Author Topic: Phaedrus: CB750 RestoMod - Update: 09/23/21 w/ new video  (Read 1215861 times)
0 Members and 10 Guests are viewing this topic.
Offline CBJoe
Re: Phaedrus:CB750 RestoMod -Shop Update: 09/15/17 w/ New Pics
« Reply #4200 on: November 12, 2017, 10:23:07 AM »
Running pretty good on a 40degree day :)  CycleX Exhaust sound on Phaedrus...I believe the baffles are drilled right Ron?
Lets give this a try...does anyone know how to embed the video here?  or can you only post the link?
https://flic.kr/p/ZnaF7G
https://flic.kr/p/ZnaS5U
« Last Edit: November 12, 2017, 10:34:40 AM by CBJoe »
'07 Bonneville Black
'65 CB77
'66 CM91 (C90'ish)
Offline Tintop
« Reply #4201 on: November 12, 2017, 12:09:40 PM »
vids worked fine, just took a bit to down load.  Sounds great Ron. 8) 8)
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
« Reply #4202 on: November 12, 2017, 03:08:27 PM »
AS to the baffling: There is a plate, you can see looking in the butt hole, about 4 in down the tube, with probably 14 or so holes drilled in it. I then used a larger drill bit and drilled each hole larger  so they connected and removed a large piece of the plate to accommodate the DYNO sniffer wand. The megs themselves have a straight through tube of equal diameter down the length of them, to the reverse tip. The reverse tip is hollow.
The space between the straight tube and the megaphone flare has some light baffling in it. The straight tube is held in place at the small end of the meg, at the plate that I ridiculed with holes, and the ending plate at the end of the meg. You can see it by removing the reverse tip. But since I opened up that center plate, you can stick a rod straight through the meg to the collector and choosing one, on up the header.
Thanks Joe, for the crate for Ticker (working name) 305 Super Hawk project. I can be confident of a secure shipment.
« Last Edit: November 12, 2017, 03:10:44 PM by MCRider »
Re: Phaedrus: CB750 RestoMod -Shop Update: 11/12/17 w/ New Vid & Sound
« Reply #4203 on: November 12, 2017, 03:25:16 PM »
Comments about the Vids: First thanks to CBJoe for the AV. I promised myself I'd get a smart phone this year and time is running out.
The bike stumbled when given throttle in one of the vids. That's because I'd been running it with the gas off. By the time we were filming it was starved for fuel. That was easily fixed by turning the tap on, duh!
Also, note that it doesn't smoke, as it should be. It has about 165 miles on it, and it wasn't babied, 12 drag-strip runs, and a WFO Land Speed Record attempt. Full speed accelerate to top speed and held at full throttle for at least 1/8 mile.
AND IT DOESN'T SMOKE!    :D
Mike (Rieck)  promised me it wouldn't, and he came through. I wouldn't have held him to it if it had. But we both believed that if its done right, no new engine should smoke, or have to have a delicate break in period. Just my .02.   :D
« Last Edit: November 12, 2017, 05:10:40 PM by MCRider »
Offline CBJoe
« Reply #4204 on: November 12, 2017, 04:24:50 PM »
My pleasure Ron  8)  Just need a quick warm week to roll around so we can get the bike moving around a bit  ;D
'65 CB77
'66 CM91 (C90'ish)
« Reply #4205 on: November 12, 2017, 04:46:28 PM »
Yes, absolutely! Just FYI, I'd like you to ride it a few miles at first. Then come back in and we'll check it over. If it passes then another 5+ miles to really get me happy with it. I'll have the trailer ready for a PU if it craps out on you.
Can't wait!   :D
« Reply #4206 on: November 12, 2017, 05:07:23 PM »
 Thanks Ron. It has always been a pleasure to have helped you out.
« Reply #4207 on: November 14, 2017, 04:24:36 PM »
Thank you!
« Reply #4208 on: November 14, 2017, 04:46:27 PM »
I'm going to get caught up with some shoptalk in the next few posts. But first...
It must have been CBJoe, in his recent visit Sunday AM, who told me to check with the local Ducati shop for a Dyno. I was skeptical as I have done extensive Google searches for local Dynos. But, sure enough on their website they proffer a DYNO. https://www.indyducati.com/  I sent them an Email and sure enough they have one, available to the public, not just Harleys. Here's their response:
Hi Ronald,
We would love to do a couple runs with your Honda. Here is a link to our dyno page. https://www.indyducati.com/dyno-tuning   A pass with horsepower, torque, and air/fuel ratios will cost $100 plus tax. What kind of pipe are you installing? If you can send a picture I just want to confirm that our O2 probe will fit the exhaust.
The best day for us to get a couple passes is on Saturday. Thursday the 16th would work for a drop-off if you can pick the bike up Saturday afternoon.
Please email or call if you have anymore questions.
Thanks,
Ray
Ray Shaw
Service Writer
Ducati Indianapolis
(317) 337-1098
Bingo! They've been there a while and its an A1 shop. And they're like 6 miles away!
« Last Edit: November 14, 2017, 04:51:04 PM by MCRider »
« Reply #4209 on: November 14, 2017, 05:28:40 PM »
Keeping with the garish 70s theme, I remember that back then, we had flat headlight lenses. I decided that I wanted one again. So after a loong search, I found one that suited me. I actually found one from a member here, but upon receipt it just didn't suit. The ones we had back then were CIBIE, but those seem to be NLA. So I found this off brand KIONIA I think. It sits behind the OEM lens:
I had an H4 left over from prior pursuits, that is a 100/55W (illegal in the states I think). It also has a blue tint to it, maybe a rainbow, Hard to tell.
It took a LOT of grinding and fidgeting to get it all to fit, but it did.
