Author Topic: Dorothy III - CB750  (Read 326408 times)
Re: Dorothy III - CB750
« Reply #400 on: January 09, 2022, 01:23:59 PM »
That is a neat piece of “aero”!
« Reply #401 on: January 09, 2022, 01:27:20 PM »
Love the Vesco Rabid Transit fairings...
« Reply #402 on: January 09, 2022, 02:18:43 PM »
+1  8)
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #403 on: May 05, 2022, 09:40:38 AM »
Gotta love some Dorothy. Hopefully some updates are coming soon!
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
"Alley Cat"  93 sportster
Offline Alan F.
« Reply #404 on: May 05, 2022, 10:55:21 AM »
Good score! I missed one around here a few years back for $100, they do come up now & then.
« Reply #405 on: May 10, 2022, 05:51:08 AM »
I stripped the tank and found a hole  :)
I will have to solder it.
On related topic, what is your prefered body filler?   I mean auto body, not bacon, biscuits and gravy.  ;D
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #406 on: May 10, 2022, 07:46:38 AM »
Mhmmm bacon....
« Reply #407 on: May 10, 2022, 08:05:30 AM »
Maybe braze it or use silver solder?
« Reply #408 on: June 09, 2022, 01:02:52 PM »
Working on the tank, the deer imprint is filled in and now it is the primer/sanding/primer/sanding....
Not sure what color I will go with and if I want to paint the Don Vesco fairing the same.
« Reply #409 on: June 16, 2022, 03:37:13 PM »
Not sure what color I will go with...
How 'bout Blue, the color of Dorothy's dress?!!
« Reply #410 on: June 16, 2022, 06:11:05 PM »
I'll place my vote  ;)
« Reply #411 on: June 17, 2022, 06:35:20 AM »
I will consider it  ;D
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #412 on: June 19, 2022, 05:43:46 PM »
I will second that!
« Reply #413 on: January 22, 2023, 07:20:36 AM »
Valves.  Cleaned and polished.
« Reply #414 on: January 22, 2023, 07:46:44 AM »
Making headway!
« Reply #415 on: January 22, 2023, 08:35:23 AM »
Making headway!
Trying.  She is boxed for too long already.  Lapped valves for #1 and set oil there to check.
« Reply #416 on: January 22, 2023, 12:13:56 PM »
Making headway!
Well done! Ahead of me, still waiting for my head from vapour blasting!
« Reply #417 on: January 23, 2023, 03:51:10 AM »
Twelve hours later.  There was not a single drop after 3 hours.  I wonder if the colder night had anything  to do with it.  Not a big deal, I will revisit 2,3 and 4 with fine lapping compound.
Now, the head is easy, but I still don't know what to do about cylinders and pistons/rings.
« Reply #418 on: January 23, 2023, 07:05:37 AM »
What was the red liquid? Did it stay thin?
If so, seems that you are in good shape.
« Reply #419 on: January 23, 2023, 07:12:51 AM »
ATF, thinnest oil I had.
Offline jgger
« Reply #420 on: January 23, 2023, 08:40:36 AM »
Gasoline works too, plus it will stay thin as the temperature goes down.
« Reply #421 on: January 23, 2023, 09:33:33 AM »
I would not leave gas like this over night.
« Reply #422 on: January 23, 2023, 04:20:42 PM »
I use a bit of varsol. It’s so thin, I only wait a few minutes. If it doesn’t leak, pour it into a bowl and test the next one.
Offline jgger
« Reply #423 on: January 23, 2023, 05:08:13 PM »
Same idea with gasoline, late 60's and 70's that was what I used before I got into 2- strokes.
« Reply #424 on: January 27, 2023, 06:01:17 PM »
Little bit more lapping, tested with rubbing alcohol and not a single drop in two hours.  Done with that one, now what?
