Author Topic: What did you do to your bike today ?  (Read 3705757 times)
0 Members and 12 Guests are viewing this topic.
« Reply #12300 on: October 15, 2012, 12:15:05 AM »
I posted in my build thread but have to show tthe video here too. From not running, last registered in 1971...
http://s1090.photobucket.com/albums/i373/Tews19/?action=view&current=116.mp4
To running...
Looking good mate, well done! (not sounding too good though...........) ;D
Offline Brookesy in Oz
« Reply #12301 on: October 15, 2012, 12:57:17 AM »
Actually yesterday - but it still counts.
Cleaned and installed the rear guard, continued cleaning the exhaust and baffles, fitted the battery box, tool tray, side stand, new seat & catch (all previously resprayed about a year ago (except the seat)). Cleaned a few bit and pieces. My bench polisher has gone out in protest - need a new one. Fitted the oil tank, side covers & then settled down (after a shower) with a bourbon or two and Hondaman's bedtime stories.
Honda CB750 K1 - awesome
Honda CB450 K5 - current project
Honda CB750 K2 - sold
Kawasaki Z1000 - sold
Offline fire113
« Reply #12302 on: October 15, 2012, 02:26:08 AM »
...scored a K0 gas cap  ;D
Offline Tews19
  • I am no
« Reply #12303 on: October 15, 2012, 05:49:43 AM »
To running...
Thanks! There are massive holes in the exhaust. New pipes are on their way.
1970 Honda CB750 survivor.
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #12304 on: October 15, 2012, 06:38:08 AM »
Rode the holy hell out of the 500 on a beautiful day, on awesome roads...had a blast!
« Reply #12305 on: October 15, 2012, 07:27:44 AM »
got my yamaha started...have put an other crankshaft in..
yamaha dt lc 125
« Last Edit: October 15, 2012, 07:29:21 AM by strynboen »
Offline longshanks
« Reply #12306 on: October 15, 2012, 11:40:10 AM »
To running...
exhaust sounds great! hm300? that clacking sounds like stretched primary chains, I could be wrong though.
cb450 K5
Offline fire113
« Reply #12307 on: October 15, 2012, 01:43:36 PM »
...polished the last needed parts.
Offline Tews19
  • I am no
« Reply #12308 on: October 15, 2012, 01:50:22 PM »
To running...
It's the exhaust that sounds like that. There are a lot of holes in the pipes including some really big ones. Engine sounds really good. I even had to put my ear down to it to listen to how quiet it is. Stoked about this one.
Offline 750resurrection
« Reply #12309 on: October 15, 2012, 06:06:35 PM »
 Finished installing cleaned and idle jetted carb & wintergreen boots took a few miles test ride, then instead of doing sync and idle screws, I did the cam chain tensioner / static top dead center comp #1 + 15 deg deal in the 1970's update bulletin and get this - I heard the tensioner snap in tighter when I loosened the lock bolt.  ;D Awesome so stoked.
maduncle
« Reply #12310 on: October 15, 2012, 10:18:21 PM »
Nothing on my bike today, but I did discover that I am distantly related to Australian motorcycle racing royalty.
My sister in laws uncle who sadly died in 1978 is Bryan Hindle.
And it turns out that Brian taught Ken (the guy working on my CB450 head) how to race.
Freakingly small world!
Offline veloracermike
« Reply #12311 on: October 16, 2012, 10:42:34 AM »
I am unfortunately in Bristol CT cranking out sausage for ESPN...but if I were at home I'd be re-torquing my head bolts and getting ready for the Harvest Classic that I'll be missing this weekend!
« Reply #12312 on: October 16, 2012, 10:54:01 AM »
Okay, so far today... after yesterdays wintergreen boots and prior carb pull and dunk clean and slow jet drill, had a #2 float overflow and crappy acell pump drip- knew needle and diaphragm were iffy, so off came the carbs again today, I am getting to be an expert 10 mins she's off.
 So I changed out the needle with a spare and the acellerator pump diaphragm with a used spare, and back on went the carbs. Much better. No leaks, fires right up, no overflows.  ;D
 Next is tappet clearance check if I don't dork around maybe a half hour, then home made carb sync, idle screws adjust.  8)
Offline CycleRanger
  • No comment about being an
« Reply #12313 on: October 16, 2012, 10:56:21 AM »
While the guys are here digging giant, expensive trenches in my yard to fix my septic system I went and got the K5 inspected.
