the deal with the bent forks-the upper tube is tough, but if the lower is bent too much it'll bend the upper tube as well.
apparently 1-2mm from straight is fine, but if it's hit hard enough to bend it to 4+mm your screwed. lesson learned.
I still need a wheel, master cyl, speedo drive, and misc doodads.
the plus side of this is, I could have found out it was bent while riding and got hurt....
__________________________________________________________________
also, it appears the 2008-2010 dyna narrow glide hub is +/- 5.0in (+/-127mm) wide from flange to flange
may be more useful than shimming a 2000-2007 hub...
(pure speculation)
