Author Topic: What did you do to your bike today ?  (Read 3889598 times)
0 Members and 17 Guests are viewing this topic.
« Reply #33525 on: November 17, 2025, 05:45:39 AM »
...took the K2 for a ride and after it I stroed it in the barn for the winter time.
Sad times…. I’ve been hoping for “one more” but might have to give up.
« Reply #33526 on: November 17, 2025, 06:44:39 AM »
Condolences, it's good to have something to look forward to.
« Reply #33527 on: November 17, 2025, 10:40:21 AM »
I also had hopes for a ride a week ago. The weather app showed +9*C and sunny for the Saturday earlier that week.
That changed to colder and rain.
I had planned to ride my 2 CB750 90-125km each to test how the oil will affect gearbox and clutches after zinc additive added.
They had only idled for ca 10-15 minutes to mix the additive in oil.
Next oil changes will get zinc added in a 5L jar with 3L oil before change.
The motorcycle oil that work with modern bikes with catalytic converters has around 800-1000ppm zinc or even less.
See API classifications and oil specification of actual oil.
Our old bikes need more. I have earlier  used Red Line or  Spectro motorcycle oils as is or mixed as an additive.
Now other motorcycle oil with less zinc I found a hopefully good additive for.
https://ebay.us/m/oMpKDH
« Last Edit: November 17, 2025, 12:22:41 PM by PeWe »
Offline CycleRanger
  • No comment about being an
« Reply #33528 on: November 17, 2025, 11:22:37 AM »
Charged the batteries on four bikes and stared at them hoping to find find time to ride them soon.
« Reply #33529 on: November 17, 2025, 12:42:41 PM »
Per…..That looks like interesting stuff, at a reasonable price. Have you used it before?How much will you add to 3 litres of oil? One oz.? Thanks!
« Last Edit: November 17, 2025, 12:44:56 PM by BenelliSEI »
« Reply #33530 on: November 17, 2025, 08:52:02 PM »
The package of the zinc bottles or home page say:
When blended with six quarts of oil, two fl. oz. of ZINC will achieve a maximum level of 3200 ppm (Ideal for new engine break-in); for properly running engines seeking additional protection.
Use one fl. oz. of ZINC (to achieve a 1500-1800 ppm level).
2fl oz= 5.9cl
1 floz = 2.95cl
Six quarts=5.68L
1500-1800ppm feels OK
(0.0295/5.68)x 3=0.0155
1.55 cl in 3L oil
If using 1/4 bottle, 1.475cl
The mix is reduced by 5%
I used 1/3 bottle for all oil in, 3.5L
Ca: 1620ppm - 1944ppm
- 1/4 bootle in oil changes  usually 3L (3 quarts) 2.8-3.0L.
1400-1700ppm (3L)
My K6 got a little more. But it has hard valve spring setting. Shimmed race springs to Kibblewhite spec
I do not know if the oil's zinc content is added or if they calculate with 400-800ppm already in the oil.
« Last Edit: November 21, 2025, 12:03:18 PM by PeWe »
Offline WhyNot2
  • I'm finally an
« Reply #33531 on: November 18, 2025, 04:40:34 AM »
I do the exact same thing........just look at them.!!!!!!!
« Reply #33532 on: November 18, 2025, 05:17:53 AM »
2fl oz= 5.9cl
1 floz = 2.95cl
Six quarts=5.68L
1.55 cl in 3L oil
1400-1700ppm (3L)
I do not know if rhe oil's zinc content is added or if they calculate with 400-800ppm already in the oil.
Per….. Thanks for all the info. I’ve ordered some!
« Reply #33533 on: November 18, 2025, 05:48:44 AM »
Oil thread warning!! ;D
Always something to add and test.
I have looked for additional zinc without other slippery additives not good for a motorcycle wet clutch.
This seems to be the stuff.
I also read somewhere when looking up things:
- Too much zinc is not good for the bore surface ending up in burning oil. Zinc will apply a protective surface for metal to metal contact.
I wonder how much too much is?
Forum member ofreen has used Spectro 20W-50 HD Mineral for lots of miles without repair. So 1900-2000ppm is not too much ;D
- Oils with higher amount of detergents remove zinc. (Diesel oils with usually high zinc content have more detergents)
« Last Edit: November 18, 2025, 08:17:23 AM by PeWe »
« Reply #33534 on: November 18, 2025, 06:41:43 AM »
I'll make some popcorn.:-)))
Offline lash
« Reply #33535 on: November 18, 2025, 08:04:59 AM »
Oh No !
