Author Topic: Wheel Lacing  (Read 2536 times)
Offline ef9tuning
Wheel Lacing
« on: September 27, 2017, 11:47:54 AM »
Followed Saltcitycafe guide on here for front wheel lacing. I think I have it correct but I wanted to check with the experts  ;D
Wheel photo with the pencil is the original
1978 CB750K
Offline disco
Re: Wheel Lacing
« Reply #1 on: September 27, 2017, 02:28:42 PM »
Yep looks fine to me
1976 CB750 K6 Sapphire Blue
1972 CB750 K2 Candy Red
1972 CB750 K2 Candy Gold'
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
Re: Wheel Lacing
« Reply #2 on: September 27, 2017, 02:35:15 PM »
Good work, have fun bringing it to tension!
Re: Wheel Lacing
« Reply #3 on: September 27, 2017, 05:37:34 PM »
Look at about 6:30 the two go Inc up cross , the other way they don't. .something is different.
How are the looking at nipple end?
Offline ef9tuning
Re: Wheel Lacing
« Reply #4 on: September 27, 2017, 06:43:58 PM »
Some of the nipples are protruding out. Doesn't seem as if they would all tighten down if I did.
1978 CB750K
Re: Wheel Lacing
« Reply #5 on: September 27, 2017, 06:46:16 PM »
You got them in there wrong.
 We need to find out how many they cross, and if I nners all go the same way.
Offline ef9tuning
Re: Wheel Lacing
« Reply #6 on: September 27, 2017, 06:57:30 PM »
ok so it looks like the inners are only crossing 2 spokes. I should move the spoke over to the next inner of the same side?
1978 CB750K
Re: Wheel Lacing
« Reply #7 on: September 27, 2017, 07:50:52 PM »
A few things that make it easier.
 Photos note whether Inners cross or not, count how many it crosses WRITE IT down..
And to help more measure angle between two spokes,  like just over 90 or just less, or even better cut a card board template. .. then youbwill catch a mistake at the beginning.
Offline disco
Re: Wheel Lacing
« Reply #8 on: September 27, 2017, 08:53:54 PM »
Good pickup Frank! Those googly eyes work better than mine! ;D
Re: Wheel Lacing
« Reply #9 on: September 28, 2017, 07:41:55 PM »
If I can 'see' it correctly, it looks like there are 6 places where the spokes are mis-placed?
Offline ef9tuning
Re: Wheel Lacing
« Reply #10 on: September 29, 2017, 11:35:32 AM »
Thanks for the input guys! I wont be able to continue this adventure until Sunday. :-\
The other evening I tried re-lacing them again following the directions to a T from here : http://forums.sohc4.net/index.php?topic=135846.0
Still ended with a similar result...I'm thinking that after flipping over the rim to do the second set of inners is where my issue lies.
1978 CB750K
Re: Wheel Lacing
« Reply #11 on: September 29, 2017, 11:38:58 AM »
Is it correct rim .
 When a rimmis drilled for inner both one way, it won't work for crossed Inners and vice versa.
Offline ef9tuning
Re: Wheel Lacing
« Reply #12 on: September 29, 2017, 11:54:16 AM »
Not sure if its OEM. I can see it says Takasago stamped on the wheel from the pictures Ive taken.
1978 CB750K
Re: Wheel Lacing
« Reply #13 on: September 29, 2017, 12:03:36 PM »
Compare the spoke hole exits carefully, the way they angle, between the rims,
But Inam guessing that they should be the same  since you managed to get the spokes in the rim.
Offline ef9tuning
Re: Wheel Lacing
« Reply #14 on: September 29, 2017, 04:33:00 PM »
Had 30 mins to spare so I gave it another go.... following exactly how the old wheel was in the picture. All nipples are at tension & each outer spoke crosses 3 inner spokes. I believe I’ve finally done it!
1978 CB750K
Re: Wheel Lacing
« Reply #15 on: September 29, 2017, 07:39:57 PM »
 Each innie/outie spoke skips one hole on the hub and skips three holes on the rim. Watch the rim holes for entry angle, you can see the angle side to side and left and right.
Offline thirsty 1
Re: Wheel Lacing
« Reply #16 on: September 29, 2017, 11:14:25 PM »
I had a real nice wheel lacing thread put together but good ol' PhotoBucket strikes again!! Funkers!!!!!!!
Re: Wheel Lacing
« Reply #17 on: September 30, 2017, 07:19:31 AM »
Many DIY's on Internet are no longer working due to PhotoBucket.  :( >:(
A photo take not much space if it is cropped showing what needed only and compressed. 100-300 kB is enough. All photos will be left in the description on site even after the author has left and closed the PhotoBucket account.
Write everything in Word and make a pdf of it even better. ;)
« Last Edit: September 30, 2017, 07:21:17 AM by PeWe »
Re: Wheel Lacing
« Reply #18 on: September 30, 2017, 10:18:47 AM »
There is a hack on Chrome and Firefox to get around Photo_ucket's greed.  Still works...I'm using Chrome. Couple out there, one by a guy I know from another forum...
David
