Author Topic: Badass 5 axis milling machine + billet Aluminum = Helmet!  (Read 7653 times)
Offline UnCrash
  • Pass
    • My Blog
Offline tramp
Re: Badass 5 axis milling machine + billet Aluminum = Helmet!
« Reply #1 on: April 10, 2010, 04:15:14 AM »
that was frigging amazing
1974 750k
« Reply #2 on: April 10, 2010, 04:54:12 AM »
Someone needs to map one of Mike Riecks heads and get a few made up, or even a totally different design for performance... very nice bit of gear...
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
« Reply #3 on: April 10, 2010, 08:15:21 AM »
It looks very heavy and uncomfortable...
:P
No.
« Reply #4 on: April 10, 2010, 08:44:07 AM »
I cant view it..
how long where they cutting, how much did it weigh?
 A guy in town here was building single sided swingarms and front-ends. some of the pieces were 20 hrs or more on the mill.
Offline HavocTurbo
  • Angry little bastard of an
  • Can you tell?
« Reply #5 on: April 10, 2010, 11:32:53 AM »
Wow........ :o
'48 HD Panhead - Exxon Valdez
'78 CB550K - Fokker CB.3
'78 Honda CB750K - Mavrik
09 XL883L - No Name
Offline Alan F.
« Reply #6 on: April 10, 2010, 06:44:12 PM »
No liquid cooling either.
Offline mrblasty
  • Expertly
« Reply #7 on: April 11, 2010, 05:43:04 PM »
I did the same thing with a dremel
I farted and made my son cry.
1973 Honda CB 750
1975 GL 1000
Offline Burnboy
« Reply #8 on: April 12, 2010, 06:04:08 AM »
Thats how they made the terminator......
1975 CB750
1973 CB350F
Offline sangyo soichiro
  • Tuck
  • ☢ the atomic playboy ☠
« Reply #9 on: April 12, 2010, 08:39:39 AM »
That's some pretty cool CNC work there.
1974 CB 750
1971 CL 350 Scrambler
1966 Black Bomber
Too many others to name…
« Reply #10 on: April 12, 2010, 09:07:47 AM »
OK, I cant/wont buy a new computer just to view this..
 can ANYONE tell me how long the milling took.. ???
 full helmet? 3/4 helmet?
Offline syth82
  • 1976 cb550f project
« Reply #11 on: April 12, 2010, 09:12:54 AM »
motocross type helmet, they cut up the footage so you can't tell how long.
-Luke
Offline mmtsquid
« Reply #12 on: April 12, 2010, 09:41:12 AM »
It's aluminum, so I can't imagine that it took more than a few hours.
77 CB550K4
Offline Steve F
« Reply #13 on: April 12, 2010, 10:07:40 AM »
Yes, while aluminum cuts quite nicely and easily, to get the level of finish that they were showing, I'd be willing to guess 30 to 40 hours+ including the changeover to the other side in the fixture.
« Reply #14 on: April 12, 2010, 10:15:25 AM »
Often the Machine makers like to  talk about machining time, and tool-change speed.
 Some parts are truly impressive, time in which it is done.. I cant see the finished product, but it sounds fairly complex, usually meaning long a time cutting..
  • Tuck
« Reply #15 on: April 12, 2010, 10:33:22 AM »
For those having trouble seeing the video, here's the finished product.  Looks like they did another helmet too.
1974 CB 750
1966 Black Bomber
  • Tuck
« Reply #16 on: April 12, 2010, 03:04:11 PM »
And for those that think machining a helmet is silly...
1974 CB 750
1966 Black Bomber
Offline Steve F
« Reply #17 on: April 12, 2010, 06:56:01 PM »
Ah yes....there's nothing like an $18,ooo cylinder head.  Beautiful work!
« Reply #18 on: April 12, 2010, 07:39:16 PM »
I would like to know why that would be $18,000 dollars worth?  I have a billet block coming from Mrieck with Nikasil bores and it cost a 10th of that...
Offline campbmic
  • Sea-Foam and Flaming 151 is a dam good
« Reply #19 on: April 12, 2010, 11:41:29 PM »
1,800 bucks is still a lot!
Its hard to be wrong when you know nothing!
« Reply #20 on: April 12, 2010, 11:51:00 PM »
Thats Aussie dollars and with gaskets and cam as well, with the 1000cc pistons and all the other go fast goodies i have this bike will be awesome.... ;D
Offline Steve F
« Reply #21 on: April 13, 2010, 06:16:54 PM »
Well lets see....this is all assuming that these pieces were done at the machine builder facility, using top of the line equipment and professionals...there's design time, programming time (and the cost of related software and equipment to run the programming software), perishible tooling costs, setup costs, material costs, debugging and reworking (unless they're really REALLY good even with computers doing the programming)...labor cost for the machine operator(s)...
It all adds up in a hurry.
« Reply #22 on: April 13, 2010, 06:39:57 PM »
Hi Steve, yes i understand the process but these days from what i have seen, they use laser equipment to "map" the piece being machined and a lot of the old processes are therefore removed. I do know it is still an expensive process but $18,000..... :o   This is what my son will be doing for a living soon....can't wait.....billet everything..... ;D
« Reply #23 on: April 13, 2010, 07:40:38 PM »
You might be surprised how stingy they can be with machine time..and by the highnormous cost of programming..
 You may not find a lot of reasonable metal cutting out there..
Offline Steve F
« Reply #24 on: April 13, 2010, 07:51:05 PM »
Just to use as an example of the costs involved in a "One-off" item.  Now, I'm not talking about machining billet aluminum here, but the process is SLA (Stereo Lithography).  Probably the simplest means of producing a solid (plastic-like) object from a 3D computer data file or drawing.  I just last week contracted to have 5 pieces made using this process.  The parts were small enough to fit inside a 6 x 6 x 10 cardboard box.  $2000.  There was no tooling cost, the material cost was about $40, the finish labor cost about two hours worth, and I did the 3D computer work.  Essentially all they did was download my 3Dfiles into their machine and press start.  no setup, no fixtures, no perishible tooling...  Now imagine if they did the design work and made the parts from billet.  Easily double or triple the price.
Laser scanning often requires an extensive amount of editing to get rid of the "glitches" that pop up all over the scanned surfaces.  They have come a long way in that respect, but you can't get a helmet like the one they have in the video without some serious "clean-up" time invested before the first chip hits the floor.
