OK, the moment we'd all been waiting for, PICS!
These are going to be kinda big, but I wanted people to be able to see detail.
Starting with the stator:
Didn't have a side-by-side of the new/old stators, but the old stator had stuff burning off of it, the varnish they dipped it in was all over the place and it generally looked like #$%*.
I cleaned all the connectors, packed all connections with dielectric grease go protect them.
Like I stated in Modest_Man's thread, (I think it was his?) my only gripe was actually with the stator in that the harness attached to it is a bit thicker than stock, heavier gauge wire than stock, which is great for power, but made it harder to route. Still, I think I got it all ok.
Put in new brushes, as well. No real visual difference on those, just that the springs are definitely stronger. Replaced all those nasty phillips' bolts with stainless steel allen bolts and anti-seized them all, too. They were a b!tch to get out the first time. (not that I intend to do this again, but you never know
Now we get to the 'new' rotor. This is a generous donation from Samson. (Eventually, Delilah's will be sent out for rebuild and go to him.) A complete terror and #$%* to get off, but it eventually popped free. The guy did a great job on it. Visually, it looks brand-new.
Pretty, non? Now let's look at a side-by-side comparison:
From a bit of a distance, the difference is already pretty drastic in that you can actually see the wiring through the coat of insulation, and everything just looks really clean and neat. All the solders, slip rings, winding... very neat and precise.
Here's a closer look, but Macro wasn't working for me so it's a little fuzzy:
From the top, a look at the sliprings, which were apparently resurfaced, as they had some gouges from the brushes:
and a pic of it installed:
Didn't get a pic of the regulator/rectifier, but it tops out at 14.7, which is the same as what Pinhead's tops out at.
The bike now puts out 13v at idle, and maxes at 14.7 starting at 2k rpms. I'll be testing it all today on my way to work and home again.
