Author Topic: My CB750 Book and CB500/CB550 Book, by Hondaman: a 15% discount thru 8/29/25! :)  (Read 267402 times)
Offline deafcaferacer
  • "I'm sorry officer, I can't hear you!"
Re: My CB750 book, by Hondaman. 20% OFF coupon code!
« Reply #325 on: March 02, 2013, 09:04:14 AM »
I want to order this book but would like to know if it covers the '78 CB750k series in comprehensive detail? Or does the material covered in the book extend to the '78 version as well since not much has changed in certain respects?
Thanks.
'73 CB750k engine, hubs, and a '76 tank, on 'a 78 frame. Go figure.
« Reply #326 on: March 02, 2013, 11:20:37 AM »
Thanks.
In terms of "covered models", it is specific in the tiny-est of details to the K1-K6. That said, the main (engine) differences in the post-1975 bikes were the cam duration, domed pistons, a slightly different clutch plate collection (i.e., one of the steel plates is a dual-plate type), and the 1st and 2nd gear tooth count. Other than these details (and the PD carbs on the post-1976 bikes), they are very much the same. On the F2/F3 bikes there is a read disc brake: that is not covered in this book, either.
All this said, many copies are out there being used to rebuild all of this SOHC4 bike. IMO, the only significant shortcoming is the missing PD carbs and the rear disc brake coverage. When this stuff was in the book, it got to over 350 pages and $150 in cost, so I cut it back. One thing I did leave in: the Engine R&R chapter is shown using a 1976 F1 model.
Offline Kickstart
« Reply #327 on: March 03, 2013, 08:42:40 AM »
Does Lulu give you the option of publishing an "extended" version of your book?
It makes sense to try to keep the cost of the book under $100, but I would be willing to pay $150 for an "extended version".  Same thing for the performance book you're working on... How is that coming along by the way?
- Chris
75' CB750F Blue (Project)
No Reserve Racing #171 AHRMA
« Reply #328 on: March 03, 2013, 10:19:06 PM »
The perfomance version is creeping along: I've had to wait to get my hands on "this" or "that" version of performance builds to get the pictures it needs. It will include more details about the post-1976 versions, but the differences don't matter much: it will have the poor PD carbs (at least the PD42) and the 2-steel plate clutch plate, and a little bit about different cams, and the slight differences of the F2/3 vs the other engines (which is essentially nothing more than bigger valves with thinner stems and hard-to-find valve keepers!). Since you can mimic the "F" cam by retarding the earlier cam 5 degrees, which is about the same as an early cam with a loose cam chain, most folks haven't noticed that difference in real life, so I'm not sure how many folks will bother with the changes? The F2/3 cam had .4 to .5mm more lift than the earlier ones (in real life: the specs showed .8mm but I haven't seen one like that), and the chambers were slightly bigger, but mechanically that's all there is to it. Hence, it seemed like losing those 50 pages hasn't caused much grief in the original manuscript.
The next one involves things like big-bore kits, the present crop of aftermarket cams, and the pluses and minuses of doing [this or that] to the engines. Along the way, since it's my book, I'll be interjecting my opinions about the performance improvements vs. the tradeoffs, because at least a few of our riders have tried to do some of it 'on the cheap' and been disappointed with the results. I'd like to help them head that off at the pass, next time?
For example, a rebore to a standard piston size like .5mm or 1.0mm will net about +5 to +7 HP increase, if everything else is done right. Boring the same engine, with everything done just right, to 836cc (low-compression) will net about +8 to +10 HP from brand-new performance, and using Wiseco's 10:1 CR pistons will add about +2 HP to that figure. (All this is with a stock cam.) The resulting tradeoffs: the stock rebore will go 100,000 miles with good maintenance, the low-compression 836 will go about 50k miles, and the Wiseco will net around 35k-40k miles. The big bore engines will likely develop oil leaks sooner than that, necessitating a pull-out and new gasket kit (and rings) along the way. Historically speaking, this is what I have witnessed, for the most part.
