 on: August 20, 2022, 07:56:36 PM »
 I may buy a plate for the K1 drag bike too, people removed them when getting show paint.  It's been raked 10* over but the stamped numbers are intact.
« Reply #38 on: August 21, 2022, 08:52:25 AM »
 Chopper forks, they are early type, have light freckling above the seals and on one side of both tubes. Rider quality probably not show quality.  Gurp asked about them, if a 750 chopper guy lived close enough to show up here, I'd make up a care package of chopper stuff.
« Last Edit: August 21, 2022, 09:02:22 AM by Don R »
Do you know how they stamped the factory/font frame numbers into the frame Don ?
« Reply #40 on: August 22, 2022, 01:44:30 PM »
  I do not, no Honda tech has ever told me they had factory number/letter stamps. I'm planning to use magnets or metal angle as a guide and stamp one letter at a time.
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #41 on: August 22, 2022, 05:04:54 PM »
PM replied on the forks.
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
"Alley Cat"  93 sportster
Offline 69cb750
« Reply #42 on: August 28, 2022, 07:24:23 AM »
The factory had a jig that held the stamps in place.
« Reply #43 on: August 28, 2022, 10:56:26 AM »
The factory also had a distinct font for the serial number.  The reproduction VIN plates look good and are close but are not the same font.
« Reply #44 on: August 28, 2022, 01:42:41 PM »
Did the dealers ever have a 'factory font' set of stamps;did they ever stamp a 'no number' frame with them ?
« Reply #45 on: August 28, 2022, 02:52:59 PM »
Interesting. I know that parts frames were made, but I'm not sure if they were stamped.  I know that some of the early engine cases that were replaced by dealers had no numbers on them.
« Reply #46 on: August 28, 2022, 03:24:04 PM »
Yeah,I'm curious if it was at the dealer's discretion to choose to either stamp or not to stamp them.. or did Honda tell them not to ??
I don't know anyone who worked in a Honda dealer back then,and HondaMan may be too busy to answer.
« Reply #47 on: August 28, 2022, 08:20:49 PM »
  I've been asking for years, no Honda tech or anyone here, ever replied that they had, or even saw Honda supplied stamps. If the tech didn't buy their own, the shop may have supplied a standard set of industrial stamps.
  There are a lot of unstamped engine cases, I'd guess the replacement frames are rarer.
Offline 69cb750
« Reply #48 on: August 29, 2022, 05:34:24 AM »
I worked in two Honda shops in 75,76,78
I replaced frames and cases, the frames and cases came in boxes, no instructions came with the parts, Honda did not sell vin stamps, I did not stamp them.
Frames are much rarer, I replaced one frame, several cases, when the chain flys off a CB750 the frame survives.
« Reply #49 on: August 29, 2022, 11:41:20 AM »
How did they deal with the DMV if the new replacement frame didn't have a VIN number stamped into it ?
