Author Topic: I've been K0'd!  (Read 199839 times)
Re: I've been K0'd! #4 was parted out, now getting parted in.
« Reply #850 on: February 02, 2024, 05:00:59 PM »
 This trans was in a box, I noticed the rings around a couple of the gears, does that make it an F transmission? The final gear has the same tooth count as the one that was in it. It's been in the solvent tank but still needs to be cleaned.
 An old shift fork was rubbed pretty bad also. I need to use the ones that came with this trans if I use it.
« Last Edit: February 02, 2024, 05:03:21 PM by Don R »
« Reply #851 on: February 03, 2024, 01:35:56 AM »
If you need to verify the trans to be K0-K6 vs later, F included
http://forums.sohc4.net/index.php?topic=169359.msg1965282.msg#1965282
The later trans has different gear on final shaft.
Here early (left) vs late (right)
The early one got the late final gear with new bearings after photos were taken to match the later trans that engine will get. Higher revs on 4-5.
That engine not yet assembled.
« Last Edit: February 03, 2024, 01:40:00 AM by PeWe »
« Reply #852 on: February 03, 2024, 10:25:10 AM »
 I have installed a backcut F2 trans in a K6 case, so am a little schooled in the differences but that engine is still on a stand waiting for a cylinder and pistons that may hold up to the turbocharger. Too many projects get in the way.
« Reply #853 on: February 03, 2024, 10:37:26 PM »
I have not assembled my bottom end yet. K5 number (K2-75 here)
Also backcut late trans.
« Reply #854 on: February 04, 2024, 08:31:52 PM »
  I've tried some different trans parts, I got a couple from a mini sprint car guy. The downside is it isn't one or two complete matching transmissions. I've been able to get it to go through the shift sequence a couple times but fifth is sometimes an issue. I have the original 1970 narrow path shift drum but was trying a later one, I may go back to the original and try it. It seems like the center shift fork is hanging up, it keeps trying to move the shaft with it. I cleaned and lubed it but not good enough apparently.  One mainshaft cluster had one ringed gear, it had the same count as a different non ringed one but the book has a different number of teeth.
 I called a wasted day and came inside.
« Reply #855 on: February 29, 2024, 06:35:35 PM »
 It was missing a thrust washer (found on the bench) and haven't put the neutral safety switch in it yet. Those would probably make it shift properly.
« Reply #856 on: March 06, 2024, 03:59:56 PM »
 I returned #1 K0 back to its wire wheel stock exhaust condition, it was a former BOM winner with Lester mags. It has the proper K0 front hub and early rotor and a 2-hole rear hub although riding on new spokes and DID rims. The wrinkly seat is an original. It got new BT46 tires this time.
  Building these wheels took a long time collecting the parts, and a covid project finding rims and re-lacing them. I finally put new tires on them and installed them.
« Last Edit: October 27, 2025, 11:05:41 PM by Don R »
« Reply #857 on: March 06, 2024, 08:41:19 PM »
Those wheels make bike look very good! ;)
« Reply #858 on: March 06, 2024, 08:59:08 PM »
The paint is awesome Don  8)
I think your K0 is a K-nock O-ut   :D  8) 8) 8)
« Last Edit: March 20, 2024, 10:53:26 AM by grcamna2 »
« Reply #859 on: March 07, 2024, 03:31:50 PM »
 Thanks, compared to the pic on page one there is quite a difference.
« Reply #860 on: March 11, 2024, 12:36:24 PM »
That bike has come a long way. Looks fabulous!
« Reply #861 on: March 11, 2024, 01:13:16 PM »
Ah, and in my favorite color, too!
:D
« Reply #862 on: March 13, 2024, 06:13:07 PM »
This bike still looks like a BOTM winner!
« Reply #863 on: March 19, 2024, 09:18:21 PM »
 Thanks. I even have an early head diecast motor in case I want to get really crazy going original.
« Reply #864 on: March 19, 2024, 10:00:12 PM »
I fully agree with you.
I nominate the bike (and owner) for BOTM!
Offline Prospect
« Reply #865 on: March 20, 2024, 02:03:38 AM »
Looks great!
Current Bikes
1969 CB750  Sandcast #256
1971 CB750K1
1972 CB750K1
1975 CB400F
1975 GL1000 Goldwing
1954 Harley Davidson Panhead
1957 Harley Davidson Panhead
Toronto Canada
« Reply #866 on: August 20, 2024, 11:41:21 PM »
 I got the diecast out for a ride today, I went to help a friend wire a relay onto his 52 chevy pickup.
  It turns out he had an award winning chopper shop once. He was even invited to do a biker build off, the problem was he didn't have the $150K he needed to build the bike. I saw the trophies, magazine covers and the pictures.
Re: I've been K0'd!
« Reply #867 on: November 23, 2024, 04:33:17 PM »
 I dug through the shock tote and pulled out a set of bent shaft, aluminum top end shocks with 3 position adjusters. I pressed them apart and removed all of the accessories. Later this winter I'll check out the repro Z1 Sandcast shocks to see if I can swap the 5 position adjusters off of them.
 My guess is those old shocks had been mounted on lowering blocks.
« Last Edit: December 17, 2024, 09:44:36 AM by Don R »
Re: I've been K0'd!
« Reply #868 on: January 08, 2025, 10:46:21 PM »
 I stumbled across this pic of the red sandcast and his brothers this evening. I resolved to get it over 10,000 miles this year.
 Gold is almost all original except the paint, seat and exhaust, Blue-Green was totally gone through by me. I repaired the frame and built the 836, it still has a no number diecast engine waiting for a rebuild.
  The red sandcast was assembled new by a friend Charlie that runs a mom-and-pop bike shop, the week before he left for Vietnam. It was bought new by Gene, a guy my brother knew, I saw him at work from time to time. A good friend was buddies with his son and grew up at his house, Gene passed and then my old Honda guru Tom owned it. He didn't title it or get it running. I used to take pictures of the cable and wiring routing for my blue green bike assembly. ALS took Tom from us, and I bought it at his estate sale. Later, his family offered to sell me the drag bike and I got it too.
« Last Edit: October 27, 2025, 11:34:24 PM by Don R »
Re: I've been K0'd!
« Reply #869 on: January 09, 2025, 05:56:01 AM »
Don….. did you repaint the red one? Looks lovely.
Re: I've been K0'd!
« Reply #870 on: January 09, 2025, 06:55:21 AM »
beautiful fleet of bikes.
Awesome
Re: I've been K0'd!
« Reply #871 on: January 09, 2025, 03:59:26 PM »
  Yes and no, the airbox and sidecovers were painted, the rest is original. The PO's son was riding it to school and one day he pulled the motor and had a few parts chromed.  The Dad had a cow and once it was back together neither one ever rode it again. After the Dad passed away, the Mom asked the son if he wanted it and the sour grapes made him say no. My buddy that had always serviced it bought it for $500 and then let it sit in the "Big 4 Bike Shop" until he was gone and I ended up with it.
Re: I've been K0'd!
« Reply #872 on: January 09, 2025, 06:20:20 PM »
Great story. It’s great that you have it.
Re: I've been K0'd!
« Reply #873 on: January 10, 2025, 05:54:42 AM »
Really nice bunch of bikes.
Sell them $$$$$$ or keep them must be a dilemma.
Stock early CB750's are very attractive for many.
Re: I've been K0'd!
« Reply #874 on: January 10, 2025, 09:28:50 PM »
Yes that set of K0's Are NICE Don.  :) ;) 8) 8) 8)
