Author Topic: CB750K4 what did I get myself into?  (Read 18222 times)
Offline BrockCB750
Re: CB750K4 what did I get myself into?
« Reply #150 on: September 15, 2023, 10:57:44 AM »
I bought an allen head bit for my impact screwdriver and tried hammering that allen head screw out. Tons of heat and tons of hammer... I got nowhere. It was about time I got an air compressor. So I got one and an impact... they came right off. No issue at all. haha. Its REALLY nice when you have the right tool for the job.
« Reply #151 on: September 15, 2023, 12:29:20 PM »
You won the fight against the stubborn bolt! ;)
Compressor is a must have anyway
Offline BrockCB750
« Reply #152 on: September 16, 2023, 02:59:23 PM »
So I have the front wheel, disc, hub, etc. Pulled up the service manual to see how I take this thing apart and the page is missing from EVERY upload. I tried 3 different sources. All missing the page. Can anyone help me find page 132?
Offline BrockCB750
« Reply #153 on: September 16, 2023, 03:01:19 PM »
Well nevermind futher searching led me to this thread which had a pdf of that page:
http://forums.sohc4.net/index.php?topic=71220.0
Offline BrockCB750
« Reply #154 on: September 17, 2023, 01:21:18 PM »
Score another one for the impact. Saved me twice now. Look at how bad the corrosion is on this thread. Been slow going waiting for tools and whatnot. Getting very close to actually restoring some part of this motorcycle. haha
« Reply #155 on: September 18, 2023, 01:09:40 AM »
From my reprinted paper version I bought on eBay UK.
Living room version. It will never see dirty fingers. Same with Mark Paris book ;)
I think I have added a missing page before in a thread here.
Offline BrockCB750
« Reply #156 on: September 25, 2023, 04:42:04 PM »
So every single part of the bike is apart finally. Rear hub took a little time.
So I am not very smart on brakes, particularly drum brakes. The hub has an inner layer that the pads press into. What is the material and should I be careful about how I clean it up?
Also for fun, here is my current pile of stuff I need to haul to the dump:
Not everything there is going but most of it. Those wheels are a very sharp rolling tetanus risk.
Looking at this picture reminded me of another question. If the disc brake measures out okay, what are the chances that it can be resurfaced? Just now thinking about this so probably need to do some more searching around here. Its very old but relative to the rest of the bike can possibly be salvaged.
I am getting so very close to starting to restore the bike. Trying to decide if I want to paint the hubs or just clean them up and then I am going to lace the spokes and drop them off to get the tubes and tires put in.
Timing is perfect, sweated through the late summer getting this rust bucket apart and I can take my time during the winter to get this back together.
« Reply #157 on: September 25, 2023, 04:58:42 PM »
Yes you can get the rotor resurfaced. And drilled too if you want.
Godfrey's Garage does it(he's a member here)
And Truedisk does it too
https://truedisk.net/
« Last Edit: September 25, 2023, 05:05:29 PM by newday777 »
« Reply #158 on: September 25, 2023, 05:20:04 PM »
The inside of the drum is a cast iron liner. Don’t be afraid to tackle it with a good, course sand paper, then a finer one. That looks pretty greasy, get it really clean before sanding.
« Reply #159 on: September 26, 2023, 04:41:25 PM »
The front disc is stainless steel (18-8, IIRC) so it should resurface with emery paper on a drill, or the like. They seldom warp: I have not (myself) ever seen a warped one. They are so thick they just never overheat. Later bikes have 1/2 as thick discs, and they do occasionally warp (Yamaha comes to mind).
Offline BrockCB750
« Reply #160 on: October 02, 2023, 03:43:51 PM »
Nice thanks for the advice on the rotor. I might take stab a cleaning it up myself or get it resurfaced if needed.
I am finally done with pretty much all the dirty jobs except the engine cleanup. But, I may pay someone to blast it for me. Spent a long time in the backyard with a bottle of simple green, the hose and a scrubber pad. Rear hub parts were coated in what I guess is brake dust and chain lube. A little time with the brass wire wheel, a little more scrubber pad and then some prep and I think I will be ready for some more paint.
The best news, the restoration has begun! Primered and applied a few coats of matte black enamel to the front hub. Waiting for it to cure and then finish up with enamel clear.
Offline BrockCB750
« Reply #161 on: October 03, 2023, 05:21:55 PM »
Front hub got new bearings:
Everything is flush in the hub. The collar has a very slight amount of movement after everything is back together. Scratched near the retaining ring trying to tighten it down but nobody will see that. Need to stake it down but wanted to post pictures just in case someone noticed I did something wrong haha.
Offline BrockCB750
« Reply #162 on: October 09, 2023, 11:37:51 AM »
One wheel done:
« Reply #163 on: October 09, 2023, 02:24:44 PM »
Nice work. It will look great with a fresh disc and new tire!
« Last Edit: October 24, 2023, 04:49:29 PM by BenelliSEI »
Offline denward17
« Reply #164 on: October 09, 2023, 02:35:00 PM »
I like it....Is the rim paint or powder coat?
Offline Kaze
« Reply #165 on: October 15, 2023, 10:19:27 AM »
Just saw the "before" pics. That looks exactly like a project I'd go for. You've really dug in deep. Must be having the time of your life! :)
One man's rubbish is another man's project.
Offline BrockCB750
« Reply #166 on: October 24, 2023, 04:40:19 PM »
Haha! Time of my life? Hmm... I wouldn't call it that. It was a massive relief getting the thing apart with only one broken off fastener. That was exciting.
Work has been a little crazy and some travel but I finally got around to painting the rear hub, new bearings and new rubber dampener things (can't remember what they are called at the moment).
I think its time to lace the spokes.
Paint is a little wet from wiping off some stuff on it. When I get the spokes laced on it I will take another picture of it all cleaned up.
« Reply #167 on: October 25, 2023, 06:07:58 PM »
Those cush drives look like NOS (not the easiest thing to come by).
Offline BrockCB750
« Reply #168 on: October 26, 2023, 06:49:09 AM »
« Reply #169 on: October 26, 2023, 07:47:04 AM »
« Reply #170 on: October 26, 2023, 08:25:48 AM »
I thought the separate parts were the older.
Those that are connected with a tang the later.
I have a Honda labeled  plastic bag with the separate, small and big rubber parts.
Ordered from Germany some years ago.
They costed much more than the other I think is later.
Fitness very tight, I gave up pressing in the sprocket carrier despite lube, replaced with the other model.
My K6 need new since the rubber has cracked. I'll try my older set again at next wheel off.
« Reply #171 on: October 26, 2023, 04:06:37 PM »
They are not NOS I believe. "Rear Wheel Damper Rubber Set"
https://www.vintagecb750.com/products/3/suspension-wheel/132/rims-spokes-wheel-seals-tire-valve-stems
Brock…… I’m curious; how snug were these when you went to slide the drive side back in place?  Thanks, I need a set on my K4 and have never tried those. Fairly recent addition to their offerings.
« Last Edit: October 26, 2023, 04:12:34 PM by BenelliSEI »
Offline BrockCB750
« Reply #172 on: October 27, 2023, 09:35:20 AM »
Haven't gotten that far yet. Will report back when I do.
« Reply #173 on: October 27, 2023, 04:59:38 PM »
Please do!
Offline CycleRanger
  • No comment about being an
« Reply #174 on: October 29, 2023, 06:54:04 AM »
Good to see that they are repopping these now.
~12 years ago when I replaced the ones on my K5 all there were was Honda parts and they were getting scarce.
It did take a little effort to squeeze the drive side back in but it wasn't too bad. A bit of soapy water helps to facilitate things.