Along with HondaMan's relays, it puts out a very hot, torchlike beam.
« Reply #4210 on: November 15, 2017, 02:01:13 AM »
That looks great Ron, I love my Marchal, all I had back in the 70's was the standard OEM headlight, and it was less than wonderful at speed on unlit country roads! ;D
« Reply #4211 on: November 15, 2017, 03:55:57 AM »
LED H4 bulb will make it even brighter.  8)
It is longer due to a fan and small connection box taking space (voltage adapter), the relays will then not have room in the bucket.
My K6 has parking light too managed from the handlebar switch. Parking bulb get 12V in position P, LO and HI.
I had to add a 3:rd relay to switch parking bulb off at LO to not disturb LO. Opening relay.
Photor here are a few years old. Here with a cheaper version of insert. I have now a Hella insert. Maybe not much that differ.
« Reply #4212 on: November 15, 2017, 07:40:49 AM »
Very nice PeWe!
I got an appt for a dyno run tomorrow at 11A. They said I could wait on it.   :D
« Reply #4213 on: November 15, 2017, 07:43:07 AM »
Thanks Terry. I owe you some pics, check your IMs
Offline Tintop
« Reply #4214 on: November 15, 2017, 02:22:00 PM »
That head is bright Ron.  I use to run motorcycle head lights on my Seven, both with 100/55 bulbs.  Just about daylight on high, and yes the setup was highly illegal. ;D ;D ;D ;D ;D
« Last Edit: November 15, 2017, 02:24:50 PM by Tintop »
77 CB550 Cafe build
« Reply #4215 on: November 15, 2017, 02:42:11 PM »
I have a LED headlight on my 550.  The light is more intense but cooler.  Also, where the incandescent bulb pattern would fade at the edges, the LED light pattern is very sharp.
Offline CBJoe
« Reply #4216 on: November 16, 2017, 05:46:54 PM »
Don't leave us hanging Ron...whats the verdict on the Dyno?  Hope the shop worked out, I'd like to take my bonnie there to be sure I've got my jetting all worked out for the best.
Joe
'65 CB77
'66 CM91 (C90'ish)
« Reply #4217 on: November 17, 2017, 02:37:48 AM »
A good headlight lense on the headlamp and reflector design is critical to getting a nice crisp light.  Hella makes a good H4 lamp, Cibie makes one that is several steps above it in my opinion. There are some on Amazon at a good price but, they are listed as an H4 foglight for some silly reason.  I can dig up the link and share it if you would like when I fire up the PC desktop again.
David
« Reply #4218 on: November 17, 2017, 07:22:25 AM »
Joe
Well... how's 47hp sound? Yuk. You remember when you were here, I was still not convinced it was running on all 4. You messed with the plug cap of #1, and it seemed to run better. That was probably a coincidence. It has that sound of being almost OK, but not quite. The 4-2 has a different sound than the 4-1.
The Duc shop is really nice. Pics to follow. And the people were also. At first the service manager just wanted me to accept it. But I persisted, saying I could accept a 10-15% drop from 79hp, but not that much, and one of the owner/partner/mechanics said to try it again. The result was the same. So they started tinkering with everything, and finally checked the header temps with an infrared checker. Like you did with your hand. I can't do that.
#1 was 1/2 of the other 3, which were pretty uniform. Pulled the plug cap and checked the spark old school with a spark plug laying on the head. It was a healthy spark, and the bike seemed to run about the same with the plug cap on or off. So the conclusion is a carb problem.
I did mess with the float levels over the last winter, so I guess maybe I futzed it up.  They just charged me for 1 run, $100, and are looking forward to me coming back.
They ran many runs, and trialed and error-ed things, so the engine got a good workout. Still no oil leaks or smoking. More later.
« Reply #4219 on: November 17, 2017, 07:35:49 AM »
oh yeah, Air/Fuel ratio was lean at the bottom, but by about 3000 rpm, it was no higher than 12 nor lower than 11, which the Mikuni manual says should be all right. So at least I shouldn't hole any pistons. I'll get the low range re-jetted.
« Last Edit: November 17, 2017, 09:16:48 AM by MCRider »
« Reply #4220 on: November 17, 2017, 09:16:38 AM »
I would be afraid of damage to cylinder 1 with it not firing.  If it is getting gas it will be wahing the oil out of that cylinder.
I hope I am wrong.
David
« Reply #4221 on: November 17, 2017, 09:19:17 AM »
I hope I am wrong.
David
Yes. I'll be taking off the carbs and ordering an infra red ray gun, before it starts again. And ordering some fresh oil.
« Reply #4222 on: November 17, 2017, 03:20:39 PM »
Probably a stupid question Ron, but have you done a compression test? I'm wondering if you've got a valve not completely seating? Cheers, Terry. ;D
Offline CBJoe
« Reply #4223 on: November 17, 2017, 04:33:51 PM »
Terry....Mike doesn't want to hear that kind of blather ;D
Let me know when you are going to dig into it Ron...I actually have one of those IR Thermometers and would be happy to bring it over or let you borrow for a bit.  Haven't used it yet, but this would be a worthy first go :)
Cheers, Joe
'65 CB77
'66 CM91 (C90'ish)
« Reply #4224 on: November 17, 2017, 10:29:05 PM »
[/quote]
Ha ha, I'm sure it has nothing to do with Mike's work Joe, but it might be something as simple as an incorrectly adjusted valve.
If there's not enough lash when the engines hot it won't have much in the way of compression, so a quick compression check won't hurt? Easier than stripping Ron's carbs, for sure! Cheers, Terry. ;D
« Last Edit: November 19, 2017, 01:43:28 AM by Terry in Australia »
