Author Topic: What did you do to your non-SOHC4 motorcycle today?  (Read 79109 times)
Re: What did you do to your non-SOHC4 motorcycle today?
« Reply #800 on: April 19, 2025, 06:14:31 AM »
Nice work Kelly. How big is that stapler? I have a dirt bike with a plastic seat that I need to recover……..
« Reply #801 on: April 19, 2025, 07:54:31 AM »
Nice work!
Offline Kelly E
  • Geriatric Hooligan
« Reply #802 on: April 19, 2025, 10:03:03 AM »
We got it from Harbor Freight a while back. It shoots T-50 style staples. We use 1/4" long staples for recovering plastic seat bases.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
« Reply #803 on: April 19, 2025, 11:40:14 AM »
Thanks Kelly….. I’ll look for one.
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #804 on: April 19, 2025, 12:49:28 PM »
Still dealing with this evo sporty. Reverse thread clutch backet nut came off and left all it's threads on the transmission mainshaft... Amazingly didn't hurt the thread on the shaft any. Waiting on that.
Did throw the cam cover on.
New oil and filter.
Did the static timing for the ignition.
Getting ready to pull the rear wheel for the swap there.
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
"Alley Cat"  93 sportster
Offline CycleRanger
  • No comment about being an
« Reply #805 on: April 19, 2025, 03:40:57 PM »
Discovered the three year old Yuasa battery in my XS650 has apparently moved on.
It will no longer take a charge.
*Sigh*  :P
« Reply #806 on: April 19, 2025, 08:04:17 PM »
*Sigh*  :P
I have been able to recover lead acid batteries by discharging with a load, like a headlight, and then charging it up to 15V, several times. Also, you might try a "smart" charger with a de-sulfation mode before giving up on it.
Offline CycleRanger
« Reply #807 on: April 19, 2025, 08:26:09 PM »
*Sigh*  :P
Yes I am going to mess with it a bit. Nothing to lose. It was fine less than a month ago.
Offline supersports400
« Reply #808 on: April 21, 2025, 10:28:14 AM »
Cleaned it, enjoyed it, and did put it back in my garage.
« Reply #809 on: April 21, 2025, 08:51:04 PM »
That's a nice looking sportbike.
« Reply #810 on: April 23, 2025, 07:13:32 AM »
That's a nice  GREAT   looking sportbike.
Fixed!
« Reply #811 on: April 23, 2025, 08:47:12 AM »
Fixed!
A race-bike. !!  :) ;D
« Last Edit: April 23, 2025, 08:48:56 AM by grcamna2 »
Offline Mikey G.
« Reply #812 on: April 29, 2025, 01:36:20 PM »
I got some of the kids out for air in the tires and some vanity shots.  No rides yet (been busy as all get out), but at least they all run.
-1970 CB750 K0
-1980 KZ1300
-1976 Yellow GL1000
-1965 CA77 "Dream"
-1997 Valkyrie
-1975 Velosolex
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #813 on: May 08, 2025, 10:41:58 AM »
Fixed the rear brake.
Took a 5 mile ride getting used to the foot clutch jockey shift.
Put the Honda on the lift.
Offline dusterdude
« Reply #814 on: May 08, 2025, 02:02:03 PM »
Rode it to work
Sent from my SM-S711U using Tapatalk
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline Mikey G.
« Reply #815 on: June 05, 2025, 05:01:13 PM »
Replaced the seals on my clutch slave cylinder on my Valkyrie.  The cylinder itself isn't bad- three bolt and the line.  UNfortunately, to get it off you need to remove the ENTIRE sidestand and, in my case, the center stand as well.  It's been an adventure.
-1970 CB750 K0
-1980 KZ1300
-1976 Yellow GL1000
-1965 CA77 "Dream"
-1997 Valkyrie
-1975 Velosolex
« Reply #816 on: June 05, 2025, 05:07:14 PM »
More than a task  :o
Offline spotty
« Reply #817 on: June 05, 2025, 06:11:25 PM »
More than a task  :o
i had to go through that, didn't bother putting the centre stand back on, made it all the easier to make the decision to sell it
i blame Terry
« Reply #818 on: June 06, 2025, 06:24:10 AM »
Took the mighty Z1 to the local fuel station for a tank of non-eth and then out for a ride....
Offline Magpie
« Reply #819 on: June 06, 2025, 08:45:27 AM »
Got some of the SuperSports ready for my Meet & Greet this coming Sunday.
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #820 on: June 06, 2025, 09:57:53 AM »
Swapped battery and stater on my sporty. Readjusted the clutch.
Now to clean the lift and teaat ride. 5 days till my trip. Haven't had a test pack or shakedown yet. Lol
« Reply #821 on: June 06, 2025, 12:10:47 PM »
I know you've Got to be looking forward to that !
Where do you plan to ride to ?
Offline Mikey G.
« Reply #822 on: June 06, 2025, 05:17:37 PM »
I use the center stand WAY too much to not put it back on, but I can definitely see where you're coming from.
For reference, the sidestand on a Valkyrie is on a bracket that's bolted to the frame, rather than welded, and the (aftermarket) center stand uses one of those bolts to attach.  This means you need to carefully thread a bolt that's almost impossible to see into the end of the center stand bracket, while fighting the spring on the stand itself.  Which wouldn't be so bad-
Except the bolts can't actually be REMOVED because the engine is in the way.  So if those get cross-threaded, you're pulling the motor (or something equally drastic).
-1970 CB750 K0
-1980 KZ1300
-1976 Yellow GL1000
-1965 CA77 "Dream"
-1997 Valkyrie
-1975 Velosolex
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #823 on: June 08, 2025, 01:24:37 PM »
Cave in rock IL
Its 385 miles from the house roughly
After gas stops and detours it ends up being around 400/410 each way.
That will be my first entry into franks thread for this year. Will prob ride about 50/70 miles a day while there given if its not raining.  The. A long ride home likely to be in the rain.
Today I'm just now going to get the bike off the lift. And check the clutch adjustment. Been busy and had a mishap changing some seized exhaust studs on the rear cylinder yesterday.
I ended up having a weld nuts to the studs then weld a socket to the nuts. Was a hassle lol.
« Reply #824 on: June 08, 2025, 01:30:08 PM »
Cave in rock IL
Good to hear you were able to remove and replace the old exhaust studs !
I hope you enjoy the journey.
