Author Topic: What do you use for fork oil?  (Read 32575 times)
Offline Dunstall_74
« on: August 25, 2010, 07:09:06 PM »
Been reading through some fork oil threads, and noticed guys are using 1 of three items.  I've heard branded motorcycle fork oil, motor oil, and ATF.  I've been thinking about giving the motor oil a try, but wanted to see what the collective knowledge on the forum had to say about it..........
What do you use, and what would you say are the benefits?
''It is clear our nation is reliant upon big foreign oil. More and more of our imports come from overseas.''
—President George W. Bush, Beaverton, Ore., Sep. 25, 2000
Re: What do you use for fork oil?
« Reply #1 on: August 25, 2010, 07:11:40 PM »
If you read the threads you will already know the collective wisdom. There is none. It is a matter of personal choice.
Offline Alan F.
« Reply #2 on: August 25, 2010, 07:14:06 PM »
+1
Offline Dunstall_74
« Reply #3 on: August 25, 2010, 07:22:15 PM »
Point taken.  Think I'll go with 10w30 motor oil.  Personal choice. ;D
Offline Alan F.
« Reply #4 on: August 25, 2010, 07:25:30 PM »
here's to ya man!
« Reply #5 on: August 26, 2010, 05:58:05 AM »
I personally went from ATF to 10-30 and it seems to be working out for me.
Offline axe
« Reply #6 on: August 26, 2010, 05:59:40 AM »
FWIW, both the owner's and shop manuals recommend 10W30 motor oil.
Offline KRONUS0100
  • MAD MATT THE MANIAC
« Reply #7 on: August 26, 2010, 06:09:34 AM »
10w-30 valvolene oil
MATT
Offline 78CB750CAFE
  • I'm not really an
  • Ride, wrench, repeat.
« Reply #8 on: August 26, 2010, 10:01:53 AM »
I use a 50/50 mix of Belray 10w and 15w fork oil
bollingball
« Reply #9 on: August 26, 2010, 10:18:43 AM »
bar's leak hydraulic jack oil and 10w30 50/50 works well on small leaks
Offline L.A. Nomad........
  • 1976 CB550 K
« Reply #10 on: August 26, 2010, 10:20:14 AM »
Fork oil is expensive!
I am a fuel-injected suicide machine! I am a rocker! I am a roller! [I’m an outta controller] I am the Chosen One! The Mighty and the Vengeance! Sent down  to strike the unroadworthy! I'm hotter  than a rolling dice!
« Reply #11 on: August 26, 2010, 10:30:11 AM »
Where does it say motor oil?
I have always learned it should be ATF or Fork Oil.
BTW, haven't changed mine in decades.
« Last Edit: August 26, 2010, 10:31:46 AM by Deltarider »
"No one is illegal on stolen ground."
Offline axe
« Reply #12 on: August 26, 2010, 11:30:20 AM »
I suppose it isn't explicitly referred to as "motor oil", but I don't know of any other oil with 10W30 viscosity.
Edit: I thought motor and fork oil were essentially the same, but after some googling it seems they aren't. Best stick to real fork oil.
« Last Edit: August 26, 2010, 12:08:19 PM by axe »
Offline bruisedlee
« Reply #13 on: August 26, 2010, 11:53:32 AM »
i went from half emptl reeeeeaaaalllllllllyyy old watery mystery stink oil to 15w fork oil.  pretty damn stiff!
Offline egar
« Reply #14 on: August 26, 2010, 02:43:53 PM »
I use 50 percent pure virgin olive oil and 50 percent coconut oil.  :D
sohc4
'04 ST1300, '70 cb750KO
Offline underachiever
  • Squandering my potential since 1989
  • 77 CB550K
« Reply #15 on: August 26, 2010, 04:49:41 PM »
I switched from cheap 10w30 that I put in last year when I rebuilt the fork to some very high quality synthetic ATF I had laying around that I was never otherwise going to use. Fluid level is a bit high so not quite getting full travel on the front end but can you say smoooooooooth. ;D
« Reply #16 on: August 26, 2010, 05:19:21 PM »
There will never be a universal answer to this question. We all have different riding styles, road surfaces, and different amount of wear and tear on the fork innards. You find what works best for you and THAT is the perfect fork oil.
Offline cb650PK
« Reply #17 on: August 26, 2010, 05:31:02 PM »
Oil from baby seals is said to be the best, in its absence whale oil or oil from dolphins can be used as substitute. They are Japanese bikes after all.
S CB750 na vecne casy a nikdy jinak.
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #18 on: August 26, 2010, 11:28:19 PM »
You missed baby oil ;)
« Reply #19 on: August 27, 2010, 01:40:21 AM »
im using 20/60 motor oil,i tried atf and it was too soft,its a choice and riding style thing,mines firm.why not start with atf,and try going up grade by grade.itll take a day or two to get the feel you like.the forks will be nice and flushed by then aswell.
Offline cookindaddy
  • I sure love this bike!
« Reply #20 on: August 27, 2010, 03:56:59 AM »
The Honda service manual says ATF. I am sure any good hydraulic oil would do. Probably they don't want the additive chemicals in regular engine oil in the forks? I used Honda brand ATF and that was pretty expensive $8/liter and I only used about 1/4 of it.
George with a black 78 CB750K (in Lion's Head, Ontario, Canada)
Offline Doctor_D
« Reply #21 on: August 27, 2010, 08:10:00 AM »
There is no viscosity standard for fork oils, so I tend to avoid them.  Motor oil has other additives that are unnecessary in suspension parts and the viscosity rating of motor oils isn't equal to the same rating for fork oils. http://www.peterverdonedesigns.com/lowspeed.htm
The good news is that suspension fluid, unlike fork oil, does have a viscosity standard and was designed for this type of application. I've used Redline Medium 10wt with success, and currently have Bel Ray HVI 15wt shock fluid in my Norton and CB750.
As for price, if $10-$20 every 3-4 years is a problem - one might have other things to worry about besides fork oil.  ;)
Take care,
David
1978 CX500
1971 Norton Commando
Offline CycleRanger
  • No comment about being an
« Reply #22 on: August 27, 2010, 08:33:02 AM »
I used the oil from 92 tins of Anchovies.  I find it superior to even baby seal oil.
Offline cb550fcafe
    • KDI Cycles
« Reply #23 on: August 27, 2010, 09:24:38 AM »
So you're the guy who filled my forks last time.  ;D It smelled like an Anchovie's butt. Seriously the original oil smelled like dead fish. I use fork oil from the Honda parts shelf, can't remember the name but its 10wt.
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #24 on: August 27, 2010, 09:35:35 AM »
I think I read some where that originally they did use a fish oil at the factory for the forks.
