Author Topic: Electrical help needed  (Read 2960 times)
Offline sixthwisconsin
« on: August 02, 2022, 11:10:02 AM »
I have a 1974 cb550 with a 1978 motor that I completed a rebuild on 4 years ago and have put many trouble free miles on it.
Out of storage this year, I noticed some corrosion on a few fasteners that I cleaned and nickel plated. When I tried to start it, I had nothing when I turned the key. I thought the damp storage might have corroded up the grounds.
Here are a few things I have already tried and some other facts.
1. First thing I did was check the main grounds to the frame under the battery and the coil mount. I redid these after a thorough cleaning and reassembled with dielectric grease. I then checked all ground wires in the bucket and under the left side cover and had good continuity. I also used contact cleaner on all plugs under the left side cover.
2. I started swapping parts from a running cb550. Solenoid, Key switch and a brand new Rick's reg/rec.
3. Before these swaps, I measured voltage at various places to trace back where the failure was occurring.
Solenoid with key off:
Solenoid with key on:
from the regulator black wire:
I measured these with the bikes existing components as well as the ones from a running cb550 with largely the same results.
Interestingly, the solinoid key on results started at about 1.9v and rose to about 2.5v after 20 sec or so.
I also checked the fuse panel and fuses with all being good.
I have bypassed the safety switch on this bike by moving the green/red wire to ground.
I am at a bit of a loss as to where to go next and any suggestions are welcome.
Re: Electrical help needed
« Reply #1 on: August 02, 2022, 11:22:48 AM »
If the voltage at the solenoid drops as soon as soon as the key is turned on, stop. Check the voltage at the battery terminals; if it still drops, the battery is dead and can't supply the load.
« Reply #2 on: August 02, 2022, 11:26:59 AM »
Scottly, thanks for the reply.
At the battery terminals I get a solid and steady 12.67v.
« Reply #3 on: August 02, 2022, 11:42:00 AM »
Scotty, Even though I was getting good steady voltage at the terminals, I hooked up the jumpers to another battery and sure enough, it came to life! Don't know if I have ever experienced that before.
« Reply #4 on: August 02, 2022, 12:01:00 PM »
Check the connections at the battery + terminal and the solenoid.
« Reply #5 on: August 02, 2022, 01:13:30 PM »
Even though I was getting good voltage from the battery and I had already gone through all the battery connections, it still was not performing under load. That is one thing I had not checked. Its a 4 year old bike master AGM and I did not anticipate a failure there. It was also on a trickle charger three of four times over the winter.
I switched out the battery to a known used one I had until I can get a replacement. Sometimes it is the simplest things one overlooks!!
Back up and running.
Thanks for the "Duh" moment, its just what I needed!
« Reply #6 on: August 02, 2022, 01:29:51 PM »
I've seen AGM and gel cell batteries act that way, where they showed a good voltage but fell flat on their face with a load applied.
« Reply #7 on: August 02, 2022, 02:20:13 PM »
I’ve had that happen too.
« Reply #8 on: August 02, 2022, 03:13:07 PM »
They are susceptible to internal shorts.
« Reply #9 on: August 13, 2022, 10:04:09 AM »
My bike seems to appreciate the conventional OEM Yuasa very much, either the 12N12A-4A-1 or the YB12A-A. Reliable, long living and forgiving towards voltages over 14,5 V, so no need to replace components by aftermarket products of unknown quality. These batteries are a direct fit with tailor made terminals, which means: no adapters needed and no risk of errors connecting them, which can be costly. What else? They're cheap.
« Reply #10 on: August 13, 2022, 11:45:04 AM »
12.6v is not fully charged
« Reply #11 on: August 13, 2022, 01:25:06 PM »
Right after charging you may see 13,2 V, but 12,6 V after the battery has been left alone for a couple of hours, is not a reason for concern. Less than 12,6V indicates a battery nearing the end of its lifespan however.
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #12 on: August 14, 2022, 11:55:42 PM »
Def time to get a load tester. They have saved me on a few days when I'm pulling my hair out.