« Reply #33536 on: November 18, 2025, 08:18:10 AM »
« Reply #33538 on: November 18, 2025, 01:19:23 PM »
Well it's been an interesting few weeks. I'm pretty much retired due to receiving the terrible (I'm joking) news that I was being made redundant, along with around 40 other defence consultants, as a result of the company I worked for not winning the contract that I've been working (joking again..) on, for the past ten years. Not at all unhappy, I'd intended to retire at the end of the year, and a I got a little "Golden Handshake" which was the icing on the cake.
Of course, in accordance with my record of self harm, I've managed to crack 5 ribs in two different incidents. I bought an old ride on mower on FB Marketplace and collected it in my ute. I got home and decided that I could lift it out of the back of my little truck, against the laws of physics, like most laws that I tend to ignore. I managed to drop the front wheels on the ground ok, but when I tried to pull/lift the back of the mower down, the weight of the machine (probably about twice my own weight) made it drop straight down, causing me to spectacularly somersault over the mower and land, head first on the concrete, busting 3 ribs on my right side of my chest. A couple of days later, when pulling on my bike boots, I slipped off the corner of my bed onto the floor, breaking another 2 or three ribs on my back. Oh well, it only hurts when I laugh, sneeze, cough, burp, fart, or breathe. So far it seems to me that retirement is a very dangerous occupation...
I made a decision to get rid of my surplus bike parts, so sold off all of my CB750 parts, less any spares for my K0. The buyer was very happy with the back of his big four wheel drive and a tandem trailer stacked 5 feet high, and has been madly selling off the parts, something I wasn't interested in, running back and forth to the post office every day to mail off various widgets all over the country. He'll make a lot of money out of it, but I was happy with the wad of cash he gave me, and allowed me to buy a new Yamiya paint set in that blue/green colour, for when I eventually re-restore my K0, that was actually originally blue. I'll keep all of the original parts for if I ever sell the bike and if the buyer wants the "correct" tank, sidecovers, airbox and headlight ears and restore them.
On top of all that, I bought a few more bikes. Another VMax (I had to, it was there..) swapped some parts to Spotty for a 1999 Yamaha "Venture Royale", bought a 1994 Kawasaki ZZR1100 (another "non runner" from the Auction place where I bought the second VMax) which I was kind of dreading after the first "C" model I bought a few years ago, that needed a replacement crank, rod, cylinder sleeve and piston, due to a problem encountered when certain riders spent most of their time on the back wheel, causing the oil to sit at the back of the engine/gearbox and starving the crank of oil, causing oil starvation.
As it turned out, the "new to me" 1994 "D" model I bought and picked up on Thursday only needed some tinkering, some lock picking (came with a re-cut ignition key that didn't fit the fuel tank, seat lock, helmet lock, and worlds tiniest glove box) a battery and fresh fuel and even though it had been sitting for many years in the back of a bike shop, the next morning it fired right up on all 4 cylinders like it had never had an extended rest. The Michelin tyres are in great condition, and once pumped up, I topped up the oil (waiting for a new filter so I can fill it up with new Castrol 4T bike oil I bought for it) and coolant, bought an "Unregistered vehicle permit" so I could take it for a quick (very quick, I saw 280 KPH/174 MPH for a few seconds and it was still pulling away) 70 mile ride on Friday, and I found it to be a magnificent beast indeed, with good handling, pothole absorbing suspension, and excellent brakes. For less than $1000 USD, it was a bargain, I paid more for my CB750 Hindle exhaust system.
Terry’s ZZR1100 14 November 2025 by Terry Prendergast, on Flickr
On top of all of the above, I sold my Triumph Rocket III and VTR1000F (through the auction place) and dropped over my two BMW K100RS' and Honda Varadero project to sell.
