Author Topic: Anybody Own a HONDA VARADERO? I DO NOW!  (Read 59742 times)
Re: Anybody Own a HONDA VARADERO? I DO NOW!
« Reply #200 on: March 20, 2024, 08:33:10 PM »
So hear’s a good one. Talk to a very experienced tech at my local Honda shop. He said just get it good and hot for a couple of trips and the idle will “fix itself”. Mmmm.
That must be a feature of the computer..
Must be. We’ll see. It does rev high for a few minutes and then drops it in stages.
« Reply #201 on: March 20, 2024, 10:15:20 PM »
Maybe like cars with fuel injection etc. Higher rev when cold to be lower when warmed up.
My car has some kind of a throttle reset at ignition on too.
Throttle by wire which means no wire.
« Reply #202 on: March 21, 2024, 05:19:15 AM »
“Throttle by wire which means no wire.“ How True!
Per…. A lot of the English language makes no sense. Great example.
« Reply #203 on: March 21, 2024, 10:18:51 AM »
Yes, that one is fun. ;D
It took a while to realize that the throttle is partly electrical, not mechanical all the way.
Modern motorcycles have that too with adjustable throttle response via a switch.
Race, rain etc.
I miss that on my K6 with very direct flatslide carbs. I have grinded the plastic throttle roll a little for a little softer take offs.
Swedish has some strange expressions too.
Many languages adopt english for newer stuff.
« Last Edit: March 21, 2024, 10:25:59 AM by PeWe »
Offline jgger
« Reply #204 on: March 21, 2024, 02:57:51 PM »
This is a backdoor approach to getting us used to A.I. controlling our vehicles for us and the way we operate them. It must be a good thing, I mean just look at how the  Terminator handled that Harley!
Offline ofreen
« Reply #205 on: March 21, 2024, 03:09:21 PM »
It is true that modern systems have a warm-up mode in the tune that raises RPMs for the first few seconds after a cold start up, but they should start to drop within a few seconds.  Pretty much everything these days has 'throttle by wire' where the throttle is operated by a servo that is controlled by the ECU/PCM/TPS, the signals from which are transmitted by a wire (or 3).  So while it is fun to make fun of English (a language that is a mishmash of other languages) it makes sense in this case.
I was thinking about that yesterday when riding the '75 750F.  The carburetors still function like they should, the only thing I've had to do them is replace the needle jet sets because of wear.  At 168,980 miles the bike is on its third set.  On the other hand, I am having trouble with the CV carbs on my '90 CBR1000F.  The hanging high RPM issue is back after a short absence.  I believe the problem is with the 34 year old rubber diaphragms getting old and stiff.  The simpler 750 carbs are fine and the newfangled CV carbs are showing their age.  The diaphragms are NLA from Honda so I have rolled the dice and ordered some aftermarket ones from feebay.  They are supposed to be here today.  We will see how it goes, but I have never had any luck with aftermarket carb parts.  Seems like to work right the diaphragms will have to have the correct pliability so they work right with the springs and what are the chances of chinese ones being right?
« Last Edit: March 21, 2024, 03:11:05 PM by ofreen »
Greg
'75 CB750F
« Reply #206 on: March 21, 2024, 04:39:32 PM »
Greg,a person this past week mentioned siriusconinc.com up in Canada for good quality rubber diaphragms as having the correct pliability? and able to let the slides raise as OEM did;I believe they're Made in Japan.  Have you ever ordered from them ? I haven't so far.
« Reply #207 on: March 21, 2024, 04:51:24 PM »
I’ve bought from them and what I got was fine.
« Reply #208 on: March 21, 2024, 05:10:34 PM »
John,I was trying to contact them to confirm if they had a product;it looks like they don't 'do phone' anymore and I've been waiting for a while for an answer to my email.
Do you know if they sold-out to another country? Or are they still up in Kitchener,ON. ?
« Reply #209 on: March 22, 2024, 05:00:10 AM »
Bill…… No idea. I see their ads locally, but I buy from them very rarely. I ask around.
Offline ofreen
« Reply #210 on: March 22, 2024, 05:24:17 AM »
Thanks gents, I looked at their website.  I'll inquire with them to see what they have if the ones I am getting don't work out.
Greg
'75 CB750F
« Reply #211 on: March 22, 2024, 06:19:36 AM »
Hey Greg...they are a big seller on eBay and have some carb parts, didnt see diaphragms after a quick search...
https://www.ebay.com/sch/i.html?_dkr=1&iconV2Request=true&_blrs=recall_filtering&_ssn=siriusconinc&store_cat=0&store_name=siriusconsolidatedinc&_oac=1&_nkw=cbr1000
I'd be carefull, they sell Keyster parts.
Offline ofreen
« Reply #212 on: March 22, 2024, 07:26:14 AM »
Thanks Stev-o, I didn’t see ones fro the CBR on the website either, but I will ask if these others don’t work our. Now they are supposed to be here tomorrow.