Installing a mild cam like the Megacycle 125-00 will raise the HP at 5000 RPM by about +4 (all else being stock, and equal) and +8 at 8000 RPM. Installing a Webcam 41/a will make more HP than that, but you must do absolutely everything else correctly to avoid things like valve guide side loading and piston-valve collisions, including stronger valve springs, proper spring height (with shims), degreeing-in of the cam, etc., etc., and even then, the extra stress on the head-cylinder interface often causes oil leaks. So then, even more 'stuff' must be done, to try to mitigate this issue.
What it boils down to is this: to rebuild a mostly-stock CB750 top end, there are about 30 'things' you must do right to get great results. To rebuild with a big-bore kit there are about 55 'things' that must be done just right. To rebuild with a big-bore kit and a big cam, there are well over 100 'things' that must be done just right, including your machine shop's handiwork, and your checking of the work. Guys like Big Jay at APE and MRieck can tell you all about it, and can probably tell you about the ones they had to 'fix' for someone who didn't do it, so it will take me some time to try to compile most of these. I just hope I don't miss some of them! That's the hard part of a performance book. :)
« Reply #329 on: March 04, 2013, 07:22:47 AM »
Thanks for the feedback HM, am going to order my copy soon.
« Reply #330 on: March 05, 2013, 09:26:26 AM »
I would not mind having a list of those 30 things, 55 things and 100 things in the FAQ question.  It would be beneficial to use a check list.
Offline Kickstart
« Reply #331 on: March 11, 2013, 08:37:32 PM »
I can't wait for the performance book... I'm already shopping for a build bike.  :)
Mark,  I do have two questions on your current book:
  • When drilling the extra oil holes in the rocker towers, do you you smooth out the ID of the tower with anything after drilling the holes, or do you just drill the holes and leave it?  I'm wondering if drilling the hole will leave any burs or a lip on the ID of the rocker tower where the rocker shaft goes.
  • Where can one find a small enough hone for the master cylinder?  I bought a brake hone from the local auto shop, but it's too large to fit inside the front brake master cylinder.
Thanks!
Chris
- Chris
Offline ladyrocket
  • 1976 Honda CB750F
Re: My CB750 book, by Hondaman. 20% OFF coupon code until 3/13!
« Reply #332 on: April 11, 2013, 01:24:08 PM »
Just bought a book, gonna be spending a lot of time in the garage this summer!
« Reply #333 on: April 11, 2013, 05:16:28 PM »
Thanks!
Chris
For those holes: Usually you can tap the shaft thru them gently and they will shear off any leftover burrs on the ID. It is soft aluminum, and the shafts are case-hardened steel, so they make good "punches" for this trick. After the shafts rotate a few times, they do a nice job of smoothing off anything left behind.
The brake hone: I got mine from Checker Auto, their tiny 2-stone hone. You can also use a ball hone, more $ but only takes about 15 seconds to do the job. I like the ball hone, although mine is getting a little worn now after all the years.
« Reply #334 on: April 11, 2013, 05:17:26 PM »
Thanks for buying one! Write with any questions. If you PM me here, I can also post them back to the various forums.
Offline Mercutiojb
« Reply #335 on: April 25, 2013, 01:15:20 PM »
Just a head's up, I haven't bought the book (yet!) but would also pay $150 to have the later CB750F info included.  If you made it available, I'd take it!
Re: My CB750 book, by Hondaman. 15% OFF coupon code until 4/19!
« Reply #336 on: April 25, 2013, 09:11:11 PM »
Well, there's not a lot of difference from the vantage point of building the bikes up to a running machine. Mechanically they are very similar, except for the carbs and pipes. In terms of performance subtleties, there's more because Honda 'hotrodded' the "F" bikes for a little more HP. Some of that is the theme for the next book. ;)
Offline Tsunami
  • There's No Place Like This Place Any Where Near This Place So This Must Be "THE PLACE"!