Hopefully they'll leave me with enough money for beer this weekend. :P
Offline WhyNot2
  • I'm finally an
« Reply #12314 on: October 16, 2012, 12:16:42 PM »
Was going to ride to work this morn, turned the switch on, hit the starter button......."clickety, click".............aw crap.
Kicked it a few times, fired up.....but, lights would get bright @ high rpm, and dim @ low rpm.
So, I either have some bad connections or a bad battery , though I had it on the charger over the weekend.
Pushed it back in the garage, got on the Harley and rode to work, got a call from the wife, she noticed the 750 was leaking (forgot to shut the gas off) so she pushed it outside, left it there, and went to work.
She called me, told me what she did and I asked her if she removed the key from the ignition.........her response was......"key, what key................awwwwwww crap, now my bikes sitting outside with the key in it, and no ones home.
And the dog is locked up in the garage....................go figure.
« Last Edit: October 16, 2012, 12:19:54 PM by budlite282 »
« Reply #12315 on: October 16, 2012, 12:27:46 PM »
Okay - valve tappet clearance is done.  ;D I had done it on the pile a few years ago and not a lot of miles so they were all very close, I think I moved like 2 of 8 just a hair, #3 intake was off the most that was the clogged idle jet I wonder if it wore that valve some...
 Looks like it took me about 1hr, took my time and enjoyed it went well without a hitch.
Offline MoMo
  • Ride like you're invisible
« Reply #12316 on: October 16, 2012, 01:52:20 PM »
Feel for you CR, I had to have a 17 year old system replaced to the tune of 12,300....Larry
« Reply #12317 on: October 16, 2012, 01:55:35 PM »
exactly the way it should be!!!  8)
« Reply #12318 on: October 16, 2012, 01:59:48 PM »
Rode to work and rode back, I love fall in Virginia.
Offline WarwickE36
« Reply #12319 on: October 16, 2012, 03:04:59 PM »
Finally went and got my license, haha.  No more riding dirty, no more permit.  'bout time
" Why does anyone get offended by what someone does to their own bike? I dont get it. "
You made me think about it after I cheered knowing someone else would like to know what these control freaks are up to.
 Every time any owner strips whatever precious Honda part the horrified purists parts go up in value. That's not the part that bothers them.
 What bothers them is they sat up late at night, their breast full of wonder and estrogen, unable to sleep, dreaming about their lovely darling and all her glory... and next thing you know someone else doesn't share their emotional deluge and their reaction is they must spread their mind museum as far as they possibly can, taking over as much of the real world as possible.
Drink fast, drive slow, but ride it like you stole it
1974 Cb550 with style
2004 SV650s
« Reply #12320 on: October 16, 2012, 08:40:07 PM »
Back in - finally, from the  valve lash check and carb balancing. Took a trip to check it out, I cannot even freakin believe it... the handlebars don't vibrate like heck anymore. The rear view mirrors no longer need their shock absorber add ons.  ;D
 I freakin coasted in, in second gear, up the bump and across the field, not even touching the throttle she just chugg chugga chugged pumpumping along... LOL
 It was frikkin great.
Offline Picasoo
« Reply #12321 on: October 17, 2012, 05:16:22 AM »
Put a new carburetor sets... Wohoooo I got a "new" bike :)
'75 cb750F super sport
Offline WhyNot2
  • I'm finally an
« Reply #12322 on: October 17, 2012, 06:59:01 AM »
Found out the battery was bone dry, is why the 750 wouldn't start yesterday.
Was still in the driveway when I got home.
Filled with denatured water and she fired right up.  All is good.
Chilly ride in on her this morn.
Offline fire113
« Reply #12323 on: October 17, 2012, 01:32:46 PM »
...completed the legs.
« Reply #12324 on: October 17, 2012, 01:38:39 PM »
clear and a chilly 37F/2.8C this am (I need a neck gaiter)  A gorgeous day in the PNW....
seat-o-the-pants test says new plug caps make an old bike 'friskier'
