Author Topic: What did you do to your bike today ?  (Read 4000061 times)
0 Members and 16 Guests are viewing this topic.
Offline SOHC Digger
  • I'm not an
« Reply #20250 on: July 26, 2015, 05:35:42 PM »
Put about 50 miles on the digger to spend some garage time with ZZPete...
Good to see the Digger's on the road still mate, and give Pete my regards, I haven't seen him on here in ages! ;D
The clock on the digger just passed 1,000 miles. Runs beautifully!!!
Pete's doing great. He's been avoiding the computer because before he knows it, he's lost hours of garage time to it. He's in the middle of an engine overhaul right now. Even if he's not on the forum, he's still focused on the bikes.
Offline Gene
  • Chat enuf you too can be a
« Reply #20251 on: July 26, 2015, 05:51:57 PM »
Replacement petcock, new in-tank filter.  First time in my ownership this sh*t ain't leaked.  Very very happy.  It's an old, bad, one-year model.  Thank you eBay.
« Last Edit: July 28, 2015, 12:39:27 PM by Gene »
*1973 CB750K3 (Bow)
DH
« Reply #20252 on: July 28, 2015, 05:47:49 AM »
Fixed finicky neutral switch operation. Installed a slightly thinner o ring. A 10mm quarter inch drive universal socket would make this job easier if you do it when the engine is on the bike. :P
Online PeWe
« Reply #20253 on: July 28, 2015, 10:45:18 AM »
Synced my carbs again.
Other cam installed = sync carbs? I cannot find other reason than different cam and valve adjustment. Mikuni TMR throttle adjusters real PITA!
« Reply #20254 on: July 28, 2015, 12:12:28 PM »
Unless you separated the carb bodies, or removed the slides, there is really no reason to re-sync
Offline edwardmorris
  • Youngish
« Reply #20255 on: July 29, 2015, 07:20:35 PM »
Took it out for a spin today and ended up stranded on the road :'(
No idea what happened, was happily in 5th and all of a sudden it turned off on me. I pulled over, looked for obvious things. Fuse is intact, carbs are getting fuel, all connections from the points out are intact, all connections to the coils are intact, all spark boots are in place. When I hit the start button it cranks/turns over but doesn't start. Ended up towing it home on a flat bed. Ideas? Please advise in my build thread...
Offline Sgt.Pinback
« Reply #20256 on: July 30, 2015, 08:17:39 AM »
Short cut in killing switch?
Doc, I love a motorcycle!
Online PeWe
« Reply #20257 on: July 30, 2015, 08:37:47 AM »
I could not do with my bike as intended due to thunder and heavy rain. Drive it to verfy low speed with synced carbs. Must run smooth without jerky throttle response.
Only thing is raised needles in all 4, different pilot jets. Maybe the adjuster nuts that can move. I'll see if they change again.  Threadlocker (blue) might be too tough.
« Reply #20258 on: July 30, 2015, 08:46:42 AM »
If you touch the slides, another vacuum sync is advisable.
Offline joeyvans
  • Definitely not a
  • God's Country, Earth
« Reply #20259 on: July 30, 2015, 08:53:51 AM »
Man, is it ever! I'd say more mandatory than advisable. I switched clip positions last night with carbs on the bike, so no bench sync. Ran like garbage and didn't have time for a vac sync. Had to turn the idle screw way in to get it to even run. Can't wait for a vac sync tomorrow night.
1976 CB550 K2
Non-SOHC4 - 1974 CB450 K7
Non-SOHC4 - 1996 VFR750F
"No matter how much you shake and dance... the last three drops go in your pants."
Online PeWe
« Reply #20260 on: July 30, 2015, 11:25:14 AM »
I do not think I changed the slides when the needles were lifted without lifting anything else except fot the cover and an allen head nut keeping needel in place. Lift needle with a thin plier or similar. Slide is the black rectangualt plastic thing...
I noticed that the carb sync affect each other. When one carb is too high, the engine rpm arise and make more vaccum in the other.
The nut with blue dot is sync adjustment. The mikuni spare part chart call this for lock nut, but its design is concentric and will affect the slide position. The idle is now better than ever, now more like r-r-r-r-, before more d-d-d-d.
I have to drive and see if the nuts vibrates in different positions and out of sync.
I'll use Loctite 222 next time  http://www.loctite.co.uk/loctite-4087.htm?nodeid=8802623422465
I'll search, find and order right now. Good stuff to have.
