Author Topic: Old tank as seat cowl  (Read 2731 times)
Offline ev0lve
« on: February 01, 2009, 12:33:42 PM »
Hey there,
I have a tank I'm considering trying to turn into a seat cowl. Basically I'd like to try and fit it up on the stock seat such that I could remove it if some fine lass (or my SO who also is fine - love you honey) decided to ride with me.
I figure some monkeying with the seat itself to add some mounting brackets under the vinyl and a couple bolts would do the trick. Clearly I have a sickness at this point.
Has anyone done this? Could you point me at the threads or post some pics?
Thanks
Re: Old tank as seat cowl
« Reply #1 on: February 01, 2009, 12:42:07 PM »
One of the first things I read on this site was Hopterfixer thread. http://forums.sohc4.net/index.php?topic=34200.0
Its not removable but may give some guidance, and it's a neat thing.
Offline ev0lve
« Reply #2 on: February 01, 2009, 12:49:27 PM »
I saw that. It is teh awesome  ;D
Every thread I can find seems to end with abandoning the idea of a removable cowl or never returning with the finished product.
Offline Mach-5(50)
    • ryan barr photography
« Reply #3 on: February 01, 2009, 12:59:22 PM »
here are a couple of ideas. i think it is a brilliant idea, as long as you have a tank with a shape you like.
http://dotheton.com/index.php?topic=7.0
http://dotheton.com/index.php?topic=2717.0
later,
ryan
The more adults I meet, the more I want to help kids.
i used to be drunk and dirty,
now i am clean and sober.
http://www.ryanbarrphotography.com
Offline ev0lve
« Reply #4 on: February 01, 2009, 01:21:21 PM »
It's a 750 tank with a lot of pin holes (since replaced) and I think it would look pretty good judging from cutting the bottom out of it and sitting it up there if I could get it low enough. Every pic I see of a 750 I like the cowl is just a bit lower than the tank. FunJimmy's thread illustrates that pretty well (not that it's a 750 but you get the idea)
http://forums.sohc4.net/index.php?topic=27159.msg414075#msg414075
These 2 machines are pretty skookum as far as I'm concerned for a cafe lite kind of thang (also not 2up). I suppose I'll have to hack the tank up to know for sure
« Last Edit: February 01, 2009, 04:13:38 PM by Iggy »
okie
« Reply #5 on: February 01, 2009, 02:52:33 PM »
It isn't a 750, but I liked the way it looked on my 350.
http://forums.sohc4.net/index.php?action=dlattach;topic=23251.0;attach=38660;image
Offline ev0lve
« Reply #6 on: February 01, 2009, 03:02:24 PM »
Same deal though? That's a 350 tank on the back? Just asking cause I'm thinking the proportion should make it a match. I like the upsweep in the bottom of yours though I'm looking to retain the fender with the tail light.
Looks damn good one way or the other!
fuzzybutt
« Reply #7 on: February 01, 2009, 03:19:35 PM »
triumphs thruxton has the removable seat cowl, all it takes to remove it is 2 screws, it has threaded inserts on the seat pan to accomodate the screws.
Offline ev0lve
« Reply #8 on: February 01, 2009, 03:24:06 PM »
That's EXACTLY what I'm thinking. Are there any pics of such a thing completed for a 750? I saw BCR's but I wasn't thinking of relocating the brake light.
http://www.benjiescaferacer.com/seatspics.html
fuzzybutt
« Reply #9 on: February 01, 2009, 03:35:08 PM »
damn thats a good looking seat................if only i hadnt just put almost 200 bucks into new foam and upholstery for the original k-4 seat.
Offline ev0lve
« Reply #10 on: February 01, 2009, 03:45:10 PM »
$600! Probably worth every penny too but...
Offline Frankenkit
  • Industrial Strength
« Reply #11 on: February 01, 2009, 03:57:20 PM »
OK! Now I have time to put my thoughts into words, pictures, and wild gesticulations.
My first thought went to this thread:
http://forums.sohc4.net/index.php?topic=43832.15
Then I got home and whipped out my photoshop and did a 3-pic, step-by-step visualization of what that'd look like on my bike.  Your results may vary.
Here, I just copied the tank and tilted it to fit the angle of the bottom of the seat. I'm figuring in real life application here, you'd want to weld on tabs to bolt on roughly where the seat bolts on back there, some sort of bracket.  I left it mostly transparent so you can see overlap.
The blue marks are just me thinking about where it could/should be cut, but I'm just thinking to keep it in line and maintain the shape you want.
Here I did hack and slash along the line, did a lousy photoshop job of removing the grab bar, and pasted on the nearby truck's taillight.  The only point of this being a rough mockup of the shapes that could be achieved while maintaining a stock stepped seat (though very few of us have 650s...)...
hth?
« Last Edit: February 01, 2009, 07:48:38 PM by Kit »
2012 CBR250R "Black Betty"
1980 CB650c- (sold) Delilah
1973 CL350- Lola?
Stuff for sale
Offline ev0lve
« Reply #12 on: February 04, 2009, 12:21:41 PM »
Why that's an excellent idea. Why don't I thin of these things? Dang.
Mocking up a 69 it sort of ends up looking liking an F bike somehow. Hrrrrrm. Pondering to commence.
Offline pampadori
  • slingshotcycles.com
    • Slingshot Cycles
« Reply #13 on: February 04, 2009, 01:07:34 PM »
i've done a couple.  the first is a CB360 tank turned bump seat.
the second is a XS650 tank turned bump seat.
www.slingshotcycles.com
brake hoses and more!
SOHC4 is your coupon code for 15% off!
