Author Topic: What did you do to your non-SOHC4 motorcycle today?  (Read 131446 times)
Offline WhyNot2
  • I'm finally an
Re: What did you do to your non-SOHC4 motorcycle today?
« Reply #975 on: January 09, 2026, 06:41:31 AM »
Laid out the tires in the sun to soften them. Got the 120/80 one mounted and put air in, and I pinched the tube..........so off again.
This tire is for the rear of this pieced together CB/CLSL350.
« Last Edit: January 09, 2026, 06:48:19 AM by WhyNot2 »
« Reply #976 on: January 09, 2026, 02:52:40 PM »
I usually hang my tires on a nail on the south side of the shop (black batt ‘n board).the power of the sun on a bright, summer day is amazing. Makes them so much easier to pop on!
« Reply #977 on: January 09, 2026, 06:20:55 PM »
Also, I try to make sure some light lubricant is on the rubber, I use window cleaner or similar that doesn’t leave a slick after drying.
Offline ofreen
« Reply #978 on: January 10, 2026, 08:49:33 AM »
Hard to beat Ru Glide for that -
Greg
'75 CB750F
Offline Magpie
« Reply #979 on: January 10, 2026, 07:12:35 PM »
For my '69 Bonnie, rear wheel laced with stainless steel spokes and trued up.  Slow progress since my wife fractured her knee cap.
« Reply #980 on: January 10, 2026, 08:41:28 PM »
Where did you get the spokes? They look strong.
« Reply #981 on: January 11, 2026, 06:23:45 AM »
Cliff….. I get that. When my wife destroyed her heel I found it pretty hard to get down to the shop. I did manage to complete a few “kitchen table” size projects….
Happy New Year.
« Reply #982 on: January 11, 2026, 07:29:32 AM »
Very stout looking spokes indeed!
Offline BallAquatics
  • Wrenching & Riding
    • My Life with Motorbikes
« Reply #983 on: January 13, 2026, 11:37:27 AM »
Did a bit of float repair on an SL100 project.
This bike is pretty rough, should be a fun project...
Dennis...  70 SL175  71 SL100 (project)  74 CB550  79 CBX  82 Seca Turbo  2011 CBR  2012 NC700X https://motobike.us
Offline WhyNot2
  • I'm finally an
« Reply #984 on: January 14, 2026, 08:09:35 AM »
I like this bike.
I have a CB100, and a CL100.
The CB is kinda finished and the CL is next on the block after the CB/CL/SL350 is finished.
« Reply #985 on: January 14, 2026, 03:02:18 PM »
I like this bike.
I like it too!  In particular, I'm moving towards smaller bikes in the shop.  I've been watching Dale Sweger. (https://www.youtube.com/@montana2strokeracer),  having a ball on YouTube working on small bikes and thought it might be fun.  I'm almost 70, and they are easy to move around the shop, and you can fit more of them in!
I'd really like to have a SL350, maybe the next bike once I get my current projects complete...
Offline WhyNot2
  • I'm finally an
« Reply #986 on: January 16, 2026, 09:04:44 AM »
I like this bike.
Yep, I'm almost 70 too, and they are much easier to push around. Problem for me is both knees have been replaced and I think the s crewed the left one up, cause it hurts more now than it did b4 the operation. Course there's a little exaggeration there, I just know it wakes me in the middle of the night, as it didn't b4.
I'm putting the 350 together from various bikes, but I'm also gathering the original parts as I can afford them, so after I'm finished with it as it is and ride it some, I want to fix it up as close to original as possible.
Just prices are going up and I have to really shop around till I get something I can afford.
I'll ride the 350 while I'm building the CL100, then I'll start clearing out the stable, and get it down to just a tickerer and rider.
« Reply #987 on: January 31, 2026, 06:59:24 AM »
And to think people used to just toss these Hondas away!!
Offline WhyNot2
  • I'm finally an
« Reply #988 on: January 31, 2026, 08:32:47 AM »
I know right.....!!!!!
Some still have them stashed away in a barn or garage and don't know or care they are there.
Offline WhyNot2
  • I'm finally an
« Reply #989 on: January 31, 2026, 08:42:46 AM »
Well, I guess 3 times the charm..........
Installed the new tube, air came out just as fast as I aired it up.
Pulled it back off, installed another, more carefully, I thought, NOT, aired up didn't hear air escaping, ok, two days later flat........uuuugggghhhh...!!!!!!
Put in 50lbs of air and could hear air coming out. Tire is back off the bike, awaiting new inner tubes to arrive.
Good thing too, cause noted the brake actuator was locked. So that has been taken care of.
Still chasing electrical gremlins. Just can't seem to get a tail light. Maybe cause I'm using an LED, same with the turn signals.
I got the brake light working and the turn signals light up, but won't blink.
Work in progress.
The CB750 is still sitting in the back ground waiting to get out in the warmer weather. Suppose to snow 3inches here in Georgia today. 16 degrees tonight.
« Reply #990 on: January 31, 2026, 09:19:11 AM »
Work in progress.
Does your tire have a small thorn stuck through it ?
Offline WhyNot2
  • I'm finally an
« Reply #991 on: February 01, 2026, 09:21:16 AM »
Work in progress.
When I pull the tire off again, I will check for sure.
And will be extra careful installing it again.
Now I have inner tubes that are new and have just minor pinches in them.
New tubes arrived yesterday, but snowed about 3 to 4 inches.
Today, to freaking cold to go out in the garage and mess with it.
Supposed to be in the 60s come Friday. So, will wait.
« Reply #992 on: February 02, 2026, 07:18:55 AM »
Was a beautiful weekend, rolled the mighty Z1 out of the garage, checked fuel, three quarters full and cranked it. About 8 seconds later she roared to life, not bad for a bike that hasnt been run in six weeks or so.  Put a little air in the rear tire and I was off....
The ride was a little cold, I didnt put my insulated jeans on and I couldnt find my gauntlets, damn wife!  [whenever I cant find something, it's typically her that "put it away". She wasnt home so I didnt bother calling, she prolly doesn't even know what gauntlet gloves are...ha!
Enjoyed the ride no less.
Offline ofreen
« Reply #993 on: February 02, 2026, 07:23:49 AM »
... and I couldnt find my gauntlets, damn wife!  [whenever I cant find something, it's typically her that "put it away".
The story of my life.   :D
Greg
'75 CB750F
« Reply #994 on: February 02, 2026, 07:24:57 AM »
Good to know I am not the only one, Greg!
« Reply #995 on: February 02, 2026, 03:08:24 PM »
You are not alone….!
Offline Nasher
« Reply #996 on: February 03, 2026, 11:55:16 AM »
I sold it!
I've had my Royal Enfield Continental GT535 for nearly 9 years, so decided to sell it and buy something else
Weather wise, today and tomorrow are the first 2 motorcycling days this year and I don't have a suitable bike to ride
(My classic race bikes don't have lights and the low temperatures here means the Suzuki GSX-R1000R won't get enough heat in the tyres)
Oh well,  better decide quickly what to buy next....
« Reply #997 on: February 03, 2026, 11:58:42 AM »
Always seems when I have money burnin' a hole in my pocket, I can always find something to buy!
« Reply #998 on: February 06, 2026, 11:20:25 PM »
I sold it!
My son bought a new Continental GT650 in 2019 and it's a great bike, but I've been admiring the 535 single for many years. If I see one going cheap (like me) I'll grab one. ;D
« Reply #999 on: February 07, 2026, 06:53:07 AM »
Oh boy, another bike! I seem to remember a certain person mentioned thinning the herd at some point, must have been my imagination:-)))
