Author Topic: 72 cb750 Project,GSXR front end- Version 2.0 coming  (Read 60328 times)
Offline spazz1984
Re: 72 cb750 engine rebuild/project/ gsxr front end
« Reply #75 on: October 01, 2013, 01:03:43 PM »
a guy named Devin, he's doing a gsxr swap on the his 750 digned one that bolts right up. Its better than having to make a plug and chopping up the original one. I feel like its too critical of a part to have it spliced and welded, especially since its aluminum.  Its $100 and i will press it in myself once it gets here. Its going to take about 3 weeks to get the stem.
Really 100 bucks for a new press in stem and it takes about 3 weeks to get it wow I want that info
It cost me a little bit more than that just to cut plugged n welded
Sent from my SPH-L710 using Tapatalk 2
Offline squirley
« Reply #76 on: October 01, 2013, 01:35:36 PM »
Jojo,
Any idea if your supplier would be willing to spit out another stem, Im interested.  Thanks
Offline jojo
« Reply #77 on: October 01, 2013, 03:18:31 PM »
Jojo,
Spazz/Squirley- I spoke to Devin and I know he has some being churned out right now but not sure how many of them are already spoken for.  You can give him shout over the phone, he said it was ok for me to post his info. Its on his website as well. Stand up dude, he's been really helpful since i first sent him a message.
http://www.cognitomoto.com
Offline spazz1984
« Reply #78 on: October 01, 2013, 03:21:15 PM »
Thanks man
Offline jojo
Re: 72 cb750 engine rebuild, Transmission questions, please help!
« Reply #79 on: October 03, 2013, 08:42:05 PM »
One of the main reasons for my engine rebuild was to get to a second gear that kept popping out and forcing me to jump from first to third. After reading a bit it looks like this was caused by a bad dog ear or snap ring. Anyways, I am now at the point where i need to put it all back together but I need some direction. The guy that sold me the bike gave me a transmission but turns out he actually gave me 2 transmissions so now i have 3! What are some things i need to look at while trying to piece together the best possible transmission while at the same time fixing the issue.
for reference.
http://forums.sohc4.net/index.php?topic=86429.0
PLease chime in. im all eyes   :D
Offline jojo
« Reply #80 on: October 03, 2013, 08:57:14 PM »
any  know the difference on these numbers?
Uploaded with ImageShack.com
Offline jojo
« Reply #81 on: October 10, 2013, 01:59:45 PM »
Jojo,
Were you able to get a hold of him regarding the stem?
Offline jojo
« Reply #82 on: October 11, 2013, 08:17:47 AM »
Does anyone have any suggestions about the best place I can buy an allen bolt set for my engine?
Offline jojo
« Reply #84 on: October 11, 2013, 11:41:26 AM »
I will be buying from this guy:
http://www.ebay.com/itm/Honda-CB-750-CB750-Four-K0-K7-F1-stainless-steel-bolt-set-new-/280950457500?pt=Motorcycles_Parts_Accessories&hash=item4169f3c49c
I got swingarm bushings from him and they are first class.
Thank you sir, i will give it a look. How was the shipping?
« Reply #85 on: October 11, 2013, 11:43:58 AM »
About two weeks from Germany to VA.
Offline edwardmorris
  • Youngish
Re: 72 cb750 engine rebuild, almost done
« Reply #86 on: October 11, 2013, 12:37:21 PM »
Any pix of your recent progress Joe?
Offline jojo
« Reply #87 on: October 16, 2013, 12:22:54 PM »
Ill have some up soon. I had some issues with the transmission not shiffting correctly so i had to split the cases again  :(  >:(
now im waiting on a new set of allen bolts for the engine. I feel like i spend more time waiting for parts than working on my project :/
  • Youngish
« Reply #88 on: October 16, 2013, 12:29:09 PM »
I'm kinda anticipating the same, I suppose winter will work out just fine though, can't ride it anymore out here.
Offline jojo
Re: 72 cb750 Engine Rebuild/ GSXR Front End-- Broken case bolt.. now what?
