Author Topic: What did you do to your bike today ?  (Read 3642273 times)
0 Members and 7 Guests are viewing this topic.
Offline grcamna2
« Reply #17225 on: April 15, 2014, 03:38:55 PM »
What nice,clean,New electrics on that one  ;) fire113
75' CB400F/'bunch o' parts'
Offline Cvillechopper
  • Is just pretending to be an
  • If not for my failures I'd never know my limits
« Reply #17226 on: April 15, 2014, 04:12:18 PM »
I went out to the shed, gazed longingly at my bike, then wiped a tear off my cheek and came back inside.
It is the mark of an educated mind to be able to entertain a thought without accepting it.  Aristotle
Offline Jerilee
« Reply #17227 on: April 15, 2014, 04:21:28 PM »
I bought some new handlebars off Bike Bandit for the project. A little spendy, I'd meant to buy suspension parts when I next opened the purse, or finish rounding up seat and fender parts, but it was still on the list, so it counts! : )
Jeri~
My F2 build http://forums.sohc4.net/index.php?topic=126314.0
77/78 cool 2 member
Offline grcamna2
« Reply #17228 on: April 15, 2014, 04:32:02 PM »
Were you sad because it was too cold to ride ?   ???
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #17229 on: April 16, 2014, 03:43:21 AM »
Thanks, folks, for the tip of using the alligator clipped light for a "fuse". Popped it on the fuse holder, and ran through my switches... turns out it was my blinkers.
Lesson of the day: ALWAYS DOUBLE CHECK YOUR WIRING. Especially when your blinkers come with no instructions and you go off your "intuition". It resulted in a popped fuse or three, a busted electronic flasher unit, and a burnt out bulb after my unsteady hands were testing the bulb's leads. Luckily I kept the original flasher to continue testing. Today will bring a new bulb and electronic flasher.
Once I had everything checked and wired properly, I was able to button up the headlight bucket, and everything works peachy! Also on there are reinforced rubber washers as mentioned, too. This is going to be a great setup. Now just to tidy up some of that excess wiring, a new brake hose from Slingshot, and front end should be good to go.
Another lesson of the day... Apparently my bike is a SERIOUS basket case. Switches are not K5 (Br/W is not on both switches) but the switches are all where they should be, and the main harness is not K5 either. There are TWO Br/W lines coming to the bucket from the main harness, among other things. Thankfully PO had labelled everything, and it all works just fine.
« Last Edit: April 16, 2014, 03:47:01 AM by evanphi »
--Evan
1975 CB750K "Rhonda"
Offline fire113
« Reply #17230 on: April 16, 2014, 08:45:45 AM »
...not @the K0, @the K2 ;)
Offline grcamna2
« Reply #17231 on: April 16, 2014, 11:16:37 AM »
You'll be doing this one's wiring next ?
Offline fire113
« Reply #17232 on: April 16, 2014, 11:46:21 AM »
...nope, going to do the next wiring @ the other K0 project.
« Reply #17233 on: April 16, 2014, 06:03:18 PM »
Recovered this 550 seat. The PO just used duct tape to repair it.
Stripped 'er down...
New cover and trim back on...
I've recovered other seats but this is the first that I am truly happy with. Bought the cover on ebay for $48 shipped.
Nothin' like a nice seat!
Offline Tews19
  • I am no
« Reply #17234 on: April 16, 2014, 06:51:22 PM »
Stev-o that looks great. How does the material feel?
1970 Honda CB750 survivor.
« Reply #17235 on: April 16, 2014, 06:54:15 PM »
Thanks.....it's soft and supple
Offline Tews19
  • I am no
« Reply #17236 on: April 16, 2014, 06:55:35 PM »
Mind texting me the link.... maybe he has k1 covers.
« Reply #17237 on: April 16, 2014, 07:11:06 PM »
done
Offline goldarrow
  • one day, i'll be an
« Reply #17238 on: April 16, 2014, 07:13:12 PM »
Great job, stev-o
CB550 K0
Offline grcamna2
« Reply #17239 on: April 16, 2014, 07:21:34 PM »
done
Stev-o, Ever have a seat done at Sargent's in Fla. w/ their 'atomic space foam' ?
« Reply #17240 on: April 17, 2014, 03:02:48 AM »
Wow that does look like a nice cover and good job Steve.  Does that seller have 750 covers ?
« Reply #17241 on: April 17, 2014, 04:53:40 AM »
Thanks, and yes, he makes them for 750's as well.  Looks like prices have gone up slightly to $53 shipped.
They are made to order, but still took less than a week.
http://www.ebay.com/sch/m.html?_odkw=&item=171291482576&_osacat=0&vxp=mtr&_ssn=joemama1931&_trksid=p2046732.m570.l1313.TR12.TRC2.A0.H0.XCb750&_nkw=Cb750&_sacat=0&_from=R40
Offline fire113
« Reply #17242 on: April 17, 2014, 06:32:46 AM »
...parts arrived, it's like Christmas on Eastern  ;D
Offline OT7
« Reply #17243 on: April 17, 2014, 11:57:08 AM »
 :) First short ride. 1976 CB550F checked tire psi , checked chain, install Scorpion AGM battery.
Started right up, purring like a cat.
Offline grcamna2
« Reply #17244 on: April 17, 2014, 12:43:10 PM »
OT7,
That Scorpion battery you installed was the equivalent to Yuasa# YB12A-A ? if I may be so bold,what did you end up paying? and how long of a warranty do they come with ?
Offline OT7
« Reply #17245 on: April 17, 2014, 01:03:19 PM »
 :)  Equivalent to Yuasa #YB12A-A.
Cost $59 free shipping , 1 year warranty.
Third season with AGM battery voltage checks ok.
Tired of messing with flooded cell battery.
AGM is the way to go.
Offline grcamna2
« Reply #17246 on: April 17, 2014, 01:32:45 PM »
OK OT7  :),
I've been looking at this other brand Motobatt and they have a 2 year warranty but the price is $81 shipped and that's a few more tanks of gas for me. You're happy w/ that Scorpion ? When you say "third season", is that with this particular YB12A-A? What's the Scorpion model# for it ? I want to do some more research. That YB12A-A size is one of the most common size batteries for Vintage cycles for many years now.
        Thanks, Bill
« Last Edit: April 17, 2014, 01:37:32 PM by grcamna2 »
Offline fire113
« Reply #17247 on: April 17, 2014, 01:41:48 PM »
...mounted the pipe, did some electric, put a ignition cover and rode it.
Offline grcamna2
« Reply #17248 on: April 17, 2014, 02:06:01 PM »
fire,
That exhaust reminds me a little of the BMW stlye., is it Stainless Steel ?
« Reply #17249 on: April 17, 2014, 02:10:49 PM »
OK OT7  :),
        Thanks, Bill
I just got this one for $66 total.  Came fully charged and ready to go.
http://www.batterystuff.com/powersports-batteries/sYTX14AHL-BS.html