A guy here in Oz bought a CB750F2 with a Rajay(?) turbo attached, and came with a spare turbo kit. I asked him if the spare turbo kit was for sale, he said it was and told me how much, I agreed, and he told me that I was the lucky buyer, he'd send me pics when he came home from work, and give me a call to arrange postage. The trouble was, I didn't want to turbo my K0 and had just sold off all of my CB750 stuff. I saw a pic of an old CB750 Chopper with a turbo attached, and thoought, "hmmnnn". Coincidentally I saw a cheap Suzuki TR250 race bike replica for sale on FB, and agreed to buy it. While chatting to the seller I told him that I'd just soold a load of CB750 parts. He replied that he had an old CB750 chopper in his garage, if I was interested? Was I interested, you fcuking bet I was! I bought it, and the little Suzy, and Spotty and I drove 100 miles each way on Sunday, and collected them both.
It was a big weekend with the (sadly, last ever) Bendigo Swap Meet, Australia's biggest swap meet on Saturday (leaving home at 4.30 to get there by the time the gates opened at 6 so we could grab all the bargains) then the drive to Phillip Island (the home of the worlds best motorcycle race track) to collect the chopper. We made another couple of stops on the way home to check out my mate Fred's absolutely immaculate "Better than brand new" CB750 K1, then to collect some Harley wheels that were going cheap, so by the time we got home we were both so worn out, we unloaded his work van, snapped a couple of pics, and went our separate ways.
Terry's chopper 16 November 2025 by Terry Prendergast, on Flickr
Now, of course the chopper hasn't run this century, so there's plenty of rust, and the top end is seized. Funnily enough, the clutch wasn't, and I can shift it thru the gears, so on Monday evening Spotty and I mixed up some "Special Sauce" (50/50 Acetone/ATF) and dumped it down the spark plug holes, inlet ports, over the top of the cam and rockers (which are all looking lovely and oily, with no rust or corrosion at all, even the spark plugs came out nicely, and look like the engine's been running nicely.
Oh, and if I can't get the pistons unstuck, the chopper also came with a HA 900 kit to fit nicely into a freshly bored, but never used cylinder block at Spotty's, (which Spotty has claimed for one of his builds) and an 812 kit to suit another of Spotty's cylinder blocks, which, if necessary, will go into my chopper. Oh, and the guy with the turbo kit (which started all of this chopper madness) has hosed me. No pics, no phone call, I'm betting he got offered more money than the agreed asking price, and he's screwed me. Oh well, schidt happens, and even here in Oz, integrity is just a word, apparently...
OK, that's an abbreviated version of where I've been and what I've been up to, I'm flying (Business Class, don't you know...) to Queensland on the weekend for my son's wedding reception so Spotty and I can't do our usual weekend bike fixing session at his place, but all going well it'll be running next week, so we can wobble and wallow around the block, while trying to look cool. I need to buy a "Dennis Hopper" suede leather jacket and hat, just to look more stupid than I usually do. More soon. ;D
Offline denward17
« Reply #33539 on: November 18, 2025, 01:25:33 PM »
Wow Terry, what a way to kick off retirement.
LOL at the "retirement is a very dangerous occupation..."
Do try to take it easy so you can heal up and enjoy retirement.
« Reply #33540 on: November 18, 2025, 03:20:47 PM »
Ha ha, thanks mate, sadly after 48 years in the Army I’m struggling to slow down. I’m currently working under my Subaru twin turbo beastie, after paying a “pro” $2660 to fix my cooling system on Monday, it first broke down in a main street due to a loose battery terminal, then 12 miles into a planned 100 mile drive, started boiling its guts out in the freeway. I pulled off onto a lonely road miles from anywhere, but luckily I hadn’t thrown out the couple of gallon jugs of water I always carried in the trunk in such emergencies, so was able to pour a gallon of water into it, and drive to the nearby RSL (Returned and Serviceman Leauge) club and have a couple of cold drinks while it cooled down.
The “New” thermostat had refused to open, (it eventually did while I was refilling the radiator) probably due to the common airlock problem due to Subaru’s moronic design flaw of putting the thermostat on the bottom if the engine, and not the top, which has killed more Subaru’s than the other issue of failing head gaskets in an engine that needs to be removed to replace them.
There’s a redneck fix that a member here told me about years ago that solves the problem without the shortcomings of removing the thermostat altogether, so I’m just draining the radiator now before popping the thermostat cover off and doing some minor surgery to fix it so it won’t happen again. Laying on the cold concrete isn’t doing my poor old broken bones any good, but the peace of mind of knowing that I’ve sorted that issue will assuage the pain. Then I’m off to the auction place to pick up some unneeded bike parts I won during a drunken bidding frenzy last night. I suppose life could be worse.. ;D
« Reply #33541 on: November 19, 2025, 02:00:58 AM »
Oh No !
