Author Topic: Sorcerer and Atchison, Topeka and Santa Fe to be restored  (Read 534494 times)
Offline sorcerer
Re: Sorcerer and Atchison, Topeka and Santa Fe to be restored
« Reply #175 on: February 12, 2012, 08:17:41 PM »
Honey...does this tire make garage look skinny?
The view .....the other direction in my garage.
Some mornings it's hard to go to work as I have to walk through this.
RCjr
Online scottly
« Reply #176 on: February 12, 2012, 08:44:24 PM »
I ran Morris mags on my Jr. Pro Stocker in 81...they came off a RR bike of unknown origin but sure look a lot like this Kimtab. Judging by the price...I'm guessing they do not make these anymore...lol
You guys will make sure I do not venture off the true path...thanks.
RCjr
Here is a pic of my Morris mag; looks nothing like the Kimtab.
Offline Old Scrambler
« Reply #177 on: February 12, 2012, 09:10:32 PM »
Just based on my restoration work of '60s and '70s models........I would suspect an AKRONT rim to be readily available at that time.  HONDA had DID make up some valanced rims (some people call them pee-catchers) for race bikes but were generally hard to come by. Of course all were copies of the Borrani design.  Looks like and 18-incher..........nice anodizing.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
« Reply #178 on: February 12, 2012, 09:33:02 PM »
 The fork looks like a Ceriani Roadrace fork, also known as the GP fork.. the new ones are  a bit different. The blown v-8 I think had the double mount fork, that is one can be for brakes and the other for brace if needed. The Cerianis I got both are made for handlebars not clipons. but they made a top tree that was smooth fore clip-ons  as far as I know. Sometimes trees can be found seperate, they are marked ARCES, I think it is the forging company that struck them. If you get lucxky you may score a whole front end listed as such. They were used on  XR 750 and a few other bikes.
 One note about them the lower leg or slider is amazingly thin, in the narrowed section, it will scare you if you measure it.. but keep in mind they carried many a double engined bike down the track, pretty sure a few of them lofted the front end, and came down less than gently..
« Reply #179 on: February 12, 2012, 09:39:46 PM »
Hmmm, i have a set of those forks.... ;)
Offline BLUE71TURBO
« Reply #180 on: February 12, 2012, 11:05:57 PM »
Found this site for rims and forks..........
 http://www.motocicliveloci.it/inglese/catalogue/cerchiborrani_uk.htm    BORRANI  RIMS
http://www.motocicliveloci.it/inglese/catalogue/forcelle_uk.htm    CERIANI FORKS
Offline BLUE71TURBO
« Last Edit: February 13, 2012, 10:46:22 AM by BLUE71TURBO »
Offline voxonda
« Reply #182 on: February 13, 2012, 06:48:12 AM »
Got a 19" Kimtab here.
« Reply #183 on: February 13, 2012, 07:29:11 AM »
Blueturbo, those forks have no mounts. Ceriani made forks for OEM dirtbikes as well plus a motocross fork, the one he needs is the GP or Roadrace fork in single bump..
« Reply #184 on: February 13, 2012, 07:39:55 AM »
Take a close look at the kimtab tire clearance at the brace and rim alighnment with the brace/brake mount lugs on the legs.....................then compare with the Borrani (or copy of)............Tire clearance (growth) at speed may have been an issue ............the comparison indicates it may be an 18-inch rim.
The tube length looks longer than standard...........very similar to Bultaco MX bikes of the era.........the top tree has nearly flat handlebar mounts..........possibly the U-type..........again, maybe modified from a Bultaco.
Just supposing but trying not to overlook the obvious...........
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
Offline BLUE71TURBO
« Reply #185 on: February 13, 2012, 10:51:06 AM »
        You mean like these that i posted earlier on the ebay paste .........http://www.ebay.com/itm/NOS-Ceriani-35mm-Competition-Fork-Lowers-Set-AHRMA-/290669373294?hash=item43ad3ea76e&item=290669373294&pt=Motorcycles_Parts_Accessories&vxp=mtr
 Or these..........http://www.ebay.com/itm/Ceriani-Vintage-Flat-Tracker-Forks-/220949648916?hash=item3371a01614&item=220949648916&pt=Motorcycles_Parts_Accessories&vxp=mtr
« Last Edit: February 13, 2012, 10:53:28 AM by BLUE71TURBO »
« Reply #186 on: February 13, 2012, 02:44:08 PM »
This is the closest I've found for new............