Greg
'75 CB750F
« Reply #213 on: April 10, 2024, 08:09:33 PM »
Put a good +150 km run on the Varadero today. The high idle has “self corrected” and the new sprockets and chain completely eliminated the annoying “thrumming” noise/vibration I’d been hearing last fall. Bike ran really well and I like it a lot.
« Last Edit: March 15, 2026, 05:24:51 AM by BenelliSEI »
« Reply #214 on: January 13, 2025, 02:42:25 PM »
Gave the Varadero its first oil change. The drain plug is in the left rear corner of the pan (wet sump), so I left it on the side stand for a few days. Slid a 2” X 4” under the front wheel to get full drainage. No more Mobil 1 4T Synthetic (ridiculously priced in Canada). Going back to the recommend Honda GN4.
Ordered the correct “204” spin on oil filter, but when I removed the WIX 51358 filter that was on the bike, noticed that it’s at least 50% larger than what I had. Checked the internet and found some guy that takes these filters apart and measures them to the last strand of filter media….. He concluded the WIX filters are superior. Took his advice and found one. Who knows, can’t hurt.
« Last Edit: January 13, 2025, 02:51:42 PM by BenelliSEI »
« Reply #215 on: January 13, 2025, 02:49:59 PM »
My wife has only been on the back of my bike on a very few occasions. Since we were teenagers, she’s always ridden her own bike, but not so much lately…..
Last year, she enjoyed one ride on the Varadero and suggested a backrest would be nice. Today I fitted the top box (I never use it, makes getting on a chore) and started looking around the shop/shed. Found an old sissy bar that was fitted to my first K8 (+40 years ago!). Pulled off the pad, cleaned it up and mounted it to the front face of the top box. Pictures next time, it looks great, no more excuses!
« Reply #216 on: January 13, 2025, 02:58:58 PM »
I bought a MC specific backpack that has highly reflective cloth built in as a Christmas gift to myself. I don't have to stap a bag behind me to carry a water bottle or any food or other things within reason to it 35L capacity.  Really made a difference on how high I would have to swing my leg over the seat. With winter and arthritis movement is more painful and sometimes more difficult, so it was nice only needing to raise my leg about 34 inches or horizontal to go over the seat and rear of the bike. Granted any trips for food supplies from grocery are not going to be helped and I may have to be careful that I don't push myself too far forward with stuff on back and the backpack...
Hope your wife likes the backrest sissy bar...
« Reply #217 on: January 17, 2025, 10:47:16 AM »
Photo of the new (+40 years old Hondaline part) backrest……
« Reply #218 on: May 07, 2025, 06:35:34 PM »
Been out a few times on the Varadero already. Today I realized the bash guard (after market aluminum beast) and lower side panels were still sitting at the back end of my shop! Took them in January to do an oil and filter change and never put them back. They got a good scrub and reattached. Lubed the chain and aired up the tires. Planning a full day on it, Friday.
« Last Edit: May 07, 2025, 06:38:26 PM by BenelliSEI »
« Reply #219 on: May 07, 2025, 08:24:35 PM »
John,it's good to hear you have the 'big V' back on the road,ready for some miles.
« Reply #220 on: May 08, 2025, 06:14:33 AM »
Stu….. Such a great machine. You never got them in the US (Cuban name) and VERY few sold here. They were expensive and at the time the segment was dominated by BMW. I’ve yet to pull in anywhere and meet another one and I always get the same question: “what is that?”.
« Last Edit: March 15, 2026, 05:31:46 AM by BenelliSEI »
« Reply #221 on: May 27, 2025, 06:43:33 PM »
Yesterday Gary and I went for a nice long ride. He has a brand new Husqvarna Noreen 901 that cost him a pretty penny. It is a gorgeous bike.
My older Varadero had no trouble keeping up and I do love my HONDA!! It’s a bit heavy, but the second it’s rolling along it sheds all the weight and is a real rocket. We stopped twice and both times the other “bike guys” always looked at mine for a few minutes and then asked “what is it?”. Have yet to meet another one.
« Reply #222 on: March 15, 2026, 05:35:33 AM »
Installed a small volt meter that also has three different “device charging points”. Threw away the old style cigarette lighter unit that popped out whatever I tried to keep plugged into it!
Actually had the shop doors opened and was considering a short ride. Snowed 6” that  afternoon and Winter is back, full time. A ride in March seems unlikely,
« Last Edit: March 15, 2026, 05:37:06 AM by BenelliSEI »
« Reply #223 on: March 15, 2026, 05:40:50 AM »
Last time Tim and I rode back trails and gravel for a few days, I realized my bars are a bit to low (or my pegs are too high). The pegs are adjustable, but I think I’ll start with 30mm bar risers. All the cables and wire look like they can handle that much without modifications.
Considered machining up my own, but these on Amazon are so inexpensive it would be a complete waste of time. I’ve bought these before and they are nicely done, but make sure you THROW AWAY the bolts that come with them.
« Last Edit: March 15, 2026, 05:44:21 AM by BenelliSEI »
« Reply #224 on: March 15, 2026, 10:20:48 AM »
They look like a strong design John.
I'm sad for you not being able to take that large 90degree Performance V-twin for a ride  :)
She must be a smooth Runner.  :)