« Reply #89 on: October 20, 2013, 08:47:26 PM »
So finally got around to getting the transmission issue sorted out so it was time to  seal the case... then this happened while i was torquing them to spec  >:( :( :'(
broken bolt- bleh
« Last Edit: October 20, 2013, 09:06:14 PM by jojo »
« Reply #90 on: October 20, 2013, 10:13:19 PM »
Make a sleeve to slip fit in case hole, ith a bit sticking out to grab with thin pliers..drill id to  1/8 or 3/16.. The drill with lefthand drill.
Offline jojo
« Reply #91 on: October 22, 2013, 09:24:23 AM »
here are the offenders.
managed to get one out but the other one isnt budging.... i found an edm place that will get it out for me but the threads will be ruined. Is it possible to fasten this part of the case with something else (bolt/screw) or possibly retap to a larger diameter
Offline iron_worker
« Reply #92 on: October 22, 2013, 09:34:28 AM »
Did you try an easy out or left hand drill bit? Once the head is sheared off all the tension should be removed from the threads so it shouldn't be too hard to back it out ... unless the threads are mangled.
What torque value are you using? You weren't trying to torque those ones to the same value as the main bearing cap bolts were you?
IW
Offline jojo
« Reply #93 on: October 22, 2013, 09:38:59 AM »
I did, thats how i removed the first one. The second one just wont budge, i think the threads are done. I was torquing according to the shop manual.
« Reply #94 on: October 22, 2013, 02:32:47 PM »
Try the bushing method i suggested with the other case half guiding it straight.
 Or.. Another EDM shop.. They way I understand it an EDM can burn a hex hole in it, then insert allen wrench, turn it out,,
Offline iron_worker
« Reply #95 on: October 22, 2013, 02:41:39 PM »
When I read the manual I could only find torque values for the bearing cap bolts which I believe are larger diameter than the outer case bolts. So if you used this torque value then that could be why they are snapping off.
I always wondered how that worked when people said they would get it "wire EDM'd out." Good info.
IW
« Reply #96 on: October 22, 2013, 03:06:48 PM »
Or EDM the bolt and all is left is the spiral ofthe thread - like hellicoil - and you just pull that out
Offline jojo
« Reply #97 on: October 24, 2013, 02:20:27 PM »
IW
hey guys thanks for the input i really appreciate it. I managed to get a machine shop help me out with drilling out the old bolt, re-tap it, and install a heli coil so its all fixed up and ready to go.
It was kind of a blessing in disguise. I realized there was some oil left over from when i used some on the tranny gears and the case didnt seal correctly. Anything in particular i should do or lookout for before I seal them back up again?
« Last Edit: October 24, 2013, 02:31:59 PM by jojo »
Offline jojo
Re: 72 cb750 Engine Rebuild/ GSXR Front End-- Wheels are done!!
« Reply #98 on: October 24, 2013, 02:37:29 PM »
https://imageshack.com/i/mj8hpgj
https://imageshack.com/i/b83h1yj
finally got my wheels all laced up and trued and the tires are mounted and balanced. more progress finally. Still going to have the rotors redrilled to have them fit the new harley hub.
To those considering this GSXR swap... after doing it myself, sourcing, parts having spacers, buying new rotors etc i wouldn't do it again. I would just buy the plug and play hub instead. I ended up spending more money this way than if i had just bought it and used my current wheel, bearings, rotors, and calipers. It would have been a lot less work, about a 150 less, and less headaches and custom fab work (caliper spacers, hubcentric rings, buying new rotors)
Live and learn  :o
« Last Edit: October 24, 2013, 02:42:36 PM by jojo »
Offline jojo
« Reply #99 on: October 24, 2013, 02:50:06 PM »
also, in case any one is wondering i used dunlop 404 series tires on both the front and back.
Front- 100/90  19"
Rear-  120/90  18"
http://www.bikebandit.com/dunlop-d404-motorcycle-tire?WT.mc_id=googlemerchantfeed&utm_source=feed&utm_medium=merchantfeed&utm_campaign=pla&gclid=CMupkZ25sLoCFcnm7AodhycAvw