  • Life's to Short, Carry On!
« Reply #337 on: April 26, 2013, 12:47:18 AM »
Crap just missed it, think you will do the discount again anytime soon?
Greg
[Tsunami Build Link]
CL450 early 70's
New 1973 CB750 Flake Sunrise Orange
CB350 Chopper early 70's
CB350 Cafe' early 70's
Honda Cub 90cc late 60's
Other's
« Reply #338 on: April 26, 2013, 09:46:20 PM »
Greg
Sure, they put it up about once a month. You might also search the web for "lulu discount coupon" because some have found as much as 30% off this way. Those specials don't get e-mailed to me, so I miss them.
Offline surveywaters
    • My Project Photos
Re: My CB750 book, by Hondaman. 20% OFF coupon code until 6/7/13!
« Reply #339 on: July 12, 2013, 04:20:25 AM »
Is there an eBook version yet? I'd love to have the book but that Franklin is set aside for parts.
1972 SL125,1974 XL125,1975 CB125,1978 CB750k,1978 KZ650,1978 XS650,1985 VT1100,1986 VF700, 2005 XV1700,2003 DL1000,1982 XR250R,1986 ATC70,1987 BW80,1987 XR250R,1999 Z50r,2002 DRZ400s
« Reply #340 on: July 12, 2013, 11:19:44 AM »
No, there's no ebook version planned. If you ever see the book, you'll understand why. :)
Offline Tsunami
« Reply #341 on: August 09, 2013, 01:25:45 PM »
Hey HondaMan,
Got your book very helpful!
I have a problem, though I might be able to get your take on it?  Also anyone reading this who has been there done that could be helpful.  My 836cc engine  build has gotten to the cam timing stage.  The cam is a WebCams cam CX-2.  I purchased it from ken at cycleX who designed it according to WebCams. Who would not answer the question?  I have been unable to get through to Ken seems no one is there this Friday?  Any, prior to bolting up the cam sprocket one must time the cam.  Usually the cam is indexed with a square notch and sometimes also with the two lines.  The notch should be up and if it has lines, they would be even with the cam bearing mount.  Well the CX-2 cam has no lines, it has a notch but when the #1 cyl is at top dead Center the notch is on the bottom not the top?  I must be missing something.  I know about the degreeing process however my talk with Ken when I was purchasing this equipment was something like this.  I'm not replacing the cam chain as I did not want to split the cases, the bike ran fine.  When I told him that he kind of laughed and said I wouldn't need the adjustable Cam Sprocket (which I already had) or the degree wheel.  I should just follow the normal reassembly process.  I assume the cam should be in the position where both lobes are flat and there is no rise or fall of the rockers, when it is the notch is down? Anybody, any Help?
Thanks Gregory
CL450 early 70's
Other's
« Reply #342 on: August 09, 2013, 06:45:12 PM »
Hey HondaMan,
Thanks Gregory
There's several cams out there like that one!
The notch can be up or down, as the whole engine goes 180 either way and the spark is a waste spark type. But, if you don't have a dial indicator to use to try to figure out the lobe centers, try this instead:
1. Set the cam in the 'notch down' spot at #1 TDC (or #4 TDC, for that matter, which in this case would put the notch up). If you have a degree wheel, install it on the spark advancer and put the nut back on. Remove the sparkplugs. Set the cam chain tension to take up most of the slack for now. You can do it correctly later.
2. Set the valve lash at .040" on the #1 intake. (That's not a typo!)
3. Install a .001" feeler gage into the #1 valve rocker and start rotating the engine. When the feeler gage gets trapped, you are reaching the "valve opening" moment. Note the crankshaft degrees BTDC, or if no degree wheel, reach thru the points plate window and make a pencil mark on the advancer baseplate, as close to the center of the window as you can.
4. Rotate the crank until the feeler gage just gets free again. Do the pencil-in-the-window thing, or note the degrees ABDC.
