Author Topic: Tarozzi rearsets on the million $ CB.........  (Read 9895 times)
« on: July 01, 2008, 06:20:28 PM »
Well....they bolted right on.....AFTER I FIRED UP THE LATHE. ;) They are much better than the Raask's in terms of comfort and quality. Freak'n Italians have to use stupid 7mm X 1.00 hardware....that's cam sprocket stuff. ::)
« Last Edit: July 01, 2008, 06:27:49 PM by MRieck »
Re: Tarozzi rearsets on the million $ CB.........
« Reply #1 on: July 01, 2008, 06:22:02 PM »
One more for the bracket I had to make for the left because of stupid engineering.
« Reply #2 on: July 01, 2008, 06:24:21 PM »
 A fine concept that took some real thought (on my part) ::). Those pegs rotate with the levers too. Sounds weird but it does work.
« Reply #3 on: July 01, 2008, 06:37:11 PM »
Oh yeah....the instructions SUCK. Parts missing on the copy BUT needed and inculded. I almost F'd the right side up.
Offline scondon
  • Mmmm......tasty bugs
« Reply #4 on: July 01, 2008, 06:42:29 PM »
  How the F did you get a set for the F ??? ???  Looks damn nice Mike. Those Tarozzi's are nice pieces with good hardware and I've got a nice set for a K bike if I ever get around to getting a frame to build on. In the meantime I just stare at 'em  ;)
  You'll get used to those quick and when ever you get on a friends bike with stock pegs you'll think "how the hell did I ever corner with these things?" ;) ;D ;D
« Reply #5 on: July 01, 2008, 06:59:16 PM »
I'll tell you Sean they are a lot more reasonable (in terms of comfort) then the Raask's I had on for 16 years or so. The basic pieces are better made too but take some thought for a good, secure bracket on the left (as well as spacers).
« Last Edit: July 01, 2008, 07:01:11 PM by MRieck »
Offline scondon
« Reply #6 on: July 01, 2008, 07:03:18 PM »
 Now you've got no excuse but to get out and ride that thing. The shiny kickstand return spring in your pick about made me hurl. GET SOME DIRT ON THAT MONSTER >:( ;) :D :D :D
Offline Dave-and-his-550
  • I know the pieces fit...
« Reply #7 on: July 01, 2008, 07:04:56 PM »
what is 'million $ CB' suppose to imply?
Offline wildcatmahone
  • Poseur
« Reply #8 on: July 01, 2008, 07:11:38 PM »
Looks great!! How you doin for kickstarter clearance?? ;)
« Reply #9 on: July 01, 2008, 07:12:50 PM »
A moniker attached to my bike by a parts person at a shop I've dealt with for over 25 years. I've owned the bike for 32 years and it's gotten a lot of personalized attention on my part if you know what I mean. ;)
« Reply #10 on: July 01, 2008, 07:14:18 PM »
Thanks! Forget it....it isn't happening. That goes for Raask's too. I was wondering if a 550 lever would clear. ???
Offline bunghole
« Reply #11 on: July 01, 2008, 07:27:55 PM »
I'm jealous!
What about bending the kick lever?  Too ghetto?  Or if you know someone with a CNC, you could do some cool offset aluminum lever.  Not sure if aluminum is acceptable for kicking though.
Did or do you need the rear peg mounts for those or other brands of rearsets?  I'm thinking about cutting those triangles off for my build, but I need to think through as far as future rearsets and/or exhaust mounts.
'05 HD FLSTCI (Heritage)
'06 Suzuki DRZ400S
'08 Honda VFR800
'77 Honda CB750K
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #12 on: July 01, 2008, 07:47:49 PM »
I recently received my Tarozzi rearsets. Ordered the ones with the rubber pegs and shifters.
Have not had time to even mock them up ::)  They look sturdy.
Offline bunghole
« Reply #13 on: July 01, 2008, 08:38:38 PM »
Oh so pretty!
If you could have a kickstarter machined to match, it would really look nice!
'06 Suzuki DRZ400S
'08 Honda VFR800
'77 Honda CB750K
« Reply #14 on: July 01, 2008, 10:33:53 PM »
Thats $1,000,500 now, I'll bet.
Did that get those 2 extra HP?  ;D
Offline coyotecowboy
  • Easily Distracted
    • American Legion Riders Post 69 Medicine Lodge, Ks
« Reply #15 on: July 02, 2008, 01:02:00 AM »
Hey Seaweb, where did you get those Tarozzi's from?  I saved a pic of them late one night and honestly couldn't remember where the hell I had gotten it from!! :D
The adventure begins when things stop going as planned - Glen Heggstad
http://www.alrpost69.com/
Sunrise Orange 750 K2
1981 Husqvarna 430 XC, "Inga"
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #16 on: July 02, 2008, 02:09:12 AM »
mike- if you don't figure it out sooner, i'll be installing a set on a '73 K soon, and will try a cb550F kickstart. if you can find one, give it a try. it was designed to clear the stock header which rode high along the frame for better cornering clearance. it comes out an extra inch at least.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline paulages
  • 1976 cb735
« Reply #17 on: July 02, 2008, 02:12:37 AM »
by the way, am i understanding right here? the levers don't pivot independent of the footpegs? the only thing holding up the custom rearsets i designed is figuring out how to eliminate this problem. i ripped mine from an old italian design (paton), but i welded the lever assembly directly to the peg in the mockup stage and haven't moved beyond that yet. if i had a lathe it would be a breeze...
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
« Reply #18 on: July 02, 2008, 04:28:00 AM »
Looking good Mike! Ill need to come round and test drive it for you  ;)
see you soon,
cheers
Andy
P.S. No engine leaks after 1600 miles on the K4 engine (most of that 2-up through the Adirondacks and I wasnt taking it easy  ;)).
« Reply #19 on: July 02, 2008, 04:48:51 AM »
Right Paul. The pegs and the levers are basically "one piece" design that rotate on a collar inside the peg. I had to modify the right peg to get it to work smoothly. The lathe made quick work of it.
« Reply #20 on: July 02, 2008, 04:53:52 AM »
see you soon,
cheers
Andy
That is good news Andy. ;) ;D
« Reply #21 on: July 02, 2008, 05:43:26 AM »
Columbia Car & Cycle..in Nakusp BC has some Tarozzi stuff..
« Reply #22 on: July 02, 2008, 06:13:10 AM »
I'm jealous!
Aluminum wouldn't be a good choice....especially on this engine!! ;)
Offline cbass*gxc
    • My Pics Page
« Reply #23 on: July 02, 2008, 07:37:01 AM »
Hey MR do you have any pics of the whole bike?  That thing looks freaking sweet!
Jay
Maybe I will do a search and see if I can find some.
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #24 on: July 02, 2008, 09:28:43 AM »
Jim Hinshaw
Fast from the Past, Inc.
PO Box 606
Hoschton, GA 30548
USA
770-614-0968 voice & fax
jimhinshaw@fastfromthepast.com
http://www.fastfromthepast.com
