Run the white one over a few more times, and it will be a sailcat...
im just gonna throw this out there but have you ever tried toasting rye bread or bagels? i bet a slice of rye will take 6 like a champ
Mine has a bagel button.
Quote from: syth82 on December 07, 2010, 05:37:00 AMMine has a bagel button. Mine has a belly button...it holds a delicious, fuzzy, navel jelly for spreading on your toast!
Ok, time to finally let you all in on the high number use.. if it was a lower number Retro Rocket would not buy it! Plus, its not a real toaster unless it has done at least 100 toasts... Actually, its for hot knives.. used for hot-knifing Hash..
Quote from: Schmthaus on December 07, 2010, 05:39:50 PMQuote from: syth82 on December 07, 2010, 05:37:00 AMMine has a bagel button. Mine has a belly button...it holds a delicious, fuzzy, navel jelly for spreading on your toast! That sounds about as appetising as toe jam...... Mick