Now, take a look at the degrees BTDC and ABDC. For most of these cams, they tend to make too-early opening on the BTDC, which gets your valves and pistons mighty friendly. But, if there is a long ABDC opening, the bike will not idle for beans and will be real hard to start and tune below 3000 RPM. I like to try to make them equal BTDC and ABDC if the opening at BTDC is not more than 10 degrees. This "equalness" will tend to provide the widest midrange powerband where most of us ride. If the cam is moved to have more ABDC than BTDC opening, then the peak power moves upward in RPM accordingly.
For example, the Webcam 41, if set equally, provides about 16-18 degrees BTDC and ABDC this way. This is OK with the flat-top 836 pistons or stock K0-K6 pistons. They normally recommend using 5 BTDC and 35 ABDC, because then they won't hear about your parts colliding and sue them or something. But, the bike becomes cantankerous that way, hard to start when hot, no idle until 1500 RPM, stuff like that. It also will wind off the tach, until the springs can't save the valves from float, but there is no room to ride that stuff on the street.
And so it goes with almost any cam: I usually take the post-1975 OEM cams and advance them 5 degrees when rebuilding those engines, too, because we don't have to deal with the emissions politics that Honda did in the Carter era (when they were trying to hurt Japanese imports to protect US car and bike builders), and the midrange power perks up noticeably for the change. While this may cost about 1 HP at 8000 RPM in the tradeoff, I have not built a racing 750 since the 1980s and no one has ever complained: rather the opposite.  ;)
Offline Tsunami
« Reply #343 on: August 10, 2013, 09:12:21 PM »
 :) Thanks Hondaman, thought I was going crazy, considering the stockers always had the notch up why would they do that and not say something.  As there didn't seem to be any other way I came close to what you suggested.  I will go back Sunday and reset everything to be sure, thanks ever so much. If your ever headed for Tahoe via 50 drop me a line and I'll buy you a beer or something!
Gregory
CL450 early 70's
Other's
Offline bert96
  • past ride
« Reply #344 on: October 06, 2013, 12:20:12 PM »
I've just order a copy from lulu.com can't wait to start reading this book!
Bert
QA50 1969,ST-90 1974,mb5 1982,rz350 1983,shadow 1100 1985,vf1000f 1985,BMW K1 1990,shadow tourer 1100 2001,vfr 750 1994,vtr250 199?
Offline Kevan Garrett
Re: My CB750 book, by Hondaman. Discount 10% through April 2014!
« Reply #345 on: April 24, 2014, 01:34:34 PM »
Just sent in my order after spending the morning reading HondaMan's thoughts on all things SOHC.  Looking forward to reading the booking and getting greasy.  Now to find an old Honda to work on.
Cheers
Kevan
Offline broshae
« Reply #346 on: May 26, 2014, 12:20:43 AM »
Just ordered a copy of your book. I have a 77 750F that's in great shape and a 77 750A that needs some work. I look forward to reading your book. I've read a lot of good things about it!
« Reply #347 on: May 26, 2014, 10:25:55 PM »
I just got a real nice 76F from a [local] SOHC4 member who had a baby, couldn't get back to the bike. I'm gonna resto it and sell it, will split some of the proceeds with him (after I figure out how to retitle it - title was 'purged from he CO system  :(  ).  Might make some more pix for the next book(s) about performance stuff from it?
Offline Greenie
« Reply #348 on: May 28, 2014, 10:30:47 AM »
Hi Mark,
I just ordered your book and am looking forward to putting the knowledge to work on the wiring.  I opened the headlight bucket of my 76 750k and it is a mess.  I'm a little worried about all things electrical, but it sounds like you lay it out pretty well.
Paul
« Reply #349 on: May 28, 2014, 05:30:12 PM »
Hi Mark,
Paul
The '76 bikes were a mix of the K5 leftovers and the upcoming F0 systems. If you get lost in there, drop me an e-mail and I'll help you through!