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
"Alley Cat"  93 sportster
« Reply #13 on: August 15, 2022, 12:17:20 AM »
You don't need one. Just crank the engine electrically and monitor the voltage drop, preferably on a analogue voltmeter. If the needle goes < 10 V, it indicates battery is at its end. There's your loadtester. ;)
Online PeWe
« Reply #14 on: August 15, 2022, 12:24:07 AM »
My blue K6 got an AGM battery this year.
I had read before purchase that this type must get higher voltage during charge. Seller confirmed that.
My CTEK charger has a snowflake marked setting for higher charge.
The latest version of my charger has replaced that with "AGM" which is same mode.
Search on AGM battery charging:
"AGM batteries are designed to require 14.6v – 14.8v when performing a full charge from a state of discharge, whereas standard lead acid batteries need 13.8v – 14.4v, hence this is what most onboard chargers are designed to deliver – not the 14.6v – 14.8v that AGM requires."
I only charge over night at AGM mode.
Bike has also improved rectifier to  enter 14.6V during riding quicker despite low rpm riding.
I'll see how long it will survive.
I have had low priced car batteries that both died after 4 years.
Last battery a slightly pricier Bosch that will live longer.
My K2 has a GEL battery with other needs.
"The peak charging voltage for Gel batteries is 14.1 or 14.4 volts, which is lower than a wet or AGM type battery needs for a full charge. Exceeding this voltage in a Gel battery can cause bubbles in the electrolyte gel, and permanent damage."
« Last Edit: August 15, 2022, 01:11:01 AM by PeWe »
Offline Airborne 82nd
« Reply #15 on: August 15, 2022, 04:04:31 PM »
Good point you can also use the headlight. The scanner for my pickup truck uses the headlights for a certain time for the battery load test you still need to start the test with the battery charged overnight.
« Reply #16 on: August 15, 2022, 06:49:25 PM »
...'nuff said. Don't use that brand battery, they are crap. Their very best ones are still made with recycled lead.
« Reply #17 on: August 15, 2022, 09:28:20 PM »
My bike seems to appreciate the LiFePo batteries that I have been using for the last 11 years! ;D ;D I've yet to have one fail, and the only reason I replaced the first one was because it didn't have the capacity to spin the starter on my high compression 836, and I was beginning to lack the capacity to kick start it. :( I am using a solid state regulator to replace the archaic stock unit; would you trust a Bosch regulator?
« Reply #18 on: August 15, 2022, 10:49:24 PM »
Mark,which is a better brand battery that you would recommend:Motobat or Scorpion AGM ?
« Last Edit: August 15, 2022, 11:31:54 PM by grcamna2 »
« Reply #19 on: August 16, 2022, 04:58:55 PM »
My first choice is [hard to find] Yuasa AGM or Maintenance-Free versions. I've received up to 8 years of service from each of these. The Maintenance-Free one supplied slightly higher system voltage overall (12.6 as opposed to 12.4 volts), while the AGM never needed a 'Springtime reawakening' with the trickle charger, so either one was good.
I haven't tried others lately, but beware the "Made in China"mark. They have NEVER made good batteries, EVER. Still don't...
Online Stev-o
« Reply #20 on: August 17, 2022, 09:43:10 AM »
That happened to my Z1 a couple months back.  Battery was fine one day and the next it wouldnt crank.  After a few checks it was determined to be a bad battery, was changed and all good.
Online PeWe
« Reply #21 on: August 17, 2022, 11:11:26 AM »
Good one day, another not is typical for batteries. Happened my bike and car despite no winter.
Car batteries usually show their weak status when -10C or colder, car parked outside.
I prefer when bike can be started with kick, ride without headlight in worst case if higher rev is not enough.
In this case a point ign is good ;)
« Reply #22 on: August 17, 2022, 11:33:42 AM »
Heat can kill batteries too...it is tough on batteries here in the desert SW...
Offline Maltboy
  • Pitter-patter, let's git at 'er!
  • Making stupid mistakes since 1959
« Reply #23 on: August 19, 2022, 08:29:09 PM »
The DieHard batteries they sell at Advance Auto Parts are rebranded Yuasas.  They are made in the same factory.
« Reply #24 on: August 20, 2022, 05:00:27 PM »
Interesting about the DieHard batteries at Advanced. I'll need a car battery soon on my 2009 CR-V and will have to check them out. Currently running an 8 y/o Fleet Farm special.
Thanks to all for your replies!
