Author Topic: Salt Racer CB 750 OZ style  (Read 187892 times)
Offline bear
  • Leeton in Australia
Re: Salt Racer CB 750 OZ style
« Reply #525 on: January 22, 2014, 01:55:58 AM »
Looking good Johno. 8)
Brian
Offline cbornotcb
    • Photobucket link
« Reply #526 on: January 22, 2014, 02:16:32 AM »
Enjoying the cool change Johno ?
Keep at it mate,,,,my head hurts, & I'm even dreaming needles, needle jets & 02 readings, this thing I'm sorting makes new rules each day  :o
Tiny
Offline johno
« Reply #527 on: January 22, 2014, 04:25:07 AM »
Stitched up the bottom end tonight.
everything turns, got 5 gears, the new 5th locks in OK, I managed to get some adjustment into the teflon primary tensioner, I set it up to get about 1.5 turns of free play on the adjuster bolt.
Tiny, do me a favour and put your link into my thread, u know the hornbag idle surge, turns me on baby, I want the other forum blokes to hear music from an old miner.
ciao johno
GRASSHOPPER SOHC HONDAS ARE THE MEANING OF LIFE.
Offline johno
« Reply #528 on: January 22, 2014, 04:26:44 AM »
Offline Bill/BentON Racing
    • BentON Racing
« Reply #529 on: January 22, 2014, 04:43:26 AM »
Nice! ;D want to see dyno #'s on this one. Bill
BentON Racing Website
BentON Racing Facebook
Offline Old Scrambler
« Reply #530 on: January 22, 2014, 07:21:01 AM »
That is looking sweet...............salt-blasting will be nil.....................but be sure to rinse everything before you return. I carry a sprayer to water-rinse in the pits.  Also, remove the chain immediately after your last run and soak in ATF or WD40 in a closed container on the trip home...................or prepare to have a very rusty and stiff stretch of links hanging in the shop as a conversation piece.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline cbornotcb
    • Photobucket link
« Reply #531 on: January 22, 2014, 12:49:51 PM »
Take your medicine son, it'll make you feel better  :o
http://youtu.be/Gppco3aKYe0
Tiny
  • Moderator
« Reply #532 on: January 22, 2014, 12:58:13 PM »
COOOOOOOOOLLLLLLL as Fcuk Tiny.  ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
AWESOME as well. ;)
Offline cbornotcb
    • Photobucket link
« Reply #533 on: January 22, 2014, 01:10:19 PM »
Thanks Sam, it's still the source of my nightmares (tuning)
One interesting advantage (so long as the conrods agree)in choosing cams with zero overlap this time 'round, the boost has risen from 8/10 psi,,to 15 psi  :o
The hunt @ idle has been tuned out, sorry Johnno, but if you bribe me with a can, saltside, I'll fiddle with the air screw to get it back for you.
Tiny
  • Moderator
« Reply #534 on: January 23, 2014, 04:10:14 AM »
 ;D ;D ;D ;D ;D ;D ;D ;D ;D I thought the hunt/surging at idle was kinda cool. haha
Offline johno
« Reply #535 on: January 24, 2014, 02:56:56 PM »
Tiny,
have you got those needles sorted yet ?
Dont stress over them if you cant get them, in the old days on the dyno it was standard practice on the holden 6's with strombergs or SU's to fatten the fuel curve up mid range by dropping out the needles , mark with texta the 1/4 , 1/2 , 3/4 spots and pop in a drill then wet and dry the appropriate spot,  just give them a tickle , couple of thou at a time put on and check AF ratio on the rollers again. 8)
Now you have the F18 dash console you could do the same out the road dodging a few roos  ;D
Offline cbornotcb
    • Photobucket link
« Reply #536 on: January 24, 2014, 09:36:28 PM »
I don't know Johnno, my lambda died  :o
But,,after finding a gum tree flower cone nestling against the fuel filter , and resetting the automatic float level  ??? back to where it was 3 checks back, the hunt & ear bleeds have returned  ;D
I will have to wait another week for the new O2 sniffer to arrive, or the 43 degree days, which ever happens 1st, to test ride (private road, of course)
Just to keep the dream alive, here's a sneaky clip at moderate throttle, shortshifting while worrying about the 02 readings,,,,
http://youtu.be/cS5dAJz90uo
Usually, 250/4 and torque don't belong in the same sentence.......................
