Author Topic: Phaedrus: CB750 RestoMod - Update: 09/23/21 w/ new video  (Read 1245567 times)
Re: Phaedrus: CB750 RestoMod - Update: 8/11/19 w/new pics
« Reply #4450 on: August 26, 2019, 12:41:28 PM »
Sounds like a plan fellas. Lets hope a hurricane doesn't pass through your area on that date. ;)
« Reply #4451 on: August 30, 2019, 02:51:06 AM »
Dyno charts are very interesting! ;)
I hope I can provide one before the dark boring and cold winter.
« Reply #4452 on: August 30, 2019, 07:01:05 AM »
Weather's supposed to be Beeyootiful!
« Reply #4453 on: August 30, 2019, 07:52:23 AM »
My shop was christened "Busted Knuckle Garage" years ago. There is a plaque (store bought and faux-distressed) hanging on the entry wall.
Bruce and I have been at it since 2008. In the last year or so, CBJoe has been coming by, Ed drifts in and out and Pat lends a much welcomed hand. any more and I'm going to have to get some bleachers. ;D
« Reply #4454 on: August 30, 2019, 10:09:12 AM »
That's exactly how my father said it Ron.  ;D
« Reply #4455 on: September 09, 2019, 08:23:08 AM »
CBJoe has posted his results on his CB750 thread. Bottom line is he squeaked out 80 hp and about 56lbs ft of torque, IIRC. Torque number may be low. He's got some leeway to lean or rich the main jet and maybe squeaked out a little more. I had some personal problems and didn't get mine to the dyno. But I was there with Joe, and it was fun. The Ducati boys are real friendly and have taken a liking to our ancient projects.  The dyno master said, as we were leaving " I expect to see yours (mine , Ron) in here soon."
Mines on the trailer, and should be ready to go when they can take me.  I'm looking at some electric trailer dollies which would really help me transport, hook up, unhook, park etc.  Looks like around $225 would get a good one.
Looking for a floor lift also. Handy seems to be the best, at about $1300 delivered and partially set up. Harbor freight has a good one for about $600. But it has just enough things wrong that would, over time, make me wish I had popped for the Handy. For instance, the Handy is air driven for a smooth up and down lift. The Harbor Freight is an oil pump, so it goes up a little with each foot pump. And I'm not very steady on my fest. I need noth feet under control. Other things, rear wheel drop out, etc. Makes a difference.
Re: Phaedrus: CB750 RestoMod - Update: 9/ 9/19 w/new pics
« Reply #4456 on: September 09, 2019, 09:05:45 AM »
Ron....I've had my compressed air Handy for 25 years now....never a problem.  ;)
« Reply #4457 on: September 10, 2019, 07:11:14 AM »
Yeah, that's what they use at the Ducati shop. Worth the premium in price.
Misc Data: I took a compression test on the new motor. It was 180lbs straight across. I'm used to getting 240. May be from the extended overlap of the new cam we're running.
« Reply #4458 on: September 11, 2019, 04:22:28 AM »
That will do it
« Reply #4459 on: September 19, 2019, 04:39:07 PM »
Yay! Finally something that makes sense. First, complements of CBJoe; 2 Dyno runs at the Ducati of Indpls ;
and...
In case you're wondering...that's 10,250 rpms. Sounds real nice.
Re: Phaedrus: CB750 RestoMod - Update: 9/19/19 w/new pics- DYNO run
« Reply #4460 on: September 19, 2019, 04:44:43 PM »
But sadly it was only 75hp and 49ft lbs.  But we've got something to work with, and I'm open for suggestion. More or less cam, I think I can handle the jetting. I'll get the graphs posted soon.
« Reply #4461 on: September 19, 2019, 05:13:03 PM »
Can somebody tell me...
I've got a PDF from Ducati attached to an email. How do I get that into the forum?
Offline Tintop
« Reply #4462 on: September 19, 2019, 05:29:05 PM »
Try opening the PDF & copying the address / link.  Then paste the link here.  Should work.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
« Reply #4463 on: September 19, 2019, 05:38:09 PM »
That's what I thought too. But I downloaded the attachment from Ducati to the desktop. Then I open the attachment on the desktop and there's nothing to copy. But even if I could wouldn't that direct a user back to my desktop for the attachment, which of course wouldn't be right.?
« Reply #4464 on: September 19, 2019, 05:43:10 PM »
Ron, it sounds great. Long road buddy.
I wonder how restrictive that exhaust is compared to others? We pretty much know what your engine is. I forget what carbs??
Online scottly
« Reply #4465 on: September 19, 2019, 05:44:19 PM »
Ron, attach the PDF to your post here.
Offline CBJoe
« Reply #4466 on: September 19, 2019, 05:56:59 PM »
Charts Attached....bmp format wasn't working.  Saved as jpegs and posted.
'07 Bonneville Black
'65 CB77
'66 CM91 (C90'ish)
Offline CBJoe
« Reply #4467 on: September 19, 2019, 05:59:15 PM »
super rich fuel mixture until end rpm....
'65 CB77
'66 CM91 (C90'ish)
Online scottly
« Reply #4468 on: September 19, 2019, 06:42:38 PM »
Thanks Joe. :) Yeah, the fuel curves are pretty wonky, and the HP/torque curves are more or less reflected, at least over a certain RPM. Notice the dips at 6500 RPM.
Online scottly
« Reply #4469 on: September 19, 2019, 06:48:30 PM »
Looking back through the thread, you mentioned the old pistons had higher domes, and suspected they may have been 12:1?
Offline CBJoe
« Reply #4470 on: September 19, 2019, 06:49:10 PM »
Ron...I was just wondering about Fuel.  I think we had unknown octane pump gas in the tank from a fill up many months ago... Didn't the dyno guy add some fuel from their shop?  Wonder what octane/grade it was.  I'm running super 91 Ethanol Free in most of my bikes from the Country Mark Coop from east of me.
I think maybe lower the needles a small bit and run some new fuel?
« Last Edit: September 19, 2019, 06:51:44 PM by CBJoe »
'65 CB77
'66 CM91 (C90'ish)
Online scottly
« Reply #4471 on: September 19, 2019, 06:59:29 PM »
What carbs are we talking about?
« Reply #4472 on: September 20, 2019, 06:39:46 AM »
Mikuni VM29 Smoothbores
« Reply #4473 on: September 20, 2019, 07:23:37 AM »
I thought he was running Mikuni 29's. I forget which cam is in there. The rich condition...like you said....corresponds with the power graph. Main jet looks OK...drop the needle a couple of notches and see what happens.
 I believe a different exhaust system would really help. I think the Hindle 4/2/1 Ripple Rock Racers sells is a really, really nice system. Price is in Canadian dollars which sweetens the deal even more. ;)
« Reply #4474 on: September 20, 2019, 08:34:12 AM »
 Ron....really no need to spin the engine that high.....party is over @ 9,500 with these engines. Your chart shows power flattening at 7,500 and the A/F is beginning to lean out towards 13-1. You are running out of cam and/or exhaust. I am sure the cam is timed correctly. What cam is in there???