EDIT: I might have moved the slides when the nut that cover the needle was tightened rather hard. I tightened it with the allen screwdriver before but had to use an angled tool for removal next time.
« Last Edit: July 31, 2015, 03:14:38 AM by PeWe »
Offline MJL
  • Don't listen to me, I'm no
« Reply #20261 on: July 30, 2015, 09:33:01 PM »
Not today but a few weeks ago... (Forgivee if I already posted this, I have so many projects on so many forums its hard to keep track sometimes)
Finally got around to ordering and installing a shift cover gasket on my '73 750. After, I decided to install my new used carbs on my '73 500. It's a barn bike that I bought several years ago, it was last registered in '83. It had been parked for 30 years. Before I put the carbs on, I sprayed the intakes with some ether, hooked up a car battery, and kicked it over a few times. To my delight it started and ran a couple seconds.
Now it's sitting and waiting on me to install the new petcock and de-rust the tank. Then just a battery and tires before I find out it was parked because of clutch issues.
« Reply #20262 on: August 01, 2015, 07:14:42 AM »
Rode the H1 very cautiously....yeah right!
Offline FrankenFrankenstuff
    • FrankenBike Stuff Store
« Reply #20263 on: August 01, 2015, 08:35:08 AM »
Decided to play with the 90. Stock bars bye bye. Suckville.
Offline eigenvector
« Reply #20264 on: August 01, 2015, 12:36:48 PM »
Finally got that fork seal replaced.  Took me long enough, but I was splitting my time between getting the air leaks out of the C750 and work (you know, actual get paid so I can eat work).
I have to give a big shout out to Stev-O, C-clamp to remove it, old seal to press it in.  Worked like a charm.
Seems like there's an awful lot of room between the seal and the bottom of the seal well.
Waiting for the heat to die down before attempting to put the cap back on the fork.  It's HOT out today and I can feel a burn coming on.
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
Offline Desert-SOHC
  • It's old
« Reply #20265 on: August 01, 2015, 02:01:28 PM »
Got the weird replacement bulbs in for my blinkers and now she is completely legal and everything works.
90 F350 Lariat CS S/C Dually
90 S&S 11SC Cabover Camper
97 FLHTP (under construction)
11 Ranger S/C 2wd
Offline Gene
« Reply #20266 on: August 01, 2015, 02:23:36 PM »
Shiny new fuel line - just cuz
*1973 CB750K3 (Bow)
Online PeWe
« Reply #20267 on: August 01, 2015, 02:29:10 PM »
Finally weather for a tour on the bike! It ran really smoothe this time! Carbs correctly synced.
Really smooth starts without jerky throttle response or sticky clutch.
« Last Edit: August 01, 2015, 02:31:20 PM by PeWe »
Offline db22
  • Old and in the way.
« Reply #20268 on: August 01, 2015, 07:06:17 PM »
Mocked up the project bike with the painted tank and fender.  Installed the carbs with 108 mains and 42 pilots, based on the last test run about two weeks ago.  Decided to build a plywood seat pan that follows the bend of the Harisuluv hoop, and rout spaces for the electrics and battery. I'll then build a plywood cover to match, and build and upholster the seat onto that.  Looking for a usable MAC 4-into-1 header to fit a 550K frame -- the old 4-into-2 system I have for this bike is really ugly.
« Last Edit: August 01, 2015, 07:10:09 PM by db22 »
1975 CB550K (rider)
1975 CB550K (shaping up, slowly)
I may be goin' to hell in a bucket, but at least I'm enjoyin' the ride. . .
« Reply #20269 on: August 01, 2015, 08:10:19 PM »
Just listed my vintage alloy cb750 cafe tank on eBay for $99. Well boys....that is about it. The only Hondas I have now is the S90 and a Z50.....can I still come to the forum??
« Reply #20270 on: August 01, 2015, 08:10:38 PM »
« Reply #20271 on: August 02, 2015, 12:26:48 AM »
Online PeWe
« Last Edit: August 02, 2015, 01:39:41 AM by PeWe »
« Reply #20273 on: August 02, 2015, 02:59:46 AM »
Wow! How'd you do that PeWe, one minute you're a man, then you somehow transformed into a hot chick! ;D
Online PeWe
« Reply #20274 on: August 02, 2015, 09:36:18 AM »
Magic that can happen on a CB750! A tour on the bike takes them to heaven, wife included.
« Last Edit: August 02, 2015, 09:46:10 AM by PeWe »