I could only afford the dust covers my set of original Ceriani 30mm forks that I use at Bonneville
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
Offline BLUE71TURBO
« Reply #187 on: February 13, 2012, 03:58:46 PM »
 That's the same website i posted above !   ::)     LOL !!   ;D ;D   There is some forks with the provision for a fender on ebay that i posted above.
Offline Bill/BentON Racing
    • BentON Racing
« Reply #188 on: February 13, 2012, 04:09:50 PM »
D.I.D. 19 " 40 spoke on Calendar Girl,was on Yoshi kitted 590 RR bike,the went to 18" D.I.D.
D.I.D. 18" from the next year 1986.Has lip,19 year before didn't,go figure! ;D Bill
BentON Racing Website
BentON Racing Facebook
« Reply #189 on: February 13, 2012, 04:55:25 PM »
Blue............sorry I missed your earlier post............I skipped to the next with the ebay references.
Anyhow.........the point is............take a close look at the WINSTON bike and try to detail each component.  Since we all have a CB750 head in the garage from which to measure the distance fromt the top fin to the bottom head fin.............it should be relatively close to measure many of the other components in the picture.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
« Reply #190 on: February 13, 2012, 06:37:04 PM »
 Blueturbo the first set is MX legs, second set is double bump, he needs single.. If his trees are flat on the top one they may be in MX trees,
 New GP legs  are 1000Euros  :o :oI think, no trees..  complete pair of leg assemblies..
« Last Edit: February 13, 2012, 07:30:03 PM by 754 »
Offline sorcerer
« Reply #191 on: February 13, 2012, 07:02:17 PM »
These are definitely top mount bars..very flat /low rise on 35mm tubes ...i Think maybe like some dirt bike stuff. They have mounts for a fender / brace as can be seen in the pic.
I'll be looking through all your sources...I'll need those calipers as well..I think Airheart pieces? I'm guessing the rotors are stock Honda with the RC copper plate ...so popular of the era.
I remember going over to Earls Supply and a having our run of the place..bike in back...what do you need Russ? Great people. All the plumbing for all of or projects done right there in the back room on Hawthorne Blvd.
The Sorcerer uses 1976 GL forks with a home made brace and clamps. Talk about cheap to restore!
Offline sorcerer
« Reply #192 on: February 13, 2012, 07:04:30 PM »
RCjr
I had the snowflake version...off of I have no idea
Offline sorcerer
« Reply #193 on: February 13, 2012, 07:28:03 PM »
You found them...it's the flat track forks. I'm gonna have to move quickly..but these are definitely them. Pretty pricey for no trees...but that may be the going rate. I'd sure like to get the whole set up but maybe too much to ask.
Thanks....great shoppers...glad you do not have my CC#
RCjr.
« Reply #194 on: February 13, 2012, 07:33:05 PM »
The second set listed is double mount, pretty sure the iple had single mount forks and the V-8 double mounts..
Offline sorcerer
« Reply #195 on: February 13, 2012, 07:38:22 PM »
Damn...your right..single mount...were getting close.
« Reply #196 on: February 13, 2012, 07:41:40 PM »
 I cant figure out the front rotors, some of the wheels back then  were flattrack hubs like Barnes and others.. Did Sandy Kosman build anything for them bikes??..may have come from him?
 You can trim off the 2nd mount but it would be a shame, there is less of them. Themx fork tubes (not lowers ) are probably longer than the roadrace type, and might be interchanged...
Offline sorcerer
« Reply #197 on: February 13, 2012, 08:05:17 PM »
oK ...here are some english measurements...used my old Starret calipers on my 1/3 scale drawing: All very approx..but i have been getting close.
27" long axle center to top tree, 13" lowers top of seal to axle center
35mm tubes
8.6" stem
1 1/2" clamp thickness
2 5/8'offset from stem to center of tubes
Old pic from front:
7" spread center of tubes
2.7" bar clamp centers
OBTW we are at 80" wheel base.
Offline 736cc
Offline sorcerer
« Reply #199 on: February 13, 2012, 08:15:44 PM »
Bingo...there are the calipers...new...no less..awesome...Ok back to fork search.