Tiny
Offline johno
« Reply #537 on: January 25, 2014, 03:55:46 AM »
Tell you what Tiny , that sounds sharp, seriously did you hear the pitch change just before you changed gear, thats a great indicator.  Bet you cant wait to be confident in the mixtures, hang in there,  get them right , it will be worth it.
cheers johno
Offline Leino
  • Not much of an
  • in drag racing since 2005
« Reply #538 on: January 25, 2014, 04:32:54 AM »
Legendary racing number  8)
« Reply #539 on: January 25, 2014, 06:06:44 AM »
I didn't know Santa Claus rode turbo bikes. ;) ;D
    • BentON Racing
« Reply #540 on: January 25, 2014, 06:39:32 AM »
Think he's worked on a sled a time or two ! Nice  ;D
Offline johno
« Reply #541 on: January 28, 2014, 04:11:53 AM »
You wouldnt read about it, I stitched up the bottom end last week, walla the heavy duty primary drive rubbers arrived today from M3....bummer, I hope the stocky hangs in there for a few dyno pulls and a few runs on the salt, should be OK, no dumping the clutch
positive thing is 100% of suppliers come through with the goods
Offline johno
« Reply #542 on: January 28, 2014, 04:16:27 AM »
I promised Mike to do two things , get the compression ratio right and to make  sure the piston misses the head so I had better do the right thing and do a few checks.   cc ing the chambers
Offline johno
« Reply #543 on: January 28, 2014, 04:19:10 AM »
That man is anal about perfection fair dinkum.
Every chamber is 22.5 cc    not 22.4 or 22.6  all 22.5cc      cool stuff Mike.
« Reply #544 on: January 28, 2014, 04:34:22 AM »
I call that a good start johno. ;) ;D  What are you using for fluid...antifreeze?
    • BentON Racing
« Reply #545 on: January 28, 2014, 04:39:28 AM »
Looks like it! Looks awesome, yo go Johno, Mike the best! ;D  Dyno soon? 8)  Bill
Offline dragracer
  • CB750F Dragbike
« Reply #546 on: January 28, 2014, 12:49:46 PM »
Is that a Play Do seal around the outside of the chamber??
Offline johno
« Reply #547 on: January 28, 2014, 01:17:30 PM »
very light waterproof marine grease to seal the plate with antifreeze for fluid, stops stuff geting rusty if it sits around for awhile....this head wont though  ;D
Offline johno
« Reply #548 on: January 29, 2014, 05:12:40 AM »
Well I only post good news normally but not tonight, :'( :-[ ???
The two things I enjoy about building a motor is putting the rings in and dialling in the cam, normally makes me warm and fuzzy.  First time in my life I trashed a ring, worst thing, it was in my engine.
Man those two ring JE 62mm pistons are super dupa thin and fragile, I was cautious but not enough obviously.
The 3 piece oil rings are so small I had trouble being able to se the expander ends to check, evan with big magnifying glass,   its a bummer getting old, this IS a sign ::)
I ordered a spare set tonight and if I can get then in 6 or 7 days I can still get it finished but will be like Dennis finish doing the tappets on the salt lake type scenario............ not good as there are a few people all geared to go and taking leave etc, I reckon 50 / 50 at this stage.,  The sunnaco supreme fuel arrived today, that wont last another year waiting though     Sufferin catfish I didnt evan swear
« Reply #549 on: January 29, 2014, 06:59:36 AM »
It happened to me with a JE oil rail too johno