Exactly!  ;D
My apologies!
No problem, John. The info here is useful.
I often write things while I still remember I can find later.
The photo is spot on when I answer questions on this forum. ;D
I'm sure we are many here with that addiction. ;D ;D
Offline MarcinMMz
« Reply #33542 on: November 19, 2025, 03:57:08 AM »
What I did?
Successful front end brakes retrofit became as a fact :-) I'm really happy with it!
Thank you very fruitful tread which helped me a lot!
« Last Edit: November 19, 2025, 04:00:03 AM by MarcinMMz »
« Reply #33543 on: November 19, 2025, 05:49:16 AM »
Welcome aboard the forum MarcinMMz
Go to the New Members section and introduce yourself and your bike there.
« Reply #33544 on: November 19, 2025, 06:33:45 AM »
Terry!!
You call this retirement? I thought I got it wrong, you are making us all feel like slugs!!
Get well, get safe :-)))
« Reply #33545 on: November 19, 2025, 12:52:49 PM »
You've Been Busy TERRY !  ;D
A very nice deal for that ZZR1100 D model.  8)
« Reply #33546 on: November 19, 2025, 04:54:29 PM »
Terry…… delighted to hear that despite the “mower-vaulting” you are busier (and freer) than ever! The chopper purchase really made me smile. Is it a hard tail? Parallel lives?
Cheers! John D.
« Last Edit: November 19, 2025, 04:56:32 PM by BenelliSEI »
« Reply #33547 on: November 19, 2025, 07:30:58 PM »
I ran into a similar problem after draining the cooling system to replace the coolant with my '89 Toyota pickup with the 3.0l V-6. When I refilled the radiator, it didn't seem to take very much coolant, but I didn't worry about it. I started the engine up, closed the hood, and climbed in, thinking I would drive it to let the thermostat open and mix up the water and anti-freeze. About the time I got my seat-belt fastened I heard a loud pop-bang from under the hood, then another, and when I looked at the temp gauge it was pegged!! The pop-bang was steam explosions popping the radiator cap pressure relief. WTF, now all of a sudden the thermostat is stuck?? The 'stat was also located at the bottom, but when I tried to remove it the bolts were stuck so tight something was going to break, either a bolt or the ratchet. >:(
The problem with the Toyota is that filling the radiator only fills the radiator, as the cold 'stat prevents the coolant from flowing into the block, and the top of the radiator tank is lower than the hose going into the top of the motor. The simple solution (simple now in hindsight ;)) is to remove the top radiator hose, hold it up, and fill the block through the hose.
When I bought the truck new, I also bought the factory shop manuals, and there was no mention of this. Some time in the mid '96s I received a notice from Toyota, talking about head gasket failures, extending my already expired warranty to 10 years or 100K miles, and offering compensation for out-of-pocket head gasket repairs if they had already been done. I talked to several different people at different dealerships, but no one could give me a reason why the 3.0l sometimes blew head gaskets, and others didn't. I think it was because the techs made the same mistake I did, but I caught it before any damage was done?
Offline Steve Campbell
« Reply #33548 on: November 20, 2025, 01:04:22 AM »
I did a 320km round trip to attend a1967-75 university reunion in Melbourne (Australia). I misjudged the weather and did not wear enough layers. It was freezing as I left at 7.30am. My bike went like a rocket until I reached heavy trafgic. I mananged to nurse it over the last 20km to reach the venue. Met one great mate I hadn't seen for 55 years. We're both 77 now. This guy is an absolute hero for working Australians as he was instrumental in establishing Industry Superannuation funds. As distinct from commercially owned funds where a varying proportion of the profits goes to investors, with Industry Super funds all of the profits, minus the admin fees, go into the Members' accounts, so they end up with a much bigger retirement nest egg compared to those in commercially owned funds. Such a huge contribution to the people's welfare as a result of one man's vision and initiative.
At the end of the event, I'm pleased to say I made it back home with some rough patches (misfiring, fuel starvation, or something else - not sure. But for the last 30 minutes the bike ran like a dream. It's a K2 750 that is now 836cc and has been tricked up quite a bit. I don't mind working on it as it's been very good to me for 45 years.
« Reply #33549 on: November 20, 2025, 06:14:43 AM »
Well done! Love hearing stories like this! Kudos to you.
